Question about Samsung SyncMaster 940N Flat panel Monitor
Samsung Synchmaster 940n - screen lasts 2secs then goes.off
Hi, My Samsung Synchmaster monitor comes on for 2 seconds and then goes off. If I repush the blue on/off button it comes back on for about 2 seconds and then goes off again,. Whats happening. Can anyone help.
I bought it new of an ebay store but I notice that Samsung will not honor warranties from an online auction. (Now they tell me). Can anything be done with it. Is it settings or stuffed?
  • 2 more comments
  • murraysch Nov 01, 2008
    After a year of no problems, my 945N frequently loses its output and the screen goes black. If I turn the monitor power off for about a minute and switch it on, everything comes back. This happens in a more intensified video environment. It's definitely the monitor because I tried a new video card and the same thing happens.
  • zdubbya Nov 07, 2008
    I'm having the same problem. My monitor will come on for a few seconds, then go black.
  • pskk Nov 18, 2008
    I am also facing the same problem with my monitor, it was working since past few month.
  • kelly4will Jan 09, 2009
    I have the same problem, and i have even tried conneting it to another and it is still the same and looked at all the other suggestions commented on the help page still nothing. The monitor is nearly 1 year old, what is the best thing to do.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Not a big problem just change your backlight inverter
Posted on Oct 19, 2008
  • 3,940 Answers
#1 Make sure that you have only one input cable hooled up to the monitor. Using both DVI and VGA inputs from the same video card can cause this issue.
#2 Try both VGA and DVI inputs individually, make sure issue occurs on both.
#3 See if issue occurs connected to another system. Also boot this system to SAFE MODE see if monitor will then function at that resolution (It may be your system is set to a resolution the monitor will not display)
#4 If purchased recently, contact the seller. Most will honor a malfunctioning item. If not, contact EBay as there is normally a $200 MINIMUM buyer preotection plan,
Hi. I have a samsung syncmaster 940n black. After i turn on my computer the screen if just black and the blue light(where i turn the monitor on) just blinks.It worked normally yesterday.
The most common problem with the 940N units is a failure of the power supply/back light inverter board. This is easy to repair be replacing 6 capacitors on the power supply. Here is a link to a repair guide with dis-assembly instructions and what to look for and replace and the power board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 17, 2011 | Samsung SyncMaster 940N 19 inch LCD...
SyncMaster 940N - screen has gone dark when turned on and computer booted up. If I get close to the screen I can just about see something on the screen. I have brought up the service menu and all the...
Your problem is usually caused by a bad power supply. You should be able to do the repair yourself, if just requires replacing 6 capacitors on the power supply board. Here is a link to a repair guide that shows how to disassemble the monitor and repair the power supply board.
And here is the a picture of the power supply board.
BuddyMc
Apr 16, 2010 | Samsung SyncMaster 940N Flat panel Monitor
Stand for the monitor on a samsung syncMaster 940n broken
It depends bad the parts are broken, this is 2007 model, you may have hard time getting replacement parts, details pictures will help.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 940N Flat panel Monitor
Samsung syncmaster 913c
press the blue fn button and look for a screen on the buttons F1 through F12
Jun 17, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Samsung Synchmaster 940N fault
I've had the same problem with mine and just fixed it (well, it's still working now, so fingers crossed).
The problem is the high-voltage supply to the backlight is breaking down due to a discharge path somewhere.
I took my monitor apart and noticed there was a lot of residue on the underside (surface-mount) side of the power supply board. The residue was bad enough to see fingerprints in it from the assembly workers. I cleaned the board thoroughly with isopropanol (other flux solvents would probably do a similar job) let it dry thoroughly, reassembled it and since then I've no problems :o)
The monitor isn't easy to take apart. Unplug the mains supply and video connector and remove the three screws and the stand. The body of the monitor is held together with clips all the way around. Prize these apart with a penknife or similar item. You have to be fairly firm, but careful not to slip and damage the monitor or yourself. Once the back is off keep the LCD face down in the front bezel, You'll see a small cable carrying signals from the front panel buttons. Remove the tape holding the cable down and unplug the connector on the end by holding down the latch.
There's a thin shiny panel clipped to the side of the pressed metal covering for the power supply. Prize away the clips on the outer edge first, then you are able to swing the panel towards you and unclip it from the other two locations by the arrows. Underneath are the backlight connectors. Note the colours of the wires (blue near the top, pink near the bottom for both pairs) and unplug them, holding down the latch. The only remaining anchor for the panel is the flat cable connector going to the LCD driver board at the top. Angle the metal pressing up a little so you can reach the connector and press in the two latches at the side. Then just slide the connector out.
Now you can remove the pressed panel holding the power supply and the VGA connector board. Undo the screws and take out the power supply board. Disconnect it from the other board (remember the latch) and pop out the three pegs holding the supplementary insulation sheet onto the back of the board. Don't lever them from the caps, just press the latching ends inwards and they pull out easily. Now your board is free you can inspect it and give it a clean. If anything looks damaged on the board it's probably best to replace it. Otherwise if it's covered in sticky residue like mine, clean it using a clean stippling brush or and old dry toothbrush with plenty of solvent and let it dry for a while.
Reassembly is just the reverse of assembly.
Hope I didn't forget anything. Good luck if you want to try it, but if you're not confident with electronics find someone who is. There are probably a number of faults that could result in this symptom, and I don't know how common mine is.
Cheers
Oct 13, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Screen goes black after 2 seconds
Simplest solution may be the screen resolution settings are set higher than the monitor's capabilities. Try lowering the screen resolution and refresh rate in the display properties or try booting to safe mode (press F8 when the Windows splash screen first appears) and see if the LCD will display the windows desktop. It that works, check your video drivers and the screen resolution and refresh rate settings.
If the monitor has the problem in safe mode and/or if lowering the screen resolution and refresh rate don't help then I suspect the a problem similar to one some Dell 17inch LCDs have. On the Dells It is usually caused by a defective voltage regulator transistor in the backlight inverter circuit. Troubleshooting that problem should only be attempted if you have experience at repairing electronic circuitry since it will involve testing individual components and soldering.
Jun 15, 2008 | Samsung SyncMaster 940N Flat panel Monitor
HOW DO I HOOK MY SAMSUNG SYNCHMASTER TO MY COMPUTER? I HAVE THE DVI CABLE CONNECTED TO BOTH AND IT KEEPS SAYING CHECK SIGNAL?
Prior to attaching the SynchMaster and if there is another monitor, pls try lowering the Screen Resolution of your Display Properties. It may also be necessary to lower down the Screen Refresh Rates. In some video card, you may have to activate Twin/Extended view or enable the use of a second monitor assuming that your regular monitor is connected to the standard 15pin VGA and that the Samsung would be the 2nd monitor using the DVI.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 18, 2008 | Computers & Internet
Samsung SyncMaster 940N Flat panel Monitor Logo
623 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
