Splendide 2000S Vented Washer/Dryer
Problem for Splendide 2000S Vented Washer/Dryer
No heat
By karonkay on Oct 19, 2008
the machine isn't getting hot during the drying cycle so clothes aren't drying.
Same Problem
Mar 09, 2009
-   dryer works but no heat-   mmaggie308
Best Solution
posted on Oct 19, 2008
Very Helpful)
ginko
Rank: Guru  Washers & Dryers  Expert
Rating: 89%, 5364 votes
If there is no heat during drying cycle, it is usually either the heating element, or a thermal fuse.
See the following suggestions from repairclinic:
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Splendide 2000S Vented
Questions and Unsolved Problems for Splendide 2000S Vented
Do you recommend Splendide 2000S Vented Washer/Dryer?
Answer
Answer
Splendide 2000 wd802 - drum motor rotates but will not generate sufficient torque to spin load.... (More)
Answer
splendide 2000s w/d combo overheating and shutting off.
Answer
how do you install porthole diaphragm on a Splendide WD802 Machine?
Answer
About 10 days ago the washer stopped after it was full of water... I disconnected it to check... (More)
Describe your Washing Machines problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , NY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
