Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Bosch Exxcel Auto option
My dishwasher isn't filling with water. The pipe is connected correctly and the mains water is on. You can hear the pump working but still no water seems to be going into the machine.
Thank you
  • ic wilson Oct 27, 2008
    originally the machine would get stuck on the cycle at 38 minutes. I cleaned the pump and filter in the bottom. This sorted this fault but it will not fill with water. I have checked for a float in the bottom ( under the lower rack) but can't see one.
  • gillr49 Nov 25, 2008
    I have the same problem can hear a click, so presume from above it is not the solenoid.
    Model no SGS3042GB/01 does any one know where the water level indicator/reader is as I have been told this may be stuck (or is this the solenoid?) How can I clean pipes out?
You will find the float s/w under the d/washer not inside,you may have a leak which has activated the float?
Posted on Oct 27, 2008
  • 95 Answers
There should be a float switch inside the dishwasher sometimes these get hung up on the full position which in turn keeps the solenoid from allowing the water to come on. remove the bottom rack and check to see if this is the case. Dislodging the float should fix the problem. If not listen to see if the solonoid Clicks when you turn the cycle to fill position if not it could be either solonoid or the timer. if you hear click and still no water check strainer in water line could be clogged or water is turned off some where.
Posted on Oct 19, 2008
SG13002GB/07 bosch dishwasher: Water isn't getting
1. Water inlet valve is faulty = replace 2. Main motor (circulation pump) faulty = replace
Jun 23, 2017 | Dishwashers
How about a malfunctioning/defective fill control valve?
Sep 07, 2012 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
The water level detector pipe could be obstructed / blocked. This thin plastic pipe is at the bottom of the washer and as it fills to the correct level of water the pressure in the pipe activates a water level switch in the washer. Sometimes the air pressure pipe becomes blocked / obstructed or the contacts of the pressure switch become burnt. You can disconnect the pipe and blow through it and the pressure switch is normally factory set and does not need adjusting. Replace it if necessary.
Mar 25, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Pipe knocking on dishwasher when taking water from cold fill
probably cold water feed pipe knocking when the solenoid opens and shuts
Jan 20, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Removing the water level sensor it is not a difficult operation, it is held with one bolt at the base of the floater arm.
The problem is that you cannot be sure that the floater is not working unless you find out that the floater is filled with water or stuck.
There is an electronic test to verify if water level switch activated by the floating sensor is working. Instructions here: Bosch dishwasher helps.
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Feb 07, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
No water is entering the Exxcel auto option dishwasher
hello there,
If there's no water entering your dishwasher, check these:
1. Water-inlet valve
2. Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
thanks for using FixYa
Jan 28, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher does not start.
remove kick plate from below the door. youll see a white tray behind the kick plate there is water in the tray activating a over flow switch. using a towel remove the water. this will solve the problem
Nov 16, 2007 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
310 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
