Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge smells i noticed a few days ago water under my salad bins so i got my instruction booklet out which said that the drainage maybe blocked & 2 use a straw to push in the hole to clean it out which seemed to work but now ive noticed an awful smell like somethings gone off. what should i do to get rid of the odour & whats causing the smell
  • Anonymous Nov 06, 2008
    same problem water gathering under salad bins..had a engineer out 3 times and all he did was stick a coat hanger down the tube to clear it. It appears to be freezing all the time and thus blocking...is this a design fault>?
  • 95 Answers
The drain leads to a pan under the fridge that sits on coils and evaporates the condensate that drained out. you should be able to access the pan and remove it and clean. or you can just wait for it to evaporate and go away. (better off to clean) some warm water in a baster will help rinse out the line. Let me know if that worked or if you need help accessing the pan.
Posted on Oct 19, 2008
Hi our CB18M/1c/FAN keeps gathering water under the salad trays please advice thankyou
You say it runs down the channels.
Is their a drain hole at the bottom?
If the drain hole is blocked then you will need to unblock it using compressed air or a thin piece of medium flexible wire.
It should drain to a pan near the compressor and evaporaste from
there. Sometimes a loose particle of food can block the drain, usually at the back lower position of the fridge.
Jul 25, 2015 | Refrigerators
I have a zanussi ZI 920/9K and the fridge has water under the salad drawer every day but the drain hole is not blocked - what else might it be?
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Jul 05, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Mar 22, 2009 | Frigidaire PLHS39EESS Stainless Steel
Water beneath the salad bins
check the freezer section if its all frost up at the bottom part. the evaporator is freezing and transfering the coldness at the bottom part that sweats water beneath the salad bins. heater cycle is not working properly...
Feb 12, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water beneath my salad bin
if the drain is truly not blocked then the water will go down it. try poking a piece of thin wire down it to check, and have a look on the outside at the back - some models have a tray or tank where this water collects that may be full - else the fridge drain should be plumbed into a drain - check from the outside too. Also check if the fridge is truly level. The feet allow you to adjust this and see - sometimes a small change in angle can spoil the drainage characteristics of these machines (possibly even lean it backwards a little if it looks like this might help). the only other possibility is if the fridge drain is fixed into another drain, that another appliance or fixture is causing back pressure - if so you would be able to see bubbling into your fridge if you sat and watched while someone else ran all the sinks/toilets/washers/dishwashers etc around the house - in theory though when all these other items are not running then the water should still drain.
Mar 10, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
228 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
