Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Flooding Yesterday the washer was working fine. Today I loaded the washer and turned it on. When I came back to the kitchen a few minutes later water was leaking from the bottom of the washer and flooding the kitchen. I turned it off but the water kept coming. I removed the clothes and used cups to scoop out all of the water left in the machine. When there was about five inches of water left, the flooding stopped. What happened and how do I fix it?
  • Anonymous Nov 09, 2007
    Same thing, water came out from the bottom of the washer & flooded my laundry room.
  • Anonymous Mar 23, 2014
    the drumkeeps filling with water every few weeks or so. To fix this I remove a screw and twist lock located at bottom left corner then all water floods out with small soft black balls usually quite a few. what could be causing this ?
    President:
  • 878 Answers
La Trisha, There could be many reasons for the leak, however usually all leaks are visable. Your model is a direct drive pump and motor and I have seen a lot of these pumps go bad and leak. You will have to remove the front panel. There should be 2 clips, one on each side of the washer top. Push a putty knife in these clips and the front panel should pop out from the top. Now you will be looking right at the pump on the bottom. It is held on with 2 clips and 2 clamps, a real easy fix. When you remove the front panel, let the washer fill a little again and see if the water is pouring from the pump. You will also be able to get a look at all the other hose attachments. The part number for the pump is 3363394. Good luck..
Posted on Jun 18, 2006
  • 3 Answers
Chances are the clear plastic line has popped off the connector fitting of the water level control. Cut off 3/4 inch of the tubing end and reconnect the tubing to the water level control. The water level control should be behind the Control Panel at the far left side. Hope this helps.
Posted on Nov 09, 2008
My GE Model JBP90A52AA electric range with convection oven suddenly does't power any of the oven functions, broil, bake or convection. The lights come on for teomp set and begins to heat when the sta
If it were a furnace, I would say it was a thermo coupler, but on the stove it is called a thermostat. If it goes bad, it will stop the heat after a few minutes, because it can not sent the right signal to the brain. Look at the web site ereplacments and maybe someone has also had this problem with this unit. Parts can be purchased then at the web site. It is what I did for a washer and fridge. Hope this helps.
Sep 29, 2014 | Kitchen Ranges
Reduced engine power warming came on yesterday, after driving in extreme cold temps, idled rough and the. started back up fine after sitting a few minutes. Drive today, in cold temps again, and drove...
Well...my ball park guess on this is just a tune up. The engine light is usually showing a misfire. If the plugs are bad then the cylinder is not igniting the fuel and it is flooding out. With what is here this makes sense to me. Let me know what it does turn out to be.
Jan 24, 2013 | Cars & Trucks
Ge load size selector broken
You can buy this part, suggest you go online and purchase it. Contact this website: Appliance Parts Accessories Repair Help
May 19, 2017 | GE Profile WPRE6100G Top Load Washer
WHDSR209DAWW washer leaks major water during the wash cycle. Rinse and spin cycle fine, only pours water during the wash cycle. Kitchen was flooded from this happeneing yesterday. Took the covers off, all...
I asked my wife about this question, before I became to technical and scared you more then you needed to be scared. My DARLING wife told me right away that you are overloading your machine. It occured to me she may have done this a few times herself. Mind you this is 50 years of experience . When you load your machine with to many items the water is displaced and has to go somewhere, it's caming up over the top and causeing your flooding problem. After you clean up and have a few highballs to settle your nerves, you should be OK. My wife and I wish you GOOD LUCK.
Sep 24, 2011 | General Electric WHDSR209DWW Top Load...
Washer Door won't open
kill the power either unplug it or turn the breaker off wait few minutes hopefully might reset it if not call service... may need new control board or latch mechansim kinda common after power outages when power comes back sends jolt blows electronics out hope this helps
Jan 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error message LE5E and would only oparate prewash
it's not on 'test' is it,
try turning the machine on while pressing the start and on buttons together until dOFF apears.
Jan 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Dribbling water when trying to fill up
Turn off faucets for hoses to washer. disconnect hoses at washer, noting which one went where first.. Hold end of hose in washer tub and turn on faucet. If it comes out strong, check the filter screens in washer inlet valve where hoses connected. DO-NOT remove these screens. If you do it can cause flooding by allowing grit to hold open valve. Clean screens without removing them by scraping with small screwdriver and flushing with water.
Nov 21, 2007 | Washing Machines
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
210 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
