Question about NEC Computers & Internet
My nec versa 2635cd wont boot from cd - NEC Computers & Internet
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmmm..can you access the setup through F8, and reset the boot sequence to cd first?
    Scholar:
  • 59 Answers
Most computer boot sequence is set up in the bios, you can access the bios if you watch the computer start and press the appropriate key, some are f2 as it boots or escape.
then enter bios look for the boot ......and make the cd first boot option.
then save the bios most by pressing f10 to save it, the computer will reboot......
then say press any key to boot from cd.
hope that helps
Posted on Oct 19, 2008
Hi, I have NEC Versa E6300 laptop. I had set its BIOS password long back but forgot now. I want it to boot from CD and need to change the option in BIOS. Can you please suggest, how can I reset this...
Hi Prajeet
To reset your BIOS password you need to call the NEC to give you a reset code. Most Computer manufacturers like DELL, HP do have password reset tool from their end. you just need to call them to ask for a reset code but expect to answer all security questions before they gave you the reset code.
Thanks for using Fixya.
Apr 09, 2011 | NEC Versa SXi Notebook
L can't boot xp from my cd rom in nec versa 680
need to change the boot seq in BIOS....
u need to press one of the foll...
DEL, F1, Esc, key etc as the case may be...immediatly after switching on the PC....
once u r in BIOS screen look for "Boot Seq" in one of the BIOS setup screens....
change the boot seq to CD ROM as 1st boot device...and HDD to 2nd boot device...
press F10 or choose BIOS "save and exit " option....
insert the XP cd...switch off and switch on...it should now boot from CD....
all the best....pls revert back...pls give a rating and feedback for this advice....thanks
Sep 27, 2010 | NEC Versa FX Notebook
It does not boot from cd
Hi. Keep on tapping F12 key while computer is booting up. It should gives you boot options. Select the DVD Rom drive and make sure that the bootable disk is inserted to the DVD drive.
Sep 01, 2010 | NEC Versa VX Notebook
Nec versa wont boot. the battery was taken out when the screen froze. and now it wont boot fully. wont even go to safe mode or do last known good configuration
try to turn off the pc , remove the cables and/or battery (if it is laptop). Then press & hold the power button for 5 seconds then reinsert the battery and cable.
Turn on the pc , if it did not work, call the NEC tech support at 1-408-844-1100
Mar 29, 2010 | Computers & Internet
How to reformat back to windows vista ?
You need a windows Vista disc. Insert the disc and follow the prompts. I would format the hard drive instead of upgrading do a new install. The best way would be to go into your bios and make sure the boot device order has the cd-rom booting before the hard drive. Then put the disc in and start the computer, when it says press any key to boot from cd hit any key and let it load and then follow the prompts to install.
Nov 27, 2009 | NEC Versa VX Notebook
Nec versa want to downgrade from vista to xp but booting from xp cd it does not detect harddrive, why? what can I do about it?
Sometimes booting from XP disk wont detect your hard disk,the problem is because the IDE driver which is needed for the identification of the hard disks are not at all avaible with the XP CD. So u have to download the corresponding IDE driver for your hard disk and then u can install that from the floppy drive during the installation . I think on installation XP set up will ask for a driver installation (third party installation). U can do this by using a floppy disk . If the floppy drive is not all available in your laptop then u can use softwares which can mix the IDE driver along with the XP set up U have. A lot of softwares are available for download for this purpose
Thank u and please rate my solution
Oct 22, 2009 | NEC Versa FX Notebook
Laptop does not boot up when you press the power on button. I have not used this computer for a number of years and I'm sure that the battery is dead. Do you need the battery to run on AC? The cmos cl
Here is what i can say:
no you do not need a battery to run ac
you do not need a cmos battery to bot
Does the light stay on?
if so find a way to check if the screenis working.the connectors may be disconnected.
try useing an external monitor
Apr 15, 2009 | Computers & Internet
NEC Versa S970 is telling us that it cant find the boot system. Notebook not working
you should try when it starts to boot if it says any F1's or anything like that
Oct 27, 2008 | Computers & Internet
Nec versa sx dvd upgrade
just check the jumper settings.one drive should be master and one should be slave.if you have two empty ide slots then you can put one on each.
Mar 26, 2008 | NEC Versa SX Notebook
Computers & Internet Logo
144 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
