Question about HP Office Equipment & Supplies
Multiple paper feed with 5L - HP Office Equipment & Supplies
  • 138 Answers
You need a separation pad kit for your machine. The parts are relatively inexpensive. There are 2 ways to accomplish the fix. You can install a separation pad overlay kit which can be done without disassembly which is simply adding a peice of rubber over the existing pad or a complete roller & pad kit which requires disassembly of the machine. The easiest is the overlay however best and longest fix is the full kit replacement. Here's a link to each of the kits off of ebay.
Overlay Kit: (5 minute install) Approx. $10.00
Full Feed Replacement Kit: (30 minute disassembly required) Approx. $25.00
Here's a link to a fre service manual for the machine just in case you get into difficulties:,%206L,%206L%20Gold,%206L%20Pro%20Service%20Manual.pdf
Hope that helps you. If so please rate me with a FIXYA!
Posted on Oct 19, 2008
Paper wont feed
there are multiple reasons that paper won't feed into a printer. the pickup roller may be worn and doesn't grip onto the paper, or the printer tray may not be lifting the paper to the pickup roller.
Feb 23, 2013 | Canon Office Equipment & Supplies
Feed tray pulling multiple pages
prior to the issue ,it can be the sign of wear and tear of the feeder seperation pad .may i know is the fax heavily utilise.if yes get the part to change ,if no try to change your paper or frequently fan the paper it can be highly moisture present on paperand try to minimise using reuse paper it may shorten your machine lifespan.good luck thanks pls rate me!!!!
Aug 27, 2009 | Canon LaserClass 2050 Plain Paper Fax
Canon faxphone L80 parts available? paper feed shaft broke in half
The L80 printer guts are very similar to the HP 5L and HP 6L printer (Not well known, but the printing engines on many HP printers are made by Canon). In fact it is almost possible to use a 5L/6L toner cartridge in the L80, but as I recall there was a plastic nub that prevented it from fitting properly. This is probably meant to force the user to buy more expensive Canon toner carts instead of using cheaper generics for the 5L/6L. Try HP PartSurfer and you may be able to locate the part that you need.
Jul 29, 2009 | Canon FAXPHONE L80 Laser
HP 5L printer Paper advance
Parts are no longer available. You might be able to clean the feed roller by removing the toner cartridge and cleaning the gray roller with isoprpyl alcohone.
Jan 04, 2009 | HP LaserJet 5L Printer
Paper feed
Have you tried a different brand of paper?. When choosing the paper try and select one which the sheets can slide easily over each other. I had loads of problems with multiple feeds and paper jams with a cheap paper. I then changed to a heavier 90gsm all in one paper from staples and have had no more problems since.(and i just chuck the paper in straight from the packet with no fanning etc)
Dec 15, 2008 | HP OfficeJet Pro k550 Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP Laserjet 5L feeds multiple pages through at a time
It prob. needs an overhaul/reconditioning/cleaning to soften up or replace the rollers and rubber pads in the paper path. I imagine it needs this about every 5-6 years. Don't know if new parts are still available for this great old machine, but it's worth trying to keep it alive, at least until you change computers and don't have a parallel output port anymore ;^).
Jul 26, 2008 | HP LaserJet 5L Printer
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
REQ:HP LaserJet 5L Repair Manual
well..those are only usually available to the HP certified field folk...
May 11, 2008 | HP LaserJet 5L Printer
Permanent alert of paper jam after cleaning a printer HP 5L
The paper path/paper guide may need replacement. I would also get a maintenance kit and replace all the rollers.
Jan 29, 2007 | HP LaserJet 5L Printer
289 people viewed this question
Ben Johnson
