Safe mode access
How to boot xp in safe mode...
  • 67 Answers
Pres f8 as it is booting up. then select safe mode.
please rate this!
Posted on Oct 19, 2008
    Scholar:
  • 85 Answers
Reboot pc and press F8 key 4-5 time a boot menu appear...select safe mode n press enter
Safe mode on a computer
When you start the PC, as soon as it hums up start hitting F8 button. The black window with a bunch of safe mode options will show up, select the one you need.
Aug 27, 2014 | Microsoft Windows XP Home Edition
Cannot get on line in safe mode
safe mode is normally used to troubleshoot problems especially software and drivers. where you use this the computer boots up with minimum software running so you can fix problems. I am sure the modem or network drivers are not loaded and ect.
Jul 12, 2011 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Windows XP SP3 New Garmin nuvi 1200 registered with Garmin. Dowloaded software update with no problems. Dowloaded map data file. When run it stops with error message that I do not have sufficient...
Ok there are two things you can try here the first this is you can right click on the application and run as administrator should be an option that should get you around that problem. Now to run the updater in safe mode to try and fix your problem should also be an easy fix. When you start up your computer and you get to the section ware it asks you how you would like to boot one option should be to boot in safe more with networking this will allow you to access your systems in safe mode and the internet by loading all needed drivers and processes for networking allowing you to access the internet.
I hope this helps.
Thank you,
Norse
Jul 03, 2010 | Microsoft Windows XP Home Edition
How do I get into safe mode on HP mini 1000? XP OS
To get into safe mode on any computer running Windows you press F8 before or right after the Windows splash screen comes up. You will have three options for safe mode:
Safe Mode: Only the absolutely necessary drivers load.
Safe Mode with Networking: Same as above plus the ability to use the internet/network access
Safe Mode with Command Prompt: Boots into safe mode with a Command Prompt for command line work.
Hope this helps.
Jesse
Jan 08, 2010 | HP Computers & Internet
Safe mode button for toshiba satellite windows xp a45
Press and hold F8 while booting up to access Safe Mode functions which include Safe Mode with Command Prompt and Safe Mode with Networking. Hope this answers your question. Best of luck!
Greg
Nov 05, 2009 | Toshiba Satellite A45-S250 Notebook
Re-installed XP Pro + SP2 + SP3 - but have black screen
reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
Sep 23, 2009 | Dell Latitude D600 Notebook
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Safe mode
You can also force the system into safe mode. You click on startup and type in msconfig. Click the general tab and select diags and the system will reboot to safe mode. Change it back to normal to get your system out of safe mode.
Please rate my response.
Feb 17, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
272 people viewed this question
David Payne
David Payne
