Question about Samsung V20 XVC 2400 Notebook
Easynote r1004 d.c. input socket broken
The d.c. input socket centre connection pin has broken off. want to either replace socket or bypass it and solder leads to circuit board. How do i get the back casing off to access the area?
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmm..not something I would recommend, frankly..
    Sergeant:
  • 306 Answers
You really have to completely remove the motherboard from the case to do this. If you cannot find the exact replacement jack (not called socket in parts catalogues) you can just run the wires out of the case to whatever jack that will accomodate your adaptor. If you do not have the remove/replace procedures and still want to tackle this then make sure that you keep track of where EACH screw goes as they do vary in size/threads and pay careful attention to the ribbon connectors that connect to the keyboard, display and touchpad. The bottom of the laptop has little icons that relate to what the screw releases (like a keyboard icon) and even the screw designations molded into the bottom case. If this is a maiden voyage into laptop repair then research or you will learn the hard way. An ESD strap is essential here and all drives/battery/PC modules removed. Good luck. ~Steve
Posted on Oct 19, 2008
Philips powervision tv my tv tuner pin is broken
You're discussing about the input socket [Ariel socket] to your TV is broken; I assume, and posts this solution. In most cases, this is a irreparable fault; because, this socket is directly connected to the tuner, and is a part of tuner body [case]. If it is broken, the the tuner should be replaced with an identical one. You should check out the number of the tuner used with your TV; can be noted on it by a sticker. Just buy that number tuner, and replace it. The tuner can be bought from most of the electronic spare part selling shops.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Apr 17, 2014 | Televison & Video
The screen on my lap top has had 3 very thin lines across the screen but if you tilt it they go now sometimes they screen fades away and i have to move the screen again this is getting worse could it be...
I'm a laptop repair technician, and in my experience the very thin horizontal or vertical lines are usually caused by malfunction in the display panel and the entire screen has to be replaced. If might be worth a shot for you to try and reseat the LCD cable though, but I doubt that it will work.
Sep 23, 2011 | Packard Bell EASYNOTE R1004 COMPATIBLE...
Will not charge easynote R1004 packard bell ac adapter ok
How long have you had it? Laptop battery life deteriorates greatly over time, and they generally need to be replaced after a year or two.
Nov 07, 2009 | HP Pavilion dv6000z Notebook
I'm trying to locate a packard bell easynote R1004 rhea-c disassembly guide so that I can replace the keyboard.
the plastic containing the power switch slides to the left and comes out.
Three screws undeneath and your done....
http://www.user-guides.co.uk/PackardBell/PackardBellCDDownloads.asp
link covers PackardBll Drivers CD ISO Downloads PackardBell User Guide CD PDF Downloads PackardBell Service Manual CD PDF Downloads PackardBell Boot Disk CD ISO Downloads PackardBell Recovery CD ISO Downloads PackardBell Restore Disk ISO Downloads PackardBell Diagnostics Bootable CD ISO Downloads
Nov 05, 2009 | Computers & Internet
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
The little green light on charger goes off when i plug it into Dell Inspiron 6400, the charger works fine
Unplug the battery from the laptop and then plug the AC adaptor into the laptop. If the green light still goes off then your motherboard is shorting out the adaptor and the motherboard needs to be replaced.
May 17, 2009 | Dell Inspiron 6400 Notebook
Broken socket for charger - Esprimo mobile V5515
you have to prise the keyboard out, then prise off the strip of plastic at the top. It's not a nice thing to have to do...
I had the same problem with the charger socket :(
Mar 29, 2009 | Fujitsu Siemens Computers & Internet
How do I get into my Easynote R4650 to change power input socket
hi,
check if ur input socket is moving , i mean a bit loose. if so then u got problem with ur DC power jack of ur Laptop. u have to get it fixed. if it seems fine then there should be problem with ur power cable of ur adapter. get it checked for short circuit.
cheers :)
Oct 22, 2008 | Computers & Internet
Dell P1500 Laser Printer: USB Port is Broken--plastic center peg broken off
If you mean the centre pin from the plug has broken off in the socket then use a tooth pick, dab a tiny bit of cyanoacrylate, (super glue) on one tip and push against the broken pin keeping steady for at least 20 seconds. Now, gently pull the pin out.
If the socket is broken, new board or repair shop.
May 19, 2017 | Office Equipment & Supplies
Samsung V20 XVC 2400 Notebook Logo
254 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
