Question about Sharp R-340 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Dear All , I have a Sharp Microwave model R-340D . it has worked fine for about 2 years . but suddenly , It stoped to heat at all . All other functions operates pretty well , ie , the lamp is on and the motor rotates during heating . and the timer operates we during the setted heated period . However , NO HEATING occurs . There is NO buzzling sound . What do you recommend me to do . Thanks, Best Regards, Eng.Waleed Said Mohamed .
  • Anonymous Mar 22, 2014
    no heat
    President:
  • 878 Answers
Waleed, Since the microwave is going through all its motions we can feel safe that the oven and magnetron thermostats are ok. If they were bad you would not have a display. Just inside the control panel to the left, you have 3 switches which the door activates. A primary (top switch) a secondary (bottom switch) and a monitor switch (middle). If the primary or secondary switch is not closing when the door is shut, you high voltage side will not activate, therefore no heat. If the monitor switch failed or found either the primary or secondary switch closed with the door open, it would blow the main fuse and the oven would be dead. Therefore Im leaning on either the primary or secondary switch not operating correctly. When checking these switches, unplug and discharge the capacitor. This is high voltage. Good luck
Posted on Jun 17, 2006
    Problem Solver:
  • 5 Answers
Check the relay for the magnetron it is the big relay burned contacts
Posted on Oct 10, 2007
Microwave oven light on but not warming food
send me schematic diagram of microwave oven brand sharp,model R-658L(S), i couldn't find the second fuse in it. it works but not heat food, please
Oct 11, 2016 | Microwave Ovens
My dcs mo-24-Ss microwave oven cannot heat the food after turn on, everything working fine other than no microwave come out
Assuming the turntable, inside light, and internal cooling fan all work when you press "Start" to cook, then I would suspect a bad magnetron, or a bad connection at the "FA" terminal of the magnetron.
If one or more of those three items do not work when you hit "Start", the I would suspect a bad door switch or mount.
The DCS MO24SS is essentially a rebranded Sharp R-530E-series microwave with different cosmetics and a higher price.
The service manual for the Sharp model is here.
The internal Sharp parts in the manual will interchange, but not the external cosmetic parts.
You can order Sharp parts from Encompass here.
Nov 22, 2012 | DCS MO-24-SS Microwave Oven
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
SHARP R 88BKM no microwave
David
This is a sure sign that the MAGNATRON unit has went out on your oven and will need replaced! (This is what cooks the food!)
Please take a second and rate my response!
Thank You!
Jan 15, 2009 | Sharp R-1481B Microwave Oven
Sharp R-340 Microwave Oven Logo
899 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
