Question about Gateway Computers & Internet
All of the sudden alot of red dotted verticle lines appeared on my screen and are on there constantly. Any idea what caused this or how to remove them?
  • 3,940 Answers
Most likely if the line appear in all screens you have a hardware issue. Reseat the monitor connection, see if anything changes. If not, try monitor on another system or another monitor on this system, see if the problem follows the monitor or the system.
If the issue stays with the system, then you will likely need a new video card. If you have Intel Integrated video, try different RAM. If RAM makes no difference, a motherboard or an expansion video card will be needed to resolve.
Posted on Oct 19, 2008
TV suddenly has pinkish red vertical dotted lines running down it that comes and goes randomly.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 16, 2015 | Televison & Video
Verticle line on iPhone 5 screen at bottom
you must replace the lcd screen
May 31, 2014 | Apple iPhone 5
The camera screen whether in stand by mode or record mode has vertical bars and dots all over the screen. The dots and bars constantly flashes and the vedio recorded sample also bear the same disturba
I hate to say this, but you better look out or a new camera.
If it is a new camera, with warranty, just bring it back, but I think repairing this one will cost much more than it is worth.
Dec 29, 2013 | Cameras
I have a samsung LCD TV that is now having colored dots and verticle lines on it. It also will have red dots and dasheds that with be on anything that is dark colored. What could cause this
Hello:
This may be due to a faulty T-Con board that needs replacing, this board is the display driver and will cause all type of symptoms when it is going bad.
Jul 08, 2011 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
I have a Dell computer with a flat screen now all of a sudden there are fine pink verticle lines along the right side of the screen. There is also a group of fine pink verticle lines about 1.5 inches wide...
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer.let me know if this resolves ur issue.. if not then we need some other steps.. regards,guru
May 05, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
TV Screen has verticle lines with a message
Place the red line actualy the reds fine cause the blue is behind it but the bla k could maybe use some stars in it ya know my ninjas and maybe fade with the colors just to keep addin to it bits at a time but yeah post me a solution lol
Aug 05, 2009 | Philips Televison & Video
What can cause a single red line to appear on my laptop LCD screen? It's a small/fine red line appear horizontally (left to right) It's NOT radio interference,back light,broken ribbon cable,or connector...
Thats a generic problem with LCD screens. Its more common in Mobile screens. Sorry, no there is no fix to it other than replacing the LCD itself. Just pray that it shall not grow because as and when the compressed gas from within the LCD will leak the line will be becoming broader and broader. It is caused by damage to the LCD corner Just a hit on side of LCD and a hairline crack for giving way to the encapsulated gas.
Jul 28, 2009 | Computers & Internet
Screen on my extensa 5630 laptop shows nothing but verticle lines
I had to finally send the machine to ACER and it was a hardware problem; they have to change the cable linking the display with the MB
Mar 22, 2009 | Acer Extensa 5630-6806 Notebook
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Verticle lines
I am woundering if the repair folks did the proper job and used the right IC's as alot of NON authorized shops will use the cheap aftermarket repalcement ICs and not even use any new heat sink compound. 4 repairs in 5 years is very excessive! I would not have called the same shop(s) to do the repairs. Put on the test scren on the TV set and see if the convergence is off. If it is make the shop replace them again for free or ask for your money back. Man what a rippoff that is. Good Luck and keep us informed of your progress with the shop and the repair.
Mar 26, 2007 | JVC AV-48WP30 48" Rear Projection...
Computers & Internet Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
