Question about Sport & Outdoor - Others
Suzuki ds 80
I need a kick starter, but i cant find one anywhere!!!!!!!!!!
    Problem Solver:
  • 6 Answers
Kick Starters on 80CC machines are almost universal. You can look for a Honda or Yamaha and they should fit just make sure that the fitting is the same. Try to expand your search for Suzuki kickstart. good luck
Posted on Oct 22, 2008
What do the VIN numbers and letters mean on a Suzuki DS 80?
Hi, Tommy for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
My Suzuki Pages FAQ identification
VIN Decoder Motorcycle Identification Cyclepedia
1981 1982 1983 1984 1985 1986 1987 1988 1989 1990 1991 1992 1993 1994 1995... Service Manual $10 cheap
OEM parts for Suzuki
Aug 21, 2017 | Suzuki Motorcycles
My 1995 250 suzuki quadrunner starts with pullcord but won't electric start it rolls over but won't kick in
weak battery? starter might suck so much juice it cant make a good spark?
Jul 05, 2017 | ATVs
I cant move the kick starter
You need to open the side cover on the kick starter side. Check if the spring that returns the kick starter ha snot came out of his position. There is a hole in the casing that it must hook into, that hole sometimes crack or break open then the spring locks in between the gears. I had mine welded up and I drilled and tapped the hole, bent the spring side ways and bolted it down, it has not came loose yet. If the spring is still in its position, remove the clutch plates and see if the engine has not seized up.
Feb 24, 2014 | Suzuki RM 125 Motorcycles
My suzuki raider 125 model 2010 won't start even in kick starter
check if a spark is coming when you turn the engine and continue from there, if yes then fuel is not getting in the engine. If no start by changing the spark plug and move from there.
Jan 15, 2014 | Suzuki Motorcycles
My daughters 2001 suzuki jr-80 was running fine, but the shifter jammed in gear, not sure what gear it's in but it will run. it was not crashed or even layed over at the time the problem originated....
The bike probably has a bent shift fork. The only other possibility is a shift index wheel assembly has become loose or the spring has broken. Pray for the index wheel problem. That you may be able to fix yourself. The right side case comes off, then the clutch and kick starter. Now the index wheel assembly is accessibletombones49_193.gif. If it is a shift fork, I don't recommend the repair for the home mechanic. Some special tools are needed. The entire engine must be torn down to get to the forks. Please rate my answer. Thanks!
Jun 22, 2011 | Suzuki Katana 600 Motorcycles
Does a 1999 suzuki ds 80 have a low oil safty shut off
No I dont believe so at the best is may have a low oil light
Apr 26, 2010 | 2000 Suzuki GS 500 E
How much oil goes in a 1979 suzuki DS 185 ?
700cc 1.48/1.24 US/Imp pint of good quality 20w/40
Hope this helps (if so please mark as helpful !!)
Ride safe
Apr 21, 2010 | 1981 Suzuki TS 185
Suzuki rm 80 fuel/oil mixture ratio, cant get hold of a manual anywhere!! Think its a 1988/1989 thaanks
Use good two stroke oil and re-jet if your spark plug color is to white or black. Should be around a chocolate color.
Oct 29, 2009 | 2003 Suzuki RM 125
You may use another brand of relay (say Bosch) then let your electrician make a retrofit to match the connection of the original . Make sure that the current (amps) rating is the same or a little bit higher than the original. If you can't get a unit with higher current rating, use 2 or 3 and connect it in parallel.
Apr 17, 2009 | Suzuki Sidekick Cars & Trucks
Sport & Outdoor - Others Logo
389 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
