Integrate SP2 in WinXP CD
I have Seperate SP2 and Winxp cd..How to make a integrated winxp sp2 cd
    Scholar:
  • 85 Answers
Step 1
Create 3 folders - C:\WINXPSP2 C:\SP2 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP2
Step 3
You will have to download the SP2 Update, which is 250MB.  Rename the Service Pack file to XP-SP2.EXE  Extract the Service Pack from the Run Dialog using the command:  C:\XP-SP2.EXE -U -X:C:\SP2
Step 4
Open Start/Run... and type the command:  C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP2contains: Windows XP SP2
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip  Code:  Code:  http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.  Select File > New... from the menu.  1.) Select CD-ROM (Boot)  2.) Select Image file from Source of boot image data  3.) Set Kind of emulation: to No Emulation  4.) Set Load segment of sectors (hex!): to 07C0  5.) Set Number of loaded sectors: to 4  6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:  Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab  Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)  Set Format to Mode 1  Set Character Set to ISO 9660  Check all Relax ISO Restrictions
Step 5
Click Label Tab  Select ISO9660 from the drop down box.  Enter the Volume Label as WB2PFRE_EN  Enter the System Identifier as WB2PFRE_EN  Enter the Volume Set as WB2PFRE_EN  Enter the Publisher as MICROSOFT CORPORATION  Enter the Data Preparer as MICROSOFT CORPORATION  Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN  * For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab  Check Write  Check Finalize CD (No further writing possible!)  Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP2  Select everything in the folder and drag it to the ISO compilation panel.  Click the Write CD Dialog button.
Press Write
You're done.
Posted on Oct 19, 2008
I want to install windowsxp service pack 2 and i need that cd room first
You can download WinXP Service Pack 2 from Microsoft Site.
or you can install WinXP SP2 using Windows Updates.
Hope it helps
Dec 11, 2010 | Microsoft Windows XP Professional for PC
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
E-machine C2881 runs good with winxp sp1 hang winxp sp2
Press F8 repeatedly after turning on power and select safe mode. Then go to ctrl/panel - add/remove apps and remove sp2. Reboot.
May 16, 2010 | FIC Crusader VC37GV (73-40682-00)...
How to solve pci.sys error during reformating of the hard drive
You have two ways to solve the problem of "Pci.sys Is Missing or Corrupt"
Error Message When You Start Windows.
1.Booting with WinXP CD to access the Recovery Console’s Repair option,
and then copy from WinXP CD the missing or damaged Pci.sys file to
Systemdrive:\Windows\System32\drivers folder , Exit and Reboot.
start the recovery console and type:
set AllowAllPaths = true
expand d:\i386\pci.sy_ c:\windows\system\drivers32 /y
If you don't type
set AllowAllPaths = true you can't access the windows folder.
2. Booting with WinXP CD and then perform a Windows XP Repair Reinstall
of the currently installed system.
If you need detailed assistance post with details of your Operating system
[WinXP Home vs WinXP Pro and the SP status i.e SP1 or SP2 ]
See
http://support.microsoft.com/default.aspx?scid=319136
Jan 12, 2010 | Microsoft Windows XP Home Edition
Worked in other computer in this Gateway Celeron 1.2gh it does not recognize that it has a cd or dvd in it. Running WinXP Pro with sp2, roxio 9 and Cyberlink PowerDVD6
If the pc isn't recognizing the hardware the main reason this happens is that you need to install the proper drivers.
Here's a link: Hope it helps
http://www.opendrivers.com/category/15/cd-rom-free-driver-download.html
Good Luck =)
May 24, 2009 | CyberDrive DVD-ROM DM-166D Internal DVD...
Unable to install
hi,
try to reinstall the printer using the laserjet driver instead of laserjet 6L. it's the remedy for that kind of problem..
rey
Sep 26, 2008 | HP LaserJet 6L Printer
All needed drivers for WinXp.
The Toshiba website had directions for getting drivers. You will need to provide your model number and follow links to get help. Good luck
Feb 18, 2008 | Toshiba Satellite A135 Notebook
Computer
1st make a backup of all the data you want saving.
2. find out your recovery cd or operating system cd.
3. insert the cd and then reboot.
4. on the start up key the first screen you see about 3 secs after turing back on hit the hot key.
could be F2 or F8 depends on your mother board.
if its neither of these watch carefully on the startup screen it should tell you wich key it is but be quick cause it will only be up for about 2 secsa :-)
when the cd boots up just follow the instructions.
please rate my solution on how it helped you.
any more quiestions or if u get stuck just reply to this post.
Dec 16, 2007 | Intel Motherboard
Dell installed on compaq
Hi, you have to use the original CD installer for WinXP that came bundled with your Compaq Presario. Reinstalling with the use of that CD will overwrite all previous installtion (from Dell) and should correctly install the drivers as well. Should the CD be not available, you may want to try and call Microsoft Support and relay to them your problem. You may need copies of proof of purchase and other documents and/or the serial number for the WinXP normally printed on a sticker at the side, back (or underneath for a laptop) of the PC. Another way is to purchase a CD installer of WinXP SP2 and go thru the routine of installing it. Hiope this be of some help to you. Good luck.
Apr 26, 2007 | Dell Microsoft Windows XP Home Edition
Computers & Internet Logo
254 people viewed this question
David Payne
David Payne
