Error i keep getting error messages saying "tftray.exe" and also "svchost.exe" how do i fix them? please help.....
Thanks Imahar04, but i have done a system restore but it still keeps happening.
any other suggestions??
Posted on Oct 19, 2008
    Problem Solver:
  • 20 Answers
Do a system restore if using XP, or a recovery at boot up if using Vista.
Scvhost.exe driver not redy..please solution
Glad to help YOU!
The svchost.exe file is located in the folder C:\Windows\System32.
On STARTUP Svchost.exe checks the services portion of the registry and constructs a list of services that it needs to load. Usually multiple instances of Svchost.exe will be running simultaneously. If the process svchost.exe uses high CPU resources it is mostly due because Windows Operating System is downloading some updates.
WARNING: A 100% CPU usage could lead to the presumption of a hidden malware on your computer!!! Same for the message that you got: "scvhost.exe driver not ready"...
I'd suggest you to do a SPYWARE/MALWARE scan AS SOON AS POSSIBLE and AS DEEP AS POSSIBLE!!!
GOOD LUCK!
Mar 14, 2011 | Computers & Internet
I am getting error "svchost.exe
If this is DVD drive or CD rom drive replace the drive, it is bad
Jan 24, 2011 | Computers & Internet
I'm receiving 2 messages from my webroot internet security essent
This sounds like a virus to me? you say you are receiving that message, please, is it Windows "Telling" you?, or some program "Telling" you? please clarify? svchost, is not something that should be deleting anything...Both TCIP & netbt are VERY important part of Windows, so I do NOT think, it should be allowed.
Feb 28, 2010 | Webroot Internet Essentials (83210)
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
Svchost.exe applicationerror The instruction at "0x012cf496" referenced memory "0x0123f496". The memory could not ne "written".
This is the most common question when computer users start to experience this error messages pop up on their screens. Many people immediately call in their computer-technicians to fix this problem and end up paying huge amount of money on professional fees.
Unknowingly, this problem could be easily fixed on your own, even if you know little about computers; and further prevents this problem to occur in the future. There are many ways to solve this and I shall discuss further on these methods; as well as the ones easier for you to do.
One of the best methods in dealing with this kind of situation is to verify the settings of windows update. If you keep on updating your system, some of the applications may not be compatible with your OS; hence, this error message shows up. In some cases, you may need to register again your update DLL file in order to fix this issues.
Another method is to reboot your computer in order to reload your operating system. There are times when your computer encounters problem during startup and rebooting your system can resolve the issue. Still another technique is to remove update files which are already corrupted; these files are usually found on your registry. In using these methods, you may need some expertise in order to make precise identification of corrupted files.
The best way to solve your problem is to use registry cleaners. This software can fix this trouble because this problem may be related to registry issues caused by the build-up of unwanted trash files. These junk files can cause various types of problems in your computer including svchost.exe application errors; it can further cause your system to run slow, takes longer time to start up, and eventually crash if not resolved immediately.
Therefore, the next time you encounter this message, you don't have to call in your technician to fix the problem for you; because you already know how to fix svchost.exe application error yourself using registry cleaner software.
http://www.ultimatepcutilities.url-go.com
Dec 01, 2009 | Microsoft Windows XP Professional for PC
Everytime i open my computer, ah pop-up windows say's WINDOWS CANNOT FIND SCVHOST.EXE
First, I'll let you know what's going on, then I'm going to post from Microsoft, what svchost.exe does, and how to find out where the problem is. I can help you further if you need it.
Svchost.exe is a program in WIndows XP Pro that will start services in your computer during startup. It sounds like you have deleted a program and "service host" is still looking for it to open on startup. This can happen if the program was removed without using the correct removal procedures. It is still listed in the registry and your computer is still trying to access it. DO NOT edit your registry unless you know what you are doing. You could create a catastrophic failure of Windows. There are programs that will remove registry entries if those entries are no longer valod. You can fing a free program for this function at web sites like www.nonags.com
Following is information from the Microsoft web site:
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services allows for better control and easier debugging.
