Question about D-Link AirPlus DI-524 Wireless Router
D-link DI-524 wireless - lan network connection
I have that d-link router. a laptop with vista is connected via wireless and a desktop with XP via lan.
I want to share files between the two
  • 1 more comment
  • cexr00t Oct 19, 2008
    i did that , the two just won't see eachother ...
    it was the antivirus "protection" .
    thanks guys.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    just set up a home network with same name, and open the folders with sharing options at the disk level..
  • 2,460 Answers
Yep. Vista sucks :-)
In the vista machine, you have to turn on a whole bunch of options. Right click Network, hilghlight properties and left click and it opens up Network and Sharing Center. Down at the bottom, you have a list of options. Start by turning on the options you need: File Sharing, Public File sharing, Printer Sharing etc. I'm pretty sure it's already done in the XP machine, but if not, check there too.
It should start to show network files between machines.
Carl
Posted on Oct 19, 2008
  • Carl Navarro
    Carl Navarro Oct 19, 2008
    Oops, a couple of other things to remember. When you log into your home network with your laptop, tell the system that you're at home. When you log into any other network, remember that PUBLIC is your friend. It locks down access to your files that you just opened up for your home network.
    Carl
2 Suggested Answers
  • 96 Answers
SOURCE: Unable to access my Laptop on My Network from my
To enable file sharing you need to follow the below steps
I moved this to networking for better exposure. I'll give you some basic tips, but it's generally pretty simple.
Turn off any firewalls for debugging. If the firewall is the problem, you'll have to configure it to allow access to "trusted zone" addresses. Note that some firewalls must be completely uninstalled to stop them from affecting your networking.
PING each computer by IP address, and if successful, PING by name. You can obtain the IP address of a computer by opening a command prompt (DOS window) and typing IPCONFIG. This should work for any Windows version.
All computers should be in the same workgroup for computer browsing to function properly. File & Print Sharing has to be enabled on any computer you wish to share files or printers from. You also need to actually share the resource in question from My Computer, right click on the drive/printer/folder, and select sharing.
If you encounter difficulties accessing computers that are visible in Network Neighborhood, make sure the computer being accessed has an account with the same name/password as the system connecting to it uses to login.
While the default NetBIOS setting is correct for normal network configurations, it's possible for it to be altered, and it costs nothing to make sure it's correct. NETBIOS over TCP/IP must be enabled for normal network browsing.
Let me know if this will help
Posted on Nov 27, 2009
No wireless connection
Dont enter the Router IP as WWW.192.168.0.1, Instead just type 192.168.0.1 and it should let you access the Router EWS Page. you are trying to access Internal network ( which we can call local network or LAN ) so do not use WWW.
In the Address bar of Internet Explorer, just type the IP Address.
Jun 24, 2010 | D-Link AirPlus DI-524 Wireless Router
DI-524 router printer sharing
All you have to do is that you will have to setup your Hp to share or to be seen by other machine on the network by going to the network properties then setting the network, file and folder on your hp to be seen and shared by other machine.
Sep 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Hi, I have a toshiba windows XP laptop which stopped connecting to wireless network(WEP) .But it connects to network through LAN with ethernet cable .Laptop wireless finds my network but does not connect(...
Check your security settings would be a good start. Have you checked to see if XP uses WEP to authenticate? (it should do this automatically but sometimes it doesn't)
Sep 11, 2009 | D-Link AirPlus DI-524 Wireless Router
I have a D-Link AirPlus DI-524 Wireless Router. I have no problem connecting the computers in my home that have windows XP installed. We have replaced two of the computers in the house with laptops that...
I have had exactly this problem and after MUCH work downloading new drivers for the Vista Pcs and updating the operating system in the DI-524 found that the 524 does not operate well with Vista. A new DI-624 integrated well with Vista, and installed with no problems. Good luck!
Feb 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect DI-524 to VISTA
There is nothing on DI-524 what is Vista specific. Make sure you installed your dirivers properly. I have the same , works without problems.
Jan 22, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524
make sure you have the wireless lan activated(software/hardware) and also configure your router's wireless setting(connecting thelaptop to the router by ethernet cable).write the wireless configuration down and configure your laptop with the same SSID and WEP key.it shud connect and you shud able to be good to goo..don'tforget to configure your DSL to therouter.post your router/modem/ISP details for further help
Feb 02, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
380 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
