Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Model #106.55622500 Thought I'd add the model # for the above problem thank you for any input
Kenwood ud70
Without looking up the DP722, I assume it's a complete audio system minus the turntable. If that is the case, the unit would have to have a PHONO input. If it lacks such an input, but has any other high level, 300MV input, such as a CD, DVD, AUX, etc., you can purchase an audio preamp. That will raise the output level from the cartridge(the turntable) to match the above input levels, as well as have the RIAA correction necessary to properly decode the record. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Audio Players & Recorders
Do you at least send a "no solution found"?
Bruce,
There are add on boxes that can do this for you , They atart around $100- to $500
But most newer laptops may have an HDMI output that will connect to your TV. If your laptop is older it may have a 15 pin VGA out connection, some TVs have this input. So first thing is see what inputs your TV has and what outputs your laptop has. Older laptops have a composite output that will connect to almost any TV , but that would produce a low resolution picture not that great to watch.
Post the models of both the laptop and Tv for more specific advise.
Thanks
Jun 22, 2012 | Apple MacBook Mac Notebook
I have a alpine cda 9815 cd player. it has an auxillary input, am i able to add a usb port connector to it? Or what parts should i add so i can play music through usb flashdisk. thanks
there is no option to add a USB port on this model. An alternative to use a usb flash drive is to use a MP3 with the auxillary input. Cheap MP3 with works fine too.
Feb 28, 2011 | Alpine CDA-9815 CD Player
Why there is no chinese in the language bar for me to put??
To add Chinese in the language bar, please do the following:
1) Go to Control Panel->Regional and Language Options
2) Under the settings Tab, click the Add button.
3) Under the Input Language,Select the chinese language you want.
4) Click the OK button.
5) Click the OK button again.
6) Check if you can select chinese in the language bar.
I hope the above information is helpful.Thank you for using Fixya.
Feb 21, 2011 | Microsoft Windows XP Professional
Woods TW300 timer - need step by step how to use? Thought I knew but it does not shut off? thank you!
1) I don't recognize TW300 timer among any of my timer files.
Intermatic used to sell DT300 which is also Woods 59203
There is Intermatic TN300 which is also Woods 59200
There is a Woods TTM1300, TD1300, T3000, T3001, C30001
2) The same timer can be sold under many different numbers.
Open following link to identify known Woods timers. Manuals are shown for each model.
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) If your timer does not show on link above, then add a comment and describe the timer in detail, and I might recognize same/similar timer in another brand.
I have extensive files on timers.
4) Note: manuals are usually longer than space allowed for free answer.
We help the do-it-yourselfer with best answer, so if you have a problem with timer, then add what specific part of manual is not working correctly and what you have done so far.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | Woods Hardware & Accessories
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
HPProductAssistant keeps tring to install, even thought i don't want it. I checked add/remove programs and can not get rid of it? Very annoying, please help. Thank you.
Sep 9, 2008 22:35:17 GMT Unassigned Here's the fix, run it and remove the hpprodutassistant entry. It works, I struggled with this a long time.
http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
Copy entire link, paste into browser, install and run.
Jul 31, 2008 | Computers & Internet
Dvi input for watching tv
the DVI input must be HDCP compatible in order for HDMI to work. It's a DRM encryption protocol. Condolences. Blame hollywood for it. The monitor model is too old to have had HDCP support built in to the DVI input.
Jul 30, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Input source change on remote for tv
Are there not enough ports? You can buy port splitters to add more connections to your tv. Also, some surround sound receivers have port switchers too.
Apr 26, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Video Inputs for a Sharp TV Model 25EM50
video inputs for any srandard tv are rca type round yellow jack.red jack for sound,and white jack is also for sound second channel.
Jan 17, 2008 | Sharp 25R-S100 25" TV
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
571 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
