Converting Partition to ntfs
I wanna convert My Running FAT32 parti.. to NTFS without loosing my data..
    Scholar:
  • 85 Answers
Converting to NTFS
Your hard drive must be formatted with a file system such as FAT, FAT32 or NTFS so that Windows can be installed on to it. This system determines how files are named, organised and stored on the drive. If you’re not using it already, NTFS (New Technology File System) is recommended for Windows XP because of the additional functionality it offers. If your PC came with Windows XP pre-installed then there’s a chance that you’re already using NTFS. If you’ve upgraded from Windows 98 or Windows Me you may still be using FAT or FAT 32. The option to change over to NTFS would have been available during the upgrade process. Don’t worry if you skipped this as it’s possible to convert at any time from within Windows XP without losing any data.
The recommended option There are a number of features in Windows XP that will only work if the NTFS file system is present, which is why it’s suggested you make use of it. File and folder permissions, encryption and privacy options are just some of those you’ll be able to access. In particular, those of you who have set up user accounts will find NTFS invaluable. For instance, if you continue to use FAT or FAT32 anyone with physical access to the drive will be able to access the files and folders that are stored there. However, with NTFS you’ll be able to use a level of encryption (Professional Edition only) that will enable you to protect your data.
You’ll also find NTFS more reliable in that it’s more able to recover from disk errors than its FAT or FAT32 counterparts. A log of all disk activity is kept so should a crash occur, Windows XP can use this information to repair the file system when your PC boots up again. To find out what file system you’re using, open My Computer, right-click your main hard drive and choose Properties. Take a look at the General tab to see confirmation of the file system that’s in use.
Convert now You can use the convert tool in Windows XP to change the file system on your hard disk from FAT or FAT32 to NTFS. The whole process is safe and your existing data won’t be destroyed. To begin, click Start -> Run, type cmd and press [Return]. At the command prompt type convert c: /fs:ntfs and press [Return] (where ‘c’ is the letter of the drive you’re converting). When you try and run the convert utility, it’s likely that Windows XP will be using your paging file so the process won’t be completed immediately. Therefore, you’ll see a brief message on screen informing you that the conversion will take place instead the next time Windows starts up. Having restarted, the Check Disk utility will run, the conversion will be performed automatically and you may find that your PC will reboot twice more.
The benefits With your drive now running NTFS, it’s time to take advantage of the new options that are available. Having created a number of different user accounts you can now control the level of access that’s granted to individual users. For example, there are going to be certain files and folders that you’ll want some users to be able to access but not others. If you have Windows XP Professional Edition you can do this immediately.
Right-click any file or folder, choose Properties and select the Security tab. A dialog will be displayed showing the names of all your users. Alongside will be two columns which enable you to select levels of access for each of them, the permissions include Full Control, Modify, Read and Write. You can then check the appropriate box to determine whether or not to Allow or Deny a particular permission. For Windows XP Home Edition users, the Security tab won’t be immediately available. To access this option you’ll need to restart your PC, pressing [F8] until a menu appears. Next select Safe Mode and wait for Windows XP to start up. You can then set your options in the same way.
Another feature is NTFS compression. It’s quick and seamless as your file or folder is decompressed automatically when you access it. (Don’t confuse this with a Zip compression utility where the files need to be extracted before they can be accessed.) Although you may have used NTFS compression on a file or folder, there’s no way of telling just by looking at it. To remedy this, open My Computer, click Tools -> Folder Options and select the View tab. Under Advanced settings, scroll down and check the option ‘Show encrypted or compressed NTFS files in color’, then click Apply and OK. Take a look at your compressed items in My Computer and you’ll see the text label has changed from black to blue. Something else that’s exclusive to Professional Edition users is the Encrypting File System (EFS). You can use this to protect your important data so that no one else can read it. Your encrypted files and folders will only be accessible when you have logged into your user account successfully.
