Question about Stoves Ovens
Stoves 900EF Cooker
The grill element in the top oven has ceased to function.
I would suggest that it simply needs a new one, but what I am concerned about is that when you use the knob to turn the grill on, the light on the dial does not come on, whereas they do when you switch on either of the ovens.
This suggests to me that it is more an electrical problem, rather than the element itself.
Any thoughts on this are much appreciated.
Many thanks.
David Brunton
barkencoa
  • 3463 Answers
SOURCE: how can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
  • 18 Answers
SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Posted on Jan 23, 2009
protek480
  • 1723 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
  • 4102 Answers
SOURCE: Smoke comes out of grill on electric cooker
hi, what you will probably find is that the grill over time has got grease on it and other contaminents from food you have cooked in the past the best thing to do is turn the grill on full and let the smoke burn out open windows etc as it will stink the whole place out it may take a while to get hot but just wait leave it on full and you should find it will burn off all the grease etc and then it will stop smoking.
If you turn it on full and then you get nothing happen after about 10min then turn it off and you would then need to think about getting the element replaced.
Let me know how you get on or if you need further assistance ok
Posted on Nov 10, 2009
  • 250 Answers
SOURCE: Stoves 720 EF Electric Double Oven Model No
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Posted on Nov 27, 2010
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How to replace the grill element in a Stoves 720EF double oven?
1) Isolate the unit by turning the power off at the main switch.
2) Remove appliance from housing unit.
a) When handling the appliance care should be taken to ensure the outer frame trim is not damaged.
b) The appliance is secured into the housing unit by 2 screws through the top corners of the front frame, open the doors and unscrew the 2 corner screws.
c) Grasp the bottom of the frame, pull forward and out onto a suitable surface.
3) Unscrew the top and rear panel securing screws and lift the panels clear.
4) From the rear of the appliance, pull off the 4 (top) grill element leads and the earth lead.
5) From inside the oven unscrew the 2 screws from the grill mounting plate.
The above is from the Handbook. I assume from point 5 the element is then free to be removed. reverse the procedure to fit the new element.
If you want a copy of the Handbook, then I will need an email address for you.
Mar 11, 2010 | Stoves 720EF Electric Double Oven
Sep 03, 2009 | Ovens
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
67 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
