Question about Sony KP-61HS20 TV
Loss of picture
While watching television, it looked like some one had taken a light pen or eraser and scribled across the screen the the picture was gone. I unplugged it for an hour thinking that it may be over heated. When plugged back in the power indicator flashes but no picture.
  • 1,476 Answers
When the power indicator flashes on a Sony it is saying "Hey, I lost high voltage". You are probably going to need a new Horizontal Output Transistor, a flyback transformer and possibly a High Voltage Block. None of the parts are that expensive from Tritronics (www.tritronicsinc.com). I just got them the other day for less than $100. You're better off just replacing everything mentioned rather than doing it piecemeal, once and done. I don't know whether you're capable of this repair or not. If you aren't sure have a professional do it. If you are going to proceed, remember safety! TVs are dangerous. Good luck.
Posted on Jun 23, 2006
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
Lines across the screen..
Open the front panel, about where the sound is, and look for 3-6 knobs, adjust those until you receive a good picture.
Jul 19, 2010 | RCA HD52W59 HDTV Projection Television
Horizontal lines on the screen after the picture is taken
Remove the Battery from the Camera then press and hold the power button for 30 seconds. Then, reinsert the Battery pack and turn on the Camera and reset it to the original factory settings by selecting the "Initialize" option under Setup1.
If the issue persists then service will be required.
Sep 08, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Spiral line descending across screen
hoz. out of sny. look for cap 200/100v
Jul 18, 2009 | Sanyo DS27910 27" TV
White line across screen
A white line across the screen is usually caused by a damaged/burnt out pixel(s) consult technical support for help, but you set is probably damaged beyond repair. I hope you have the reciept, my brother had a similar prob.
Apr 25, 2009 | Philips 32PF5531D 32 in. LCD Television
Panasonic PT-47X54J Not working
I can't tell you how to fix this set, but I can tell you that its not a "lamp" issue as this doesn't have a lamp. Its a 3 picture tube projection TV. the three tubes are in a red green blue format, and average about $175 for each one, not including the labor to install them. your problem, may not be the tube, but just a power supply problem, but there is a chance it is.
Nov 21, 2008 | Panasonic PT-47X54 47" Rear Projection...
Picture Problems On 50 Inch Philips Plasma
You plasma still under manufacturers warranty. Most electronic devices have one year warranty.
The failure in your TV can only be corrected by repairing it.
I would suggest to call philips and ask them to find you an authorized repair center near you to get your TV fix under their warranty.
Jul 24, 2008 | Philips 50PFP5332D 50 in. Plasma...
Looks like pen marks on inside of screen
What you are decsribing sounds like your picture tube or tubes have been scored (permanent burn marks on the picture tube phosphor). The sure way to tell is to remove the front screen and look into each of the three lenses while the set is on. You will see a black image of your pen mark within the picture. Did you recently have problems with convergence or the set shutting down (turing off by itself for no resaon) ?
Nov 12, 2007 | Toshiba 50H82 50" Rear Projection...
Sony KP-61HS20 TV Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
