Virtual Memory error
Some programm show err low virtual memory err how to get rid off
    Scholar:
  • 85 Answers
Dear
Right click on My Computer icon .. go to Properties->Advanced->Setting->advanced->Change..
THan Select Drive go to Custum Size Fill Minimum an Meximum virtual ram size remember u fill double ammount to ur actual ram size like 512-1024
Click Set ok  and restat ur pc
Posted on Oct 19, 2008
Error message Low on virtual memory
Virtual Memory is used by the operating system as an extension to the Random Access Memory (RAM). When the RAM does not have enough space to accommodate the entire running program, the inactive parts of that program are temporarily shifted to the Virtual Memory. These parts are then swapped back into the RAM as and when needed. If the Virtual Memory set on your system is not enough for the computer operations to run smoothly, then you will get the "Virtual Memory Is Too Low" error message.If operating system is xp then this problem can be easily overcome by increasing the Virtual Memory size.This is how you can do it by following instrutions:
  1. Click on "Start" and then click on "Control Panel.
  2. Double-click on the "System" icon in the Control Panel.
  3. Click on the "Advanced" tab in the System Properties dialog box.
  4. Click on the "Settings" button below Performance.
  5. Click on the "Advanced" tab in the Performance Options dialog box.
  6. Click on the "Change" button below Virtual memory.
  7. Click on a drive_letter below "Drive [Volume Label]" in the Virtual Memory dialog box.
  8. Click on the "Custom size" option.
  9. Click in the "Initial size (MB)" text box and type a larger value (for example, 600).
  10. Click in the "Maximum size (MB)" text box, and type a larger value (for example, 1500).
  11. Click on the "Set" button. Similarly change the Virtual Memory on other drives.
  12. Click on "OK" and then restart your computer.
Apr 07, 2010 | Microsoft Windows XP Professional SP2
Tip
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
Tip
Virtual memory Information.
Tutorial Objective
This tutorial talks about anything about the virtual memory and how much virtual memory you need for your system.
Tutorial Introduction & Background
Today application is getting bigger and bigger. Therefore, it requires a bigger system memory in order for the system to hold the application data, instruction, and thread and to load it. The system needs to copy the application data from the HDD into the system memory in order for it to process and execute the data. Once the memory gets filled up with data, the system will stop loading the program. In this case, users need to add more memory onto their system to support that intense application. However, adding more system memory costs the money and the normal user only needs to run the the intense application that requires the memory only for one or two days. Therefore, virtual memory is introduced to solve that type of problem.
Terminology & Explanation
There are two types of memory, which are as follows:
* System Memory is a memory that is used to store the application data and instruction in order for the system to process and execute that application data and instruction. When you install the memory sticks to increase the system RAM, you are adding more system memory. System Memory can be known as either the physical memory or the main memory.
* Virtual Memory is a memory that uses a portion of HDD space as the memory to store the application data and instruction that the system deemed it doesn't need to process for now. Virtual Memory can be known as the logical memory, and it controls by the Operating System, which is Microsoft Windows. Adding the Virtual Memory can be done in system configuration.
Tutorial Information & Facts or Implementation
Virtual Memory is a HDD space that uses some portion of it as the memory. It is used to store application data and instruction that is currently not needed to be process by the system.
During the program loading process, the system will copy the application data and its instruction from the HDD into the main memory (system memory). Therefore the system can use its resources such as CPU to process and execute it. Once the system memory gets filled up, the system will start moving some of the data and instruction that don't need to process anymore into the Virtual Memory until those data and instruction need to process again. So the system can call the next application data and instruction and copy it into the main memory in order for the system to process the rest and load the program. When the data and instruction that is in the Virtual Memory needs to process again, the system will first check the main memory for its space. If there is space, it will simply swap those into the main memory. If there are not any space left for the main memory, the system will first check the main memory and move any data and instructions that doesn't need to be process into the Virtual Memory. And then swap the data and instruction that need to be process by the system from the Virtual Memory into the main memory.
Having too low of Virtual Memory size or large Virtual Memory size (meaning the size that is above double of the system memory) is not a good idea. If you set the Virtual Memory too low, then the OS will keep issuing an error message that states either Not enough memory or Virtual too low. This is because some portion of the system memory are used to store the OS Kernel, and it requires to be remain in the main memory all the time. Therefore the system needs to have a space to store the not currently needed process data and instruction when the main memory get filled up. If you set the Virtual Memory size too large to support the intensive application, it is also not a good idea. Because it will create the performance lagging, and even it will take the HDD free space. The system needs to transfer the application data and instruction back and forth between the Virtual Memory and the System Memory. Therefore, that is not a good idea. The ideal size for the Virtual Memory is the default size of Virtual Memory, and it should not be exceed the value of the triple size of system memory.
To determine how much virtual memory you need, since the user's system contains the different amount of RAM, it is based on the system. By default, the OS will set the appropriate size for Virtual Memory. The default and appropriate size of Virtual Memory is:
CODE
* 1.5 =
For example, if your system contains 256 MB of RAM, you should set 384 MB for Virtual Memory.
CODE
256 MB of RAM (Main Memory) * 1.5 = 384 MB for Virtual Memory
If you would like to determine how much the Virtual Memory is for your system and/or would like to configure and add more virtual memory, follow the procedure that is shown below. The following procedure is based on windows XP Professional.
