Computers & Internet Logo
Anonymous Posted on Oct 19, 2008
Change My Documents Path
How to change My Documents Path to any drive
Anonymous
Level 2:
Scholar:
  • Expert 85 Answers
  • Posted on Oct 19, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
85
Questions
0
Helped
33262
Points
210
Right click on my documents than go->Properties->Target->move
than select any drive or folder
u will do that
How to move/copy user files to external hard disc (wall or usb powered) so that productivity applications default-save to the external hard disc (virtual drive) folder via...
quite a bit of "what if's there" lol
First of all, yes you CAN re-direct the 'my documents' folder to another location....be it on an internal or external drive volume. This requires careful adjustments to the HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folder
when you do this, you can assign any path to the "my documents" folder, (and also the others listed,) this will be a permanent change and will cause that path to be the new destination for files saved to 'my documents' by the OS. the actual path does not HAVE to even have the word 'documents' in it...you could call it E:\bubbles if you want.
You would continue to 'save' your new docs to 'my documents', the OS would just be interpreting a new and different destination for the Save.
Should that resource become unavailable, you would have to perform a 'save-as' and then specify a valid save location.
If you are doing this because of limited space on your C-drive, well and good, but if not, then consider Drive synchronization software instead.
These software programs allow you to specify single, or multiple folders, to copy files. you would set it up to copy from your pc to the same-named folder(s) on the external drive, and to propagate changes....so it will save files that are new or changed and delete files that were deleted, (this can be suppressed.)
One of the pitfalls of using USB devices is that drive letters are typically assigned automatically. If you do not manually assign a drive letter that is not typically accessed by the fist say....4 USB drives, it is possible for the PC to become confused and start putting files to the wrong USB device. So assign your external a high drive letter like P for portable, and don't forget to include that in the new 'path' you put in the registry.
I hope that answered your questions.
tip
An error message informs you that you cannot move or rename the Documents and...
To specify a different folder for the Documents and Settings folder during installation, follow these steps: 1. Run Winnt.exe or Winnt32.exe by using the /unattend option, and then insert the following entry into the Unattend.txt file, where z:\foldername is the path and folder name you want: [GuiUNattended]
ProfilesDir = z:\foldername 2. Install Windows. The path that you included in the Unattend.txt file is used instead of the default Documents and Settings folder.NOTE: This method does not relocate any key Windows components. Use this method if you require only user-specific data to be moved.
After you install Windows XP, to specify a folder other than the Documents and Settings folder for a particular user's data, follow these steps: 1. Identify the user's profile path. You can identify the profile path either by user security ID (SID) or by user path settings. The user SID method is preferred. To identify the user's profile path by the user SID loadTOCNode(3, 'moreinformation'); a. Use the Getsid tool from the Windows Server Resource Kit to obtain the SID. At a command prompt, use the following syntax: getsid \\ComputerName UserName \\ComputerName UserNameFor example: getsid \\windowsxp joedoe \\windowsxp joedoeThe results look something like this: = The SID for account WINDOWSXP\joedoe is S-1-5-21-1708537768-1993962763-1957994488-1003 b. After you obtain the user SID, start Registry Editor (Regedit.exe or Regedt32.exe), and then select the user SID under the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList To identify the profile path by the user's path settings loadTOCNode(3, 'moreinformation'); a. Log on to the computer as the user, and then type set at a command prompt. Note the setting for UserProfile, and then quit the command prompt. b. Log on to the computer as an administrator. c. Use Registry Editor to add the UserProfile setting to the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList d. Click the registry key, and then click Find on the Edit menu. e. In the Find box, type the value of the UserProfile setting, and then click Find Next. 2. In the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList registry key, change the ProfileImagePath value to reflect the new path that you want to use, and then quit Registry Editor. 3. Log on to the computer as the user, type set at a command prompt, and then verify that the path has changed.
Moving the entire folder loadTOCNode(2, 'moreinformation'); NOTE: This method does relocate key Windows components. Use this method only if you require the Documents and Settings folder to be moved or renamed and you cannot use the Unattend.txt file to change the name during installation.
To specify a different folder for the entire Documents and Settings folder, including key system components, follow these steps: 1. Log on to the computer as an administrator, and then create a new folder. 2. In the current Documents and Settings folder, on the Tools menu, click Folder Options, and then click the View tab. 3. Under Advanced settings, click Show hidden files and folders, and then click to clear the Hide extensions for known file types and Hide protected operating system files (Recommended) check boxes. 4. Click OK. 5. Click and drag all the folders in the Documents and Settings folder to copy them to the new folder, except for the folder for the currently logged-on administrator. 6. Log off and then log back on, using a different administrator account from the one that you just logged off from. 7. Open the Documents and Settings folder again, and then copy the profile of the administrator that you just logged off from to the new folder. This extra step is needed because you cannot copy the profile of the account that is currently logged on. 8. Log off the computer, and then again log on to the computer as an administrator. 9. Start Registry Editor, and then click Find on the Edit menu. 10. Type documents and settings, and then click Find Next. 11. For every registry key or value that contains the original path, replace the value data or rename the value or registry key to the new path.IMPORTANT: You must complete this change in the registry for every instance of the original path, or your computer may not start. It is imperative that you update all registry keys and values with the new path.
