Question about Sony FD Trinitron WEGA KV-27FS320 27" TV
TV won't turn on
I've been turning on the power for the tv from the DirecTV remote and in the last two day, i haven't been able to turn it on from the remote or the manual controls. i think i have to reprogram the remote, but can't get the code numbers unless the tv is on. the satellite feed is working fine, i just can't turn on the tv.
    President:
  • 3,130 Answers
If the TV wont go on with the manual button on the front panel, then you have an issue with the tv set. Try a differant wall recepticle. Or unplugging it overnight. If it wont go on with the button on the front of the set after this is tryed, then its time to go to the repair shop, as the set has a power supply problem or a problem in the HI voltage/sweep circuit. Good Luck
Posted on Jun 17, 2006
Have an Element TV and the remote will shut the TV off and on plus do the SAT/CAB Directv I can turn on and off but the channels won't gel so I can watch The TV
Search Results
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code. ... All the steps you'll need to program your Rogers Remote to control all your home theatre devices. .... the Cable turns on and off and volume etc. but will not shut offthe tv. ..... I bought a Element Electronic Smart TV and have set it up.
    Support ' Element Electronics - Elementelectronics.com
    www.elementelectronics.com/support/
    Element ElectronicsA description for this result is not available because of this site's robots.txt - learn more.
    DIRECTV - Support: Your Remote Control
    www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
    DirecTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On until they ... Power Key - Your DIRECTV™ Remote can operate alternate devices.
    [PDF]Get to know your remote control Need more help ... - AT&T
Jan 31, 2016 | RCA Televison & Video
TV scrolls through inputs and menu after turning on. Will not stay on any input.
Main system control memory IC is faulty. Replace it. Contact any service technician. http://electronicshelponline.blogspot.com/
Mar 25, 2015 | Televison & Video
Need code & instructions for Emerson TV. I have universal remote
Hello
Codes for Emerson TV with "Direct TV - RC64 for web Univeral remote control are:
10154, 10236, 10463, 10180,
10178, 10171, 11963, 11944,
11929, 11928, 11911, 11394,
10623, 10282, 10280, 10270,
10185, 10183, 10182, 10181,
10179, 10177, 10158, 10039,
10038, 10019
You haven't specified the model number of remote control you possess; that is why I send this remote controls codes.
[1] Locate the 5-digit code for your DIRECTV® Receiver
[2] Power on the DIRECTV Receiver
[3] Slide the MODE switch to the DIRECTV position
[4] Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys
[5] Using the number keys, enter the 5-digit code. If
performed correctly, the green light under the
[6] Aim the remote at your DIRECTV Receiver and press
the PWR key once. The DIRECTV Receiver should
turnoff; if it does not, repeat steps 3 and 4, trying each
code for your brand until you find the correct code
OK.
Jul 02, 2011 | Emerson Televison & Video
I tried to program my remote control to power my sharp tv and it will now turn the tv on and off but I cannot get any directv channels and the screen is fuzzy.
PUT THE DIRECTV REMOTE BACK INTO THE TV MODE TURN THE TV TO CHANNEL 4 OR 4 THEN PUT REMOTE ON DIRECTV TO CHANGE CHANNEL ENJOY
Aug 24, 2009 | Directv RC-64 Remote Control
Problems programming DVR remote to TV
If your DirecTV remote is in SAT mode and the power button isn't turning the receiver on and off, you will likely need a new remote. There isn't suppose to be any trick to getting the power button on a remote to work. However, only DirecTV tech support can confirm this. I would give them a call right away.
Jul 12, 2009 | Philips Televison & Video
Directv remote
if the Directv remote has the ability to operate other units you will need to input a code for the Vizio into the Directv remote
Nov 25, 2008 | Universal Remote Control DIRECTV Universal...
Sony FD Trinitron WEGA KV-27FS320 27" TV Logo
154 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
