Question about Acer TravelMate 529ATX Notebook
Acer Travelamte 515 TE cmos battery replacement
Hello!
could you help me in knowing where the cmos battery is located inside this old Acer laptop? I'd a look on the bottom panel without success. I guess it is under the keyboard, but I would like to be sure before removing it.
Thanks a lot
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    do you have a service or user manual for this unit?
    Sergeant:
  • 306 Answers
All older laptops have the CMOS/RTC battery under the keyboard and usually not in easy access as laptop theft was an issue from day one (password reset). After the keyboard is lifted then either look to the front or rear for two little twisted wires connecting the battery to the motherboard. Some older laptops even have two. And since Acer is a less than supportive manufacturer with a perpetually busy website you might even try looking on EBay for a parts only offering that shows pictures of the motherboard.
Posted on Oct 19, 2008
Hi!
I've encountered the same problem. The solution however is rather simple.... except for the troubles in removing the keyboard...
Just on the right of the HD, there is a small 3 volts Lithium battery (not rechargeable, I guess), similar to those used in watches. The code of the battery is CR1220.
Simply replace it (it easily found in electronic shops for a few euros) and all will be ok!
I hope to be helpful!
S.
Posted on Oct 23, 2008
How do I find and replace cmos battery on Clevo M762T/Sager NP7660 laptop notebook?
Your laptop CMOS battery is CR2032 and instead of writing the instructions on how to replace the CMOS battery I am posting the link where it has been illustrated with images/pictures.
http://www.paulstravelpictures.com/Laptop-CMOS-Battery-Replacement/
I hope this helps, please let me know if you have any further questions.
Best regards,
Amar Sondhi
Nov 20, 2013 | ASUS D1 500 (ap d1500) Barebone
Computers
pic
First you need to remove the keyboard to gain access to the CMOS battery (Acer call them a RTC battery)
Tell you what give me a email address and I'll send you the service manual.
Cheers
Jan 08, 2008 | Acer Extensa 503T Notebook
BIOS
Step 1:
This might not be your laptop it might give you a guide into the cmos battery
The CMOS (Complementary Metal Oxide Semiconductor) battery saves basic settings on your computer. If the date and time function on your Acer notebook isn't working, chances are your CMOS battery needs to be replaced. Separate from your laptop's main battery, the CMOS battery is about the and shape of a coin and is located inside of your computer. Changing the battery yourself isn't the simplest task that relates to your Acer, but it isn't terribly difficult either. Here's how.
Open the notebook screen until you can easily access the keyboard. Locate the plastic bar that borders the top of the keyboard. Insert the flat head screwdriver at one end of the bar and gently pry it up until you can grip the edge with your fingers. Pry the other side of the bar up with the screwdriver and pull out the entire bar, being careful to mind the ribbon cord that connects the keyboard to the computer. Remove the two screws on either side of the keyboard that secure it to the computer. Slide the keyboard up and place it to the side. Remove the four screws on the exposed metal plate that covers the motherboard and remove it. You should now see the CMOS battery in the bottom-right-hand corner of the motherboard. Remove the battery by gently pulling it up and off the motherboard. Replace it with the same model battery (available at any computer store or online). Reassemble the computer the same way you took it apart. Acer TravelMate 6592G Keyboard Replacement Guide http://tomkaminski.com/acer-travelmate-6592g-keyboard-replacement-guide
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Apr 01, 2013 | Acer Aspire One Netbook 8.9" Notebook
How do I change the CMOS battery of a acer travelmate 4652?
On all laptops it is theoretically possible to replace the CMOS battery. To do so you need to strip the entire laptop.
However, your issue seems to be mainboard related as the unit still keep settings when on power or on battery - Thus your mainboard might be damaged, or bugged up.
CMOS battery are standard and you should get them in any electric store that sells watch batteries etc.
May 25, 2010 | Acer TravelMate 4652LMi PC Notebook
How do I replace a dead cmos on acer 4520LCi travelmate laptop? The laptop no longer keeps track of system time when shut off completely. Can you tell me the exact location of the cmos so I can be able to...
what you replace is not the CMOS, but the CMOS battery.
On an ACER from those years the CMOS battery looks like a coin, or a coin wrapped in plastic and connected to the motherboard.
On most models from same series the battery is located on the lower side of the motherboard, like on picture below:
On some model the battery may be located underneath the keyboard.
Here disassembly instructions for a similar model.
Sep 11, 2009 | Acer TravelMate 2300 Notebook
I need help how to locate the cmos battrey on acer
the cmos thats is a small part of the computer that's located at the near of the battery of your motherboard
cmos that is a jamper nearest the battery of the motherboard
Jul 04, 2009 | Acer Aspire 5335-2257 Notebook
Urgent help needed to locate cmos battery laptopasus x51r series
The cmos battery is on the motherboard and unless you are competent at disassembling laptops then I suggest you take it to a repair shop for battery replacement.
Jun 09, 2009 | Acer Aspire 3690-2196 Notebook
Travelmate 4230 battery
My laptop does the same thing - i think it is because you either have a new charger or your laptop is just getting old.
Apr 25, 2009 | Acer TravelMate 4230 Notebook
Where is the CMOS battery located on Acer Aspire 5100 laptop?
Bottom of the laptop, the big cover that comes off. Below the wlan card
Feb 18, 2009 | Acer Aspire 5100 Notebook
Acer TravelMate 529ATX Notebook Logo
580 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