Posted on Oct 19, 2008
    Problem Solver:
  • 7 Answers
Goto start 2.Run 3.type cmd 4.type CONVERT volume name or drive letter /FS:NTFS
Kingston data traveler 200 128 GB format ex Fat 32 to NTFS
Would you please clarify your problem. But i suggest that you would like to change the file system from FAT to NTFS. If you want to do that then follow the following simple steps
1. Go to start and click o RUN
2. Type CMD and press enter
3. in the Command prompt, type the following
convert E: /fs:ntfs
In this example, you are converting Drive E to NTFS. Note that you can you this command to simply change FAT16 or FAT32 system files to NTFS but you can not simply reverse the situation. This is because when changing from NTFS to FAT6 or FAT32, the system will delete the partition and erase all the data and personal files on it
Mar 26, 2012 | Computers & Internet
Tip
Convert FAT or FAT32 File system into NTFS
You can increase the performance of your computer using NTFS (New Technology File System) hard drive volume with windows XP, because this advance file system provides some extra features, for example security, reliability, file encryption and Compression features.
But if you are still using old file systems like FAT or FAT32, you can covert it into NTFS with a simple command. The interesting thing is that you can convert your hard drive volumes file system without losing data on the drive. Follow the giving steps to convert FAT or FAT32 partition to NTFS:
  • First go to Start button then click on Run option.
  • Now type here “CMD” and press Ok to open command prompt.
  • At the command prompt type convert drive letter name: /fs:ntfs
  • For example if you want to convert drive E to NTFS then the command will be “convert e: /fs:ntfs”.
  • Now restart your computer and enjoy NTFS features, but keep in mind you cannot covert back it to FAT or FAT32 again.
on Jan 29, 2010 | Computers & Internet
Tip
Converting Fat to NTFS
To convert a FAT partition to NTFS, Do these following steps steps.
Click Start, click Programs, and then click Command Prompt.
In Windows XP, click Start, click Run, type cmd and then click OK.
At the command prompt, type CONVERT [driveletter]: /FS:NTFS.
Convert.exe will attempt to convert the partition to NTFS.
NOTE: Although the chance of corruption or data loss during the conversion from FAT to NTFS is Low, it is best to perform a full backup of the data on the drive that it is to be converted prior to executing the convert command. It is also recommended to verify the integrity of the backup before proceeding, as well as to run RDISK and update the emergency repair disk (ERD).
on Dec 01, 2009 | Computers & Internet
What format should I chose to grab it to a PC?
This will depend on which type of computer and operating system you have
if you are referring to formatting your hard drive to a specific format file system NTFS or FAT choose the Ntsf file system is more secure Ntfs is more powerful than Fat or Fat32 and includes features required for hosting Directory as well as other important security features . You can use features such as Active Directory and Domain - based security only by choosing Ntfs your file system Its easy to convert Partitions to Ntfs . The set up programs conversion makes it easy whether your partitions used Fat or Fat32 or the older version of Ntfs .This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive.
hope this helps you
Sep 03, 2011 | Computers & Internet
If you are running your computer under ntfs should your external harddrive be formatted the same instead of fats32. If it does can I move my back up from the external hard drive and move it back after...
The external hard drive can remain formatted as FAT32. NTFS and FAT32 are the file systems used by the individual disk drives, and do not effect the data being read or written (i.e., you can transfer data between the two with no worries about compatibility). There ARE differences, however, and many would suggest using NTFS to avoid some limitations with FAT32. For example, FAT32 drives have problems with individual files over 4GB. Formatting in NTFS is definitely recommended for people storing large files like video and other media files.
Yes, you can move any data you have off of your external hard drive (to your system hard drive or another external you use temporarily), format your external hard drive with NTFS, and then transfer your backups and other data back to your newly formatted external drive.
You can also convert the drive to NTFS; but I recommend backing up the data first anyway in case of (rare) problem during conversion. Here is a link that has directions for both scenarios (scroll down for conversion info) for Windows XP. http://www.microsoft.com/windowsxp/using/setup/tips/advanced/ntfs.mspx
The process to convert is similar for Vista and 7; here are the instructions from MS: http://windows.microsoft.com/en-US/windows-vista/Convert-a-hard-disk-or-partition-to-NTFS-format
Feb 02, 2011 | Western Digital My Book Essential Edition...
