Question about Garmin zumo 550 GPS Receiver
Zumo Wull not charge form bike mount
Hi My zumo 500 will not charge on the bike mount. It has power to the terminals but dies not get through to the unit.
  • armeav8r Apr 28, 2009
    That's incorrect. It is supposed to charge anytime it is connected to a powered source and that includes the vehicle mount or motorcycle mount if plugged in. The motorcycle mount fails electronically and must be replaced. I'm on my second unit.
    Problem Solver:
  • 18 Answers
Gfjohn, You are incorrect. It does indeed charge via the car and the bike cradle.
The problem you have is that your connectors at the base of the unit have fried and the entire connector block needs to be changed.
My unit was replaced after only 7 months. 6 weeks later and unit #2 has just died on me. Refuses to power up. Back to Garmin once again.
Posted on Jul 08, 2009
Experience the same problem with my Zumo 550. Told by service advisor @ Radio World that this is a common problem. Unit needs to be charged on the DC charger occasionally. The motorcycle mount and car mounts, I was told, does not charge the battery on these units, but maintains a charged battery.
Posted on Oct 20, 2008
Have just had the same problem. The unit stopped while on holiday, just when I needed it most. When back home I decided to dismantel the support as it unit worked in the car. I found the ribbon connector had shorted and the copper had gone completely. After inverting it I plugged it back in and bingo, it works. Will not be leaving the support on the bike when I don't need it.
Posted on Aug 11, 2009
I unplugged cable to computer during first update This is a garmin zumo 340
Try doing a Hard Reset
  • hard reset zumo 340 en 350 - YouTube www.youtube.com/watch?v=tWUDsiXu9QI
    • BY MRGPSNL
    • 6 MIN
    • 10K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer ... hard reset zumo 340 en 350 ... Garmin Zumo ...
  • zumo 340LM ' Garmin buy.garmin.com > Shop > Automotive > Motorcycles Garmin Connect lets you search, plan and share your rides. Get Started /en-GB/GB/accessoriesAndMapsUrls/010-01043-06.ep. Customer Service. Product Support;
  • Hard reset Garmin Zumo 220, 550, 660 - YouTube www.youtube.com/watch?v=g9h9QtWWedk
    • BY MRGPSNL
    • 4 MIN
    • 25K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer 'als nieuw ... Hard reset Garmin Zumo ...
  • Garmin zumo 660 665: How to Reset Video - GPS City www.gpscity.ca/videos/play/Q0td7d4BH9A How-to video for the Garmin zumo 660 665: How to Reset Video explaining its functions and installation.
  • http://www.bing.com/search?q=garmin+zumo+340+reset&qs=n&form=QBRE&pq=garmin+zumo+340+reset&sc=0-21&sp=-1&sk=&cvid=3C4EE77095704DEC935AD44372BE0B4D
    May 11, 2016 | GPS
    HI I have Zumo 550 when I first switch it it comes up with can't maps press OK you press OK then starts to work but starts at 1am on the clock and in night time mode after awhile it goes to the right time...
    If your zumo 400 or 500 series will not power on, or performs strangely after powering up, follow the steps (described on the Garmin website) below to perform a soft reset:
    1. Connect the zumo to a power source such as a computer or AC outlet
    2. Hold the zoom (+) and ON buttons at the same time for five seconds
    3. If this does not restore power, remove the battery for five seconds
    4. Place the battery back in the zumo
    The zumo will now power on. Because the battery may deplete while the zumo is locked up, it is ideal to leave the zumo connected to power to allow it time to charge.
    Once the battery has charged, follow the steps on the Garmin site to update the operating software in the zumo. (just copy this link to get there https://buy.garmin.com/support/searchSupport/case.faces?caseId={8576ba20-e948-11dc-d6fc-000000000000} )
    Good luck,
    Michael
    Feb 01, 2011 | Garmin zumo 550 GPS Receiver
    Garmin 550t. When i have my zumo on my motorcycle mount it seems not to take power from the bike & then after a while it tells me "low battery", it is wired directly to the bike battery so it should...
    Moisture has probably gotten inside the motorcylce cradle through the connector pins. if you take it apart, there is a very small ribbon cable that attaches from the pins to the cicuit board. if moisture gets on the end of the ribbon cable it can short out the small power tracers on the cable and cuircuit board. this happened to me. i had to buy a new cradle. 85.00
    May 16, 2010 | Garmin zumo 550 GPS Receiver
    GPS is not getting power on the motorcyclen mount.
    If you're sure the power cord is getting power, then the mount has likely failed. Mine has failed 3 times. Replacing the mount will fix the problem as it did on mine. If the unit is less than 1 year from purchase, Garmin will warranty replace it for free. If not, it'll cost you about $85 plus shipping to put a new one on.
    May 09, 2009 | Garmin zumo 550 GPS Receiver
    ZUMO CHARGING STATUS
    I have had Zumo 550 for 2 years now, and it does exactly the same.
    I think it is just the way the unit is, and is not a fault.
    Feb 14, 2009 | Garmin zumo 550 GPS Receiver
    Zumo not accepting a 12v charge
    Mike,
    My friend had the same issue as you mention. Puts his Zumo 550 on his bike only to have it discharge in a few hours. He later found out the pins on his motorcycle cradle had corroded and therefore was not keeping the Zumo charged. His solution was to purchase a new motorcycle cradle at about $100.00 CDN.
    Oct 20, 2008 | Garmin zumo 550 GPS Receiver
    Zumo 400
    You mean helmet speakers? If you use the bike mount it should work, the car mount is a line out(not amplified so the sound is very poor) I had a wired helmet set, worked okay below 50 KMh
    Jun 16, 2008 | Garmin zumo 550 GPS Receiver
    My garmin zumo will not turn on.
    Have you also held the power on button for a couple of minutes, with the battery installed, and without the battery installed. There is an issue with the garmin dying, some cases a new battery helps, other cases, just leave the battery to charge for several hours, worst case is that you have to ship it to Garmin. I had a couple of Dead Zumo, however, removing the battery for several minutes, putting it back and clipping the zumo in the car holder did the trick for me. I also have a spare battery and allen wrench, just in case...
    May 26, 2008 | Garmin zumo 550 GPS Receiver
    No power
    I had exactly the same problem with a 3 month old Zumo 550. Removed battery, waited a few minutes and replaced. System now poers on OK. All data on-board was retained.
    Dec 22, 2007 | Garmin zumo 550 GPS Receiver
    Unit won't draw power from the bike battery
    Ay I just fixed my Zumo 550, that would constantly go into battery power when hook up to my Motorcycle, found the enemy I was fighting was lack of proper ground (-).
    Aug 20, 2007 | Garmin zumo 550 GPS Receiver
    Garmin zumo 550 GPS Receiver Logo
    794 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