Svchost.exe groups are identified in the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the following registry key, whose Parameters key contains a ServiceDLL value: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Service To view the list of services that are running in Svchost:
  1. Click Start on the Windows taskbar, and then click Run.
  2. In the Open box, type CMD, and then press ENTER.
  3. Type Tasklist /SVC, and then press ENTER.
Tasklist displays a list of active processes. The /SVC switch shows the list of active services in each process. For more information about a process, type the following command, and then press ENTER: Tasklist /FI "PID eq processID" (with the quotation marks) The following example of Tasklist output shows two instances of Svchost.exe that are running. Image Name PID Services
System Process 0 N/A
System 8 N/A
Smss.exe 132 N/A
Csrss.exe 160 N/A
Winlogon.exe 180 N/A
Services.exe 208 AppMgmt,Browser,Dhcp,Dmserver,Dnscache,
Eventlog,LanmanServer,LanmanWorkstation,
LmHosts,Messenger,PlugPlay,ProtectedStorage,
Seclogon,TrkWks,W32Time,Wmi
Lsass.exe 220 Netlogon,PolicyAgent,SamSs
Svchost.exe 404 RpcSs
Spoolsv.exe 452 Spooler
Cisvc.exe 544 Cisvc
Svchost.exe 556 EventSystem,Netman,NtmsSvc,RasMan,
SENS,TapiSrv
Regsvc.exe 580 RemoteRegistry
Mstask.exe 596 Schedule
Snmp.exe 660 SNMP
Winmgmt.exe 728 WinMgmt
Explorer.exe 812 N/A
Cmd.exe 1300 N/A
Tasklist.exe 1144 N/A
The registry setting for the two groupings for this example are as follows: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Svchost:
Netsvcs: Reg_Multi_SZ: EventSystem Ias Iprip Irmon Netman Nwsapagent Rasauto Rasman Remoteaccess SENS Sharedaccess Tapisrv Ntmssvc
RApcss :Reg_Multi_SZ: RpcSs
Jun 18, 2009 | Microsoft Windows XP Professional for PC
Svchost error memmory
Svchost.exe acts as a host for a group of services on your computer. As you are aware there a many services and programs the run silently in the back ground. Svchost.exe pools many of these services in one group and runs all at the same time. This is a great for efficiency. However, it can cause your CPU to spike to 100%.
As mentioned before svchost.exe is essential. So the trick is not to block svchost.exe, its to limit your computers need to use it. You can limit your computer need for svchost.exe. By cutting down on the services that are loaded when you PC starts. This can be done quite easily.
1. Open your Start menu.
2. Click Run
3. In the command screen type: msconfig
4. In the "system configuration utility", Click "services" tab
5. Uncheck all services that are unnecessary.
6. Click "OK"
Uncheck the suspecious services but make sure you do not stop necessary services. Restart the PC to take them affect
Mar 20, 2009 | Dell Inspiron B130 Notebook
Svchost.exe problem
i think its a virus or a worm problem to get rid of this go to my blog and download quickheal two months full verion scan it will clear your problem
dont forget to turn off system restore before installing and upto completing the complete scan of your pc
bye bye
http://xviruslab.blogspot.com
Feb 28, 2009 | Microsoft Windows XP Professional
I have deleted svchost.exe accidently from windows xp and cannot now log onto windows. I have tried expanding the file from dos however still cannot log on
this is going to be a tough one to fix. since I don't know which svchost you have deleted from the system.
usually when that happen the only solution is to reinstall the OS. even try to fix it from the registry key, the key and the pointer will be there, but not the excution file, and there is not way which svchost control what services.
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the registry key.
Dec 02, 2008 | Microsoft Windows XP Home Edition
I have compaq cq60 104u. I have windows xp pro with sp2 installed on it..Howvere the inbuilt mic is not working and i keep getting svchost.exe application error..when i connect to internet. Does this sytem...
svchost.exe is a generic host process name for services that run from dynamic-link libraries.
Sounds like a driver or application problem you have. As you get this when you connect to the internet, sounds like your web browser. Try reinstalling it
Nov 29, 2008 | Computers & Internet
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
