Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer dryer stops when it gets hot. Thermostat? It's also making a screeching sound when it starts but quits as it gets warmer.
    President:
  • Maytag Master
  • 2,651 Answers
If its completly shutting down aftger runnig for a bit, and sounds a little rough upon starting, sounds as if you may have a bad motor, its overheating( not allowing you to restart untill it cools off anyway.
Posted on Oct 21, 2008
I get code E6 and my Maytag dryer keeps stopping
BAD MOTOR WINDINGS OR DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Apr 19, 2015 | Maytag Dryers
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Screeching sound coming from Maytag dryer. Blower wheel, motor?
Probably bad motor if dryer is shutting down after few minutes of operation
Aug 27, 2017 | Maytag PYG2300A Gas Dryer
Screeching noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdgs
Jun 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Ihave a maytag atlantis gas dryer model mdg7400aww that when I first start it up it gets warm but then stops heating? what is the problem
The operator coils get hot and quit on these ,when they get a little age on them, quite difficult to diagnose. If the coil feels hot to the touch after failure then that is a clue. f00c98f.jpg
Mar 05, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
My front loader dryer stopped heating,
have a electrician inspect the circuit going to the dryer as it might not be providing proper current to operate the dryer
Jun 22, 2009 | Maytag MDE9206 Dryer
Maytag Performa PYET344ATW dryer noise problem
unplug the dryer.
Raise the lid.
Remove the front panel.
Inspect the blower wheel on the motor.
If loose on the shaft, replace it.
Inspect the glide supports on the front drom support.
Remove the drum.
Inspect the rear rollers for sticking.
Inspect the belt tension roller for wear.
Mar 12, 2009 | Maytag Dryers
Dryer flame shuts off after about 30 seconds
this sounds like a clogged vent more than a thermostat. go outside with the dryer running and see if hot air is blowing out the vent. if not check outside vent for birds nest etc, inside make sure the vent is straight any dips in vent could cause water to build up clogging the vent. try this first if it doesn't work write back
Jan 23, 2009 | Maytag Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
118 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
