Question about Panasonic CT-36D11 36" TV
Lightning? Lightning strikes close to my home and my TV dye. Nothing works! What to do? DVD and Satelite receiver I fixed , it was power supplies fried, replaced and OK, but TV is a problem, because I don't have a clue about voltages on main board. What voltages should be where? Anybody can help me? Can I find all board somewhere? Thank's! Steffano
    President:
  • 3,130 Answers
90 % of the time, when you get lightning damage to a tv set, its not worth repairing, because the chain reaction the surge causes. Its a matter of labor v cost of a new set. Ive seen brand new large screen tvs 1 week old get popped with lighyning and cause every board in the set to bur and blow out not only the printed circuit traces, but the ICs had holes in them and the transistors were blow apart. Luckly this customer had homeowners insurance and got a new set. With a lightning strick all you can do is start from the front of the power supply an work your way back till you get some life in the set. Now you could get lucky as I know panasonic uses whats called a thyristor type of a device that when a surge enters the set it shorts out the ac plug and pops the internal fuse and it will be black. You cant simply replace the fuse cause the thyrisistor is shorted. Also no one with no teleivision training should be inside a tv now a days as there are no user serviceable parts inside and theres way way more voltage inside these sets ,even unplugged then a dvd or satillite reciver. I would advise you to get a pro to assist you in this matter as it could if your lucky ,like i said before be a simple problem But i've seen peeps make a mountain out of a molehill. Good Luck
Posted on Jun 17, 2006
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
What's the likelihood of my TV being able to be fixed after a lightning strike killed all electronics on one wall?
Probable power supply fault now. Maybe if you replaced the power board it might work again.
Jun 19, 2017 | Vizio Televison & Video
Had Lightning strike. TV box destroyed and tv does not get power. Which boards may need to be changed?
The power supply board is the first board to feel the impact of a lightning strike.. Try that one out first.
Jun 21, 2016 | Televison & Video
Would replacing the main board fix my TV?
We can't predict what might have been happened during a lightning strike. If the TV is dead now; the main power supply regulator board [SMPS] board is fault. If so, you have to replace it first. then only we can get information about the condition of the main board. If the TV was connected to external Ariel or cable; before the lightning stroke; the possibility to damage to the main board too is there upto 80%.
In fact, if both of this boards are damaged, it might cost around 2/3rd of the total cost of a new TV.
The decision left to you. Do whatever you want.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 26, 2015 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How do I fix a 50 Plasma TV that seems was struck by lightning
Your probably have power supply damage, but lightning strikes can do major damage in all circuits.
Aug 07, 2015 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
We took a lightning strike and my RCA 20f510td has no indication of power. Is there a fuse that needs to be replaced?
Hello
The faults occurs during lightning strike is not predictable. At present, the power supply inverter section of your RCA ahs damaged. A thorough chekup must be done to detect whether there is any other faults also occured or not during this time. OK.
Apr 10, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Receiver tuner out after lightning strike
you more than likely have a F.E.T.(Field Effect Transistor) front end tuner,very susceptable to lightning or static charge damage, chech your home owners insurance, you might be able to repair or replace the tuner but it wont be cheap
Sep 26, 2009 | Onkyo HTR500 Receiver
Model TDC2075A Sansui Had lightning storm, lost power no close lightning strike. TV will not power up, don't know if it has internal protection or is power supply went out
you mite try replacing the ac fuse 1 time-if it blows again there is a short in the power supply-i would then check rectifiers in the primary of the power supply-then check the fet-if any of them are shorted replace them
Sep 04, 2009 | Sansui CDVD1900 19" TV/DVD Combo
Panasonic CT-36D11 36" TV Logo
85 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
