I have gone to Power Options trying to set the time when Monitor would go dark so I could leave the pc on all the time and it will NOT change. The screen will stay on day and night.
  • Eleanor150 Oct 19, 2008
    No, that's where I had it, on Home/office desk..
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmmm...did you save that or apply the changes ?
  • 84 Answers
Change to home /office desk it may be on always on let me know if this helps bob
Posted on Oct 19, 2008
If i leave computer on without anyone using it . computer goes to black/dark screen , can't perform any functions. also computer crashes at times during use.
You need to check your power settings. It is being set to go to turn of the drivers after a certain amount of time.
Control Panel\Hardware and Sound\Power Options Then change the power options so it does not shut off the hard drive.
Mar 06, 2011 | Gateway DX4300-03 Desktop PC
Monitor comes on for 2 seconds and then goes all black. What type of problem do I have?
May be you have set "Changed" the setting of your monitor power. If it's set then try this step and see whether it's helpful to you or not. In Windows 7, Vista, or XP, to change the power management settings. To change power management settings in Windows 7, Vista, or XP: Note: If this doesn't match what you see, refer to About navigation settings in Windows.
For Windows 7 and Vista From the Start menu, select Control Panel. Then choose Power Options.
From the list in the left panel, click Choose when to turn off the display or Change when the computer sleeps.
Set your options. For each action, "Turn off the display:" and "Put the computer to sleep:", you can select times ranging from 1 minute to Never.
Click Save changes.
Windows XP From the Start menu, select Settings, and then Control Panel. Double-click Power Management or Power Options. From the "Turn off monitor:" drop-down menu, select a time from After 1 min to Never. Click Apply, and then click OK.
All the Best!
Sep 15, 2010 | Computers & Internet
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
No signal with acer moniter
Check your power settings on your PC (Start Button ---> Settings ---> Control Panel ---> Power Options)
Under the "Power Schemes" tab you will find the dialogue "Turn off monitor:" and then your choice. The power option refers to the SIGNAL sent to the monitor, not the actual monitors power-source itelf (although some can control both). It will simply stop sending a signal to the monitor and "put it to sleep"
Change the setting to what is appropriate for your use, and you should be set!
Hope this helps!
-- RT
Sep 03, 2009 | Acer AL1916W 19" LCD Monitor
Loss of light on screen Dell Inspiron E1705
Check your backlight settings, Power Settings, etc.....
You may have Vista (vista has other power settings such as a custom sleep mode which can fail sometimes to work properly with some hardware/monitor configurations).
So Disable any unconventional Hibrid Hibernation options k!
Apr 20, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
Dark screen if unhooked from battery
You can use the function keys to increase the brightness. Also if you go to Start, Control Panel, Power Options you can change the settings to give you more monitor time.
Apr 15, 2009 | HP Compaq Presario R4000 Notebook
Blank screen but sound works
on XP check your "ScreenSaver" Monitor power "Power" options settings. It might be set to turn off monitor after so many minutes.
on Vista;
go to Control Panel >click on "Mobile PC"> click on "Power Options" > Check "Change plan settings" on the selected option
Adjust time as required
Jan 11, 2009 | Acer TravelMate 290LCi Notebook
E-yama 17" flat screen monitor
It sounds like the internal bulb in your monitor is going out. Some LCD monitors go through a slight warm-up period but it should not be 5-10 minutes. You may want to change your Power Saving settings to prevent from going into standby. Here's how:
Right-click in an open space on your desktop
Choose Properties
Click the Screen Saver tab
Down at the bottom look for the Power settings
Change the Monitor Standby to NEVER
Click OK
Good luck!!
Oct 01, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
The monitor is black
i've had this problem from even trying to restart my pc at times. it happens usually when you've changed or added something that the pc wasn't prepared to do. if you've installed a new card. disconect it and try again. installing the drivers and software for it first.
Aug 21, 2008 | HP Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
