Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer need to be repaired
My washer won't wash, or spin f2 is flashing. but it comes on makes a sound like it wants to go .
  • 62 Answers
The f2 code is a pump problem. Need to look in pump. It is the first cycle to be satisfied when started.
Posted on Oct 20, 2008
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Washer got very loud during spin cycle this continued and then when its spins it sound like the tub is grinding against something and also squeeling noise during washing.. and spinning.
HI,
This sounds like a leak under the unit and above the motor. I would suggest tipping the unit back, look unit the washer for milking brown residue on the cabinet and the motor area. If present you will need a new outer tub and this won't repair will not be cheap. I am sure this answer is not what you want to hear. If no residue, I would look into the pumps as you can have a foreign objects inside them and cause a-lot of noise during operation. But the only way to make sure if to look.
Hope for the best...
Jul 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an HE 3 front loading washer and I am having problems with
Hi
Thanks for using FixYa. F2 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F2" is flashed. Press PAUSE/CANCEL twice to clear the display. Also, check the drain hose and make sure it is not plugged or kinked. Then check the electrical connections at the pump and make sure the pump is running. If still the issue is not resolved then replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Kenmore Elite 45986 Front Load Washer
GE/Whirlpool Duet electric dryer squeals badly... what is it and how do I fix it?
A common problem with noises from washing machines and dryers has been the under wire that may come out of a bra. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! In dryers, they can get caught in one of the drum seals and make a scrapping noise, (remove power, grab a flash light and have a peek inside through the door opening) or the wire can actually pass through one of the heating duct holes at the back of the drum and touch something electrical like the heating element, thermostats. If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Mar 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Will not drain and displays code F2. Makes a
ck your pump.take off your access panel get a bucket and unscrew your pump.might just need cleaned out if not then pump bad
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 error
f2 means the unit is draining to slow...you need to clean your pump filter...if you need help with that post to onthejob
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
171 people viewed this question
Dan Webster
Dan Webster
Sal De
