Installation path change
How to change installation path in winxp.....from c: to anywhere
    Scholar:
  • 85 Answers
Change The Default Location For Installing Apps -----------------------------------------------
As the size of hard drives increase, more people are using partitions to separate and store groups of files.
XP uses the C:\Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/ or directory by using a Registry hack.
Go to :-
- Start > Run
- Type “regedit” (without “” NOOBS!)
- Go to this directory… HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
- Look for the value named ProgramFilesDir. by default,this value will be C:\Program Files. Edit the value to any valid drive or folder and XP will use that new location as the default installation directory for new programs.
Posted on Oct 19, 2008
How come I am not able to install on my computer,
An example of a path would be c:\windows\programs\redbook
Everything starting at the c is the path. Change the destination to a folder/path that is shorter than the current one. The path starts at the hard drive then goes from folder to folder until it reaches the destination.
Jun 06, 2014 | Avanquest Checksoft 2007 Home & Business ...
I can"t access wireless after
  • You can download it here
  • Decompress the zip file on your desktop, and then go to the folder:
    • C:\Documents and Settings\F\Bureau\2007112100265\TL-WN321G_071102\Win98_ME_2K_XP_X64\Driver Files\WINXP
  • And right-click on the rt73.inf file and select the "Install" option
  • Then unplug your wireless adapter and reconnect it.
  • It will then be detected by the installation wizard that will now launch.
  • You may be required to indicate the path for the rt73.sys file.
Aug 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Driver manhatten webcam winxp
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Sep 11, 2010 | Manhattan Mini WEBCam
How do i fix dynamic link library powrprof.dll.
you have to run the installation disc of winxp or whatever o.s. you are using you may have accidentally deleted or the file is corrupt, run the installation disc repair your current o.s using the disc it will copy the missing dll to your system
Dec 04, 2009 | HP Pavilion dv9000z Notebook
Installing winxp on my computer, but installation stops
is like you are too stingy to spend for your PC, take your pc to a computer repairer, if not you will crash your PC.
Dec 12, 2008 | Computers & Internet
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
Dual boot prob
boot to win98 operating system. Insert the XP operating CD. IT will automatically open a window asking you to select Install winXP prof. It will ask for new installation and Upgrade (recommended)
select upgrade and select next and follow the instructions. it will restart and ask you select the os.
select xp in blue screen. install the OS other than C Drive.
please don't ever install in c drive.. do with caution.
Enjoy.
Oct 19, 2008 | Computers & Internet
Kodak EasyShare C340 Digital... Problem
actually the software installation defaultly goes into C:
if it showed CUSTOM option during installation its path could be changed...
the method i said previously was only for the photos to be saved in D: or E: whatever...
did you check for that option??
Jul 01, 2008 | Kodak EasyShare C340 Digital Camera
Install my scanner with winXP
how to install my scanner acer Prisa 340p with winXP because the installation CD support only win95, win98, winNT,and when I connect the scanner to the computer ,the computer can see the new hardware but the installation failled, and the scanner doesn't work with the pc, what can...
Dec 02, 2007 | AcerScan Prisa 340P Flatbed Scanner
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
