Question about Naxa Electronics Naxa NX-572 7" TFT LCD Color Television Television
Remote control no longer working. Tried changing batteries several times. does not correct problem.
Have a naxa 13in. tv/dvd need codes for remote.
Posted on Jul 06, 2009
  • Gary Haley
    Gary Haley Dec 25, 2010
    i lost my remote and have tried 3 universal remotes. Whe they search for codes the channel up and down turns off tv. It should not be this difficult to get a remote to work
  • 55 Answers
Try fixing it yourself
Here is my blog how to do it:
http://www.instructables.com/id/Repair-your-remote-controls/
Posted on Nov 17, 2008
  • 513 Answers
Remote controls like dropping to the floor. Is it possible it was dropped hard enough to knock the sense out of it? something might be cracked inside or loose, and now power won't be transffered from the batteries, or into the infra red. Take it to a repair shop if it's worth it. Good luck
Posted on Jun 19, 2006
Remote not working
If you recently changed batteries, remove the batteries and make absolutely sure that they are connected properly. The + and - ends of the batteries must be correct. This is the #1 reason remotes stop working.
I am an Electronics Engineering Technician and have, through inattention, put one or more batteries in backwards. And I was SURE I put them in correctly. :>)
The second most common failure is that the remote has been dropped so many times that the battery contacts no longer make firm contact with the batteries. You can usually gently bend them outward to fix this.
Another common problem is the Infrared LED in the remote fails. Only a Tech can fix this.
Mar 24, 2013 | LG Televison & Video
Problem With Operating the Remote
Check to see that the batteries are installed correct,,may need to reprogram...hope this was helpful...
Apr 23, 2010 | Philips SRU3003 Remote Control
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Control Pad on Wii remote fails to work
Problem fix was simple-plastic cover over unit was blocking lens of the unit. Readjusted so it didn't block and now works fine.
Dec 25, 2009 | Nintendo Wii Console
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Remote control no longer works
an original remotes available for ya at http://www.remotes.com for 30 bucks + shipping
Apr 23, 2006 | Sylvania 6319CC 19 in. TV/VCR Combo
Naxa Electronics Naxa NX-572 7" TFT LCD Color Television Television Logo
352 people viewed this question
Top Naxa Electronics Televison & Video Experts
Paul Gustar
Dung Maurice
Dung Maurice
Level 1 Expert
Are you a Naxa Electronics Televison and Video Expert? Answer questions, earn points and help others