I want to format my 2 T hard drive from NTSF to fat 32 , how to do please help
Ok this fix will erase all Partitions on the drive, Make sure you have all data back'd up.
Open Command:
Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator. Or Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
You should have a black MS-DOS prompt on your screen. Type DISKPART in and press enter. Another window will open
Type: list disk It will the display list of devices with memory storage. Find your disk, It should be in a Table(kinda). You have to locate it by its size. so look for 1TB(1000GB) In this Example its Disk 2, yours may differ.
type in: Select disk 2
Execute the rest one by one: CLEAN CREATE PARTITION PRIMARY SELECT PARTITION 1 FORMAT FS=FAT32 ASSIGN EXIT
Wait for one command to complete before running another
You should be left with a working FAT32 Device :P
Regardz Sinn3D
Oct 27, 2010 | Western Digital My Book Essential 1TB...
Can not get hard drive to convert from fat32 to ntfs
Convert FAT32 to NTFS In Windows XP:
  • Click Start -> Run
  • Enter "cmd" into the text field labeled "Open".
  • Click OK button
  • If you want to convert drive D (D:), enter the command "vol d:" in the command window, to find the volume label for the D: partition
  • Then enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS
  • When prompted, enter the volume label for the partition
Convert FAT32 to NTFS In Windows Vista and 7:
  • Click Start sphere.
  • In the Start Menu search box, simply enter "cmd" and hit enter.
  • If you want to convert drive D (D:), enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS that way can be confusing so an easier way is to download a free software heres the link http://www.partition-tool.com/personal.htm
Oct 20, 2010 | Maxtor Hard Drive
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Partitioning ext. "MY BOOK"
You don't need to format it. You can also just convert it to NTFS and keep the current data.
There is also no requirement to create more than one partition.
In the command prompt window, type
convert drive_letter: /fs:ntfs
You'll find this in Windows Help. Just search for convert ntfs.
Jun 09, 2008 | Symantec Norton Partition Magic-8.0...
Converting in order to Resizing an NTFS partition...
The only way to make your partion bigger is too merge your partitions.
The way the partition is formatted. (ie. FAT, FAT32, NTFS, etc) allows for information to stored differently. These file allocation tables use different size slots to store the information in. When you install a new program, the data is put into the first empty slot on the drive, and if there too much data for 1 slot, it uses the next available empty slot and so on until all the data is stored. If the last bit of data is just a couple of bites. The remaining space is unusable for any other program, thus wasting space.
When you delete a program, those slots are emptied and the next time you install something, it is stored in the first available empty slot. SInce most programs are not the same size, your drive soon becomes fragmented and this slows down the way the OS is able to retrieve information. (That's why defraging is a good thing.)
So using smalller allocated table sizes makes more efficient storage (less wastage of space) but on large drives this also makes for slower retrieval times and makes the OS work harder.
But to answer your question, you cannot easily convert NTFS to FAT,and I don't understand why you'd want to go to FAT from NTFS anyway. NTFS has much better security (FAT has none) and is more efficient than FAT.
But to convert to FAT you would need to do the following:
BACK UP YOUR DATA FIRST/
Then delete the partition that you wish to convert. This is done by going into Disk Management: right click "My Computer" -> Manage -> Disk Management, which is found under the Storage section. Right click the partition you wish to remove, and click "Delete Volume". This will erase the partition. Once you have done this, you must re-create the partition. This is done by right clicking on an unallocated region of a disk, and selecting "Create Partition". Then click "Create Logical Drive". Bear in mind that Windows cannot format a FAT32 partition that is any larger than 32GB. This is the case because FAT32 is terribly inefficient on volumes that are larger than 32GB: fragmentation becomes a serious problem.
To format this new volume, right click it, and choose Format. Again, if the volume you wish to format is larger than 32GB, FAT32 will not be one of the options available to you in the drop-down box. You will have to create multiple partitions if you want to format a large drive as FAT32. (Oops, there goes the reason you were doing this in the first place)
You would be better off just leaving it alone, and if you must have a bigger drive, either buy a larger drive, or merge 2 partitions. (Using the above method to do so)
Hope that helps.
Dec 25, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
