Question about Zanussi ZWF1440 Front Load Washer
Zanussi zwf1631 w
When the machine has finished washing, the part of the drawer where you put the comfort, is full with water. This then has to be emptied every time before you can use the machine again.
Also the machine does not always take the comfort. I have cleaned out the drawer and have scrubbed the top to make sure all the holes
are not clogged up where the water comes from.
Any ideas, I do have a maintenance contract on the machine but was not sure if this would be covered.
  • kellywelleru Dec 01, 2008
    Thank you for yor reply, I have had an engineer check the machine and the compartment where the hole is above the softner dispenser needed to be replaced. This was so badly clogged up, that it was beyond cleaning. - Tip from the engineer to push a cable tie as far into the whole and twist it around, once a week and this should stop the hole from being clogged.
  • vikesa Jan 19, 2009
    zanussi aquacycle 1400 still not taking conditioner after clearing hole
    Champion:
  • 249 Answers
There just one hole in the comfort part of the drawer is that clear,it has to be that.did you take out the drawer to clean
Posted on Dec 01, 2008
Bosch maxx 1000 - when finished cycle, leaves central fabric conditioner drawer full of water + trace of condtioner.
Check that the hose that connects the drawer to the tub is clean, fabric conditioner normally gunks up especially on colder wash cycles.
Apr 01, 2015 | Bosch Washing Machines
Washing cycle stops before finishing
Hello, i have exactly the same problem. Did you find the solution?
Thanks
May 24, 2010 | Zanussi ZWD12270 Front Load Washer / Dryer
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
Maytag MAH8700AWW - detergent drawer full of water
try removing the drawer to see if one of your kids has put something in there
Dec 13, 2009 | Washing Machines
I have a zanussi washing machine mod fx1465w. I
If the drum is not turning this could be due to worn motor brushes,assumimg that its pumping out the filter will be clear and spin should follow @ program end.The motor brushes are secured by two screws each.....
Nov 24, 2009 | Washing Machines
Zanussi iz 161
Hi there!
Congrats on the twins! Getting any sleep yet?
I think the problem is to do with the water pressure sensor, or hoses inside the machine.
This sensor determines when there is enough water in the machine, and turns the valve off.
If you are competent to have a look, then continue -
Isolate supply and turn off water connections -
Remove the lid by removing screws at the rear, and slide back.
Check the air hoses that are near the drawer area. It is not uncommon for one to just come loose, or rip.
Reassemble and turn on to check opperation.
If this assists you, please spare a moment to rate as Fixya! as I would apreciate it. Thank you.
If not, contact me again for further items to check.
Jun 18, 2008 | Zanussi FJS1225W Front Load Washer
Washer not woring properly
check your water valves ere not open cicuit if not may be your programmer
Sep 11, 2007 | Zanussi FLA1001W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
162 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