1-1) Go to right-click My Computer and choose Properties
1-2) In the System Properties dialog box, go to Advanced tab
1-3) Click Settings button that is from the Performance frame
1-4) Once the Performance Options shows up on the screen, go to Advanced tab
1-5) Under the Advanced tab, click the Change button from the Virtual Memory frame to access to the Virtual Memory setting
Then the Virtual Memory dialog box appears on the screen. In there, you are able to check how much the Virtual Memory you set. If you would like to modify the size of Virtual Memory, follow the procedure that is shown below.
2-1) In there, select the drive letter that is used to install the Operating System
2-2) Choose the option that says, "Custom Size:"
Once you choose that option, the setting for Initial Size and Maximum Size become available for you to set. Initial Size (MB) means the actual size of Virtual Memory, and Maximum Size (MB) means the maximum size of Virtual Memory that is allowed to use.
Let's say if your system contains 512 MB of RAM, then the ideal setting for the Virtual Memory is as follows:
CODE
Initial Size (MB): 768
Maximum Size (MB): 1500
Once you are happy with that Virtual Memory size, click the Set button from Paging file size for selected drive to apply the setting for the Virtual Memory size. Then click the OK button to apply the setting.
That's where you can manage and configure for the size of Virtual Memory.
Additional Information
* To maintain the good overall system performance, you should be using the default size of actual size for Virtual Memory and the triple the value of the size of the main memory for the maximum size of Virtual Memory. If you find that main memory plus virtual memory is not big enough to load the intensive application, then you will need to add more main memory onto your system.
Search Keyword
virtual memory
on Dec 02, 2009 | Computers & Internet
System says low on virtual memory even after I zero & format the hard drive with new operating installed?
this is virus instaled on computer bios or defective memory boards.
1st replace memory, and check-it.
2nd find a original bios on IBM website, and flash-it.
Nov 22, 2009 | IBM NetVista PC Desktop
Windows XP Virtual Memory is low. How can I regain memory?
Virtual memory is "memory" on your hard drive, not actual memory. The best way to regain this is reboot and shut down some of the stuff that runs automatically when you DO boot up.
(This Virtual memory is space set aside on your hard drive that the processor moves data into and out of like it would put data on a memory module ... but in comparing the two, the virtual memory is SLOW.)
You can increase the size of your virtual memory to anything you want. Some say too large a allocation will slow you down and too little will cause crashing or slow opertion. You are 99.44% probably set to let Windows manage your virtual memory (default) at this time.
thanks for posting your question to FixYa.com
positive comments are welcome
a
Nov 02, 2009 | Gateway Essential 500 PC Desktop
I get a "virtual memory is low" error message. How do I correct
You have two different & independent problems. I will solve them one by one.
First of all, for increasing VIRTUAL MEMORY you should Right Click on "MY COMPUTER" then choose "Properties", then goto "Advanced" tab and then in "Performance" frame click "Settings" and then again goto "Advanced" tab and there you will see a "Virtual Memory" frame and then click on "Set" and increase the size of your virtual memory.
Second problem is due to installing many instances of XP. You can re-format your whole drive again and you will enjoy a fresh & single copy of XP again.
if you finds any difficulty or any doubt is there then feel free to contact me again.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 29, 2009 | Dell Inspiron 1300 Notebook
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
Im having low memory problems im gettin a virtual memory error and it shows that i have 224.mb is there anythin i can do to adjust this or wh do you think?? thank you for any advice you my have jrwh
First, a little explanation: Memory and virtual memory are not the same. Physical memory is what you see when you have 224 MM. Virtual memory is actually a file on your hard drive. You have to reset it to get rid of this message. Here's how:
Right click on "my computer" and then left click on "properties."
Now left click on "advanced." In that window, left click on "settings."When that window opens up, left click on "advanced." At the bottom of this window you will see the virtual memory properties. You will need to click on "change." About halfway down you need to click on "system managed size" and click on "set" just to the right. Then click on "OK"
The paging file will be changed when you restart and you should be good to go.
Jan 22, 2009 | HP Pavilion Ze4900 Notebook
RAM memory and Adobe Photoshop 7
The solution is to increase your virtual memory size...
Considering Win XP SP2 system.. the following procedure may be used to increase ur virtual memory / page file size...
Right click 'My Computer' --> Properties --> 'Advanced' Tab --> 'Performance' Settings --> 'Advanced' Tab --> 'Virtual Memory' Change --> Type in a custom size of 1024MB or something like that (not too much) --> Press 'Set' --> Close the windows --> restart -->DONE!!!
I hope that this solves your problem
Bye
Have a nice day
May 11, 2008 | Adobe Photoshop 7.0 for PC
Internet explorer not opening (memory problem?)
if your system is running low on memory, the pc will not be able to run the programmes as normal as it will use virtual memory which enables the system to open up programmes that you use regularly without searching for the start up files reciding on the hard drive, but if your system is low you will get these screen messages. Either upgrade the system with more memory or check what programmes you have running on start up using your memory, press start>run, then type msconfig and look at the start up tab and untick any unnecassary programmes that start up,then click apply for a restart, as this will release some of your memory. On the other hand there may well be a problem with internet explorer itself also, so you can download the latest IE7 from microsoft if you wish and see if this solves the runtime issue
Aug 24, 2007 | Toshiba Satellite M55-S331 Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