12. Restart the computer. You can now safely remove the original Documents and Settings folder.
tip
How to rename or move a User Profile folder ?
To rename (or move) the User Profile folder, you may use the following method. This method has been adopted from KB314843, but this page explains in detail how to rename an User account home directory.
Though you can move or rename the user profile folder, there may be some side-effects after using this method. This is because of the reason that there may be some absolute path (to the old user profile folder) references in the registry, made by third-party software. Therefore, there may be a loss of functionality in some third-party software which stores the file locations as absolute paths, in the registry.
Before modifying the registry, you need to take a full backup, in case you want to Undo the changes or to recover from disasters caused by incorrect registry modifications if any. You may use ERUNT for a full registry backup. Use Registry Editor at your own risk
Rename the User Profile folder using Windows Explorer
  • Logon to an admin account that is not the account being renamed.
  • Open the Documents and Settings folder, by typing this in Start, Run dialog:
%SystemDrive%\Documents and Settings
  • The list of folders will be displayed. Select the corresponding folder of the user account that you want to rename.
Example %SystemDrive%\Documents and Settings\OldUsername
becomes
%SystemDrive%\Documents and Settings\NewUsername
Next step is to notify the registry that the folder has been renamed (or the Profile Path has been changed)
Changing the ProfileImagePath value in the registry
ProfileList key, SIDs and the ProfileImagePath value The ProfileList registry key contains some sub-keys, which are nothing but the list of User Account Security Identifiers (SID). Each of the SID represents an Account. The key is located here:
HKEY_LOCAL_MACHINE \ SOFTWARE\ Microsoft\ Windows NT \ CurrentVersion \ ProfileList
Identify the SID for your User account, and change the Profile path
  • To know the SID for your user account, you may use the script sidlist.vbs
  • Download the script and run it. (The User Account names and SIDs will be listed in a log file, and opened automatically.)
  • Note down the SID for your account.
  • Then, in the Registry Editor, select the correct SID that belongs to your user account.
  • In the right-pane, double-click the ProfileImagePath value and set the correct path and folder name. ( The ProfileImagePath stores the full path of the User account home folder. )
becomes the following:
You're done now. Close Registry Editor, and restart Windows. See if you're able to logon to that user profile successfully. Additionally, to verify if the path has been changed successfully, type SET in the Command Prompt. If you find any abnormal behavior while running an application (in case), you may Undo the above procedure. Then you may use the Copy To Profile method instead to accomplish your task.
3answers
How come I am not able to install on my computer,
An example of a path would be c:\windows\programs\redbook
Everything starting at the c is the path. Change the destination to a folder/path that is shorter than the current one. The path starts at the hard drive then goes from folder to folder until it reaches the destination.
We have a Savin 4045sp copier with scanning. It scans documents but does not transmit them to the network drive. I had to reset the jobs and now I have this problem. Network is working fine. Can you...
From what you are saying You are making scan-to-folder???? Yes????
Make sure the path is rigth. Make sure the folder is properly shared.
Are the autentication rigth???? Did you made any change in the login (windows)?????
My C drive and Backup E drive are switched
You ned to change the save path file. For a short answer...Try clicking "save as" instead of "save" there should be a dialog box prompt that lets you select where you wish to save your documents.
I am having trouble changing the default "save" directory on the
The default 'save' directory for Livecam is fixed as: My Documents\My Pictures\LIvecam Files on C: drive.
However, you CAN change the location of My Documents e.g. put it on D: drive. See the MS Knowledge base for how to do this: http://support.microsoft.com/kb/310147
1helpful
2answers
Toshiba A100 will not automatically save data to the 2nd drive
Close all documents and running programs. Locate your Documents Folder on your C: Drive. Right Click and select Properties. Change Taget Folder Location by replacing C: with E:, then click OK. Answer Yes to move all of the files from the old location to the new location. This will migrate all Documents to E:, and set the save path to this drive by defualt. Thus freeing space on drive C: and leaving it for applications and updates only. You may also want to run the Disk Cleanup utility to free even more space from drive C:.
Installation path change
Change The Default Location For Installing Apps -----------------------------------------------
As the size of hard drives increase, more people are using partitions to separate and store groups of files.
XP uses the C:\Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/ or directory by using a Registry hack.
Go to :-
- Start > Run
- Type “regedit” (without “” NOOBS!)
- Go to this directory… HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
- Look for the value named ProgramFilesDir. by default,this value will be C:\Program Files. Edit the value to any valid drive or folder and XP will use that new location as the default installation directory for new programs.
How to get rid of a black strip (1") on the leading edge of scanned documents?
You must be using Auto contrast/brightness. Change to manual, try one or two scans changing the brightness tab moving left or right and choose desire output quality. Remember the settings for that set of documents. The brightness will vary depending upon data (foreground) and noise (background). For a different set of docs you may need to adjust the settings slightly.
S. Mohan
Grand Canyon Tech
Grand Canyon Tech
