BIOS Update Procedure
How to update bios
  • Anonymous Feb 03, 2009
    How do I update my older Bios ?
    Scholar:
  • 85 Answers
All latest Motherboards today, 486/ Pentium / Pentium Pro etc.,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about this.
Please read the following instructions in full before starting a Flash BIOS upgrade: A. Create a Bootable Floppy (in DOS)
•With a non-formatted disk, type the following:
format a:/s
•If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you are flashing the new BIOS.
B. Download the BIOS file
•Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip for Windows 95 shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•You should have extracted two files:
Flash BIOS utility eg: flash7265.exe (for example)
BIOS eg: 6152J900.bin (example)
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file). This information is usually provided.
C. Upgrade the System BIOS
During boot up, write down the old BIOS version because you will need to use it for the BIOS backup file name.
Place the bootable floppy disk containing the BIOS file and the Flash Utility in drive a, and reboot the system in MS-DOS, preferably Version 6.22
•At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
flash625 615j900.bin
•From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:13J900.bin
Alternatively select "N" if you don't want to save your current BIOS. Beware, though, that you won't be able to recover from a possible failure.
•Select "Y" to "Are you sure to program?"
•Wait until it displays "Message: Power Off or Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
Make sure the new BIOS version has been loaded properly by taking note of the BIOS identifier as the system is rebooting.
For AMI BIOS Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips note: 1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
2. If you have problems installing your new BIOS please check the following:
Have you done a clean boot? In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
If you have not used a bootable floppy, insure a clean boot either by
a) pressing F5 during bootup
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by using the EDIT command.
Have you booted up under DOS? Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers. Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above procedure (format a: /s and rebooting from a:).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c: your will need to type a:15j900.bin, rather than 615j900.bin only.
Posted on Oct 19, 2008
  • Kris Czerniawski
    Kris Czerniawski May 03, 2013
    How to make CD for board that does not have floppy driver? I am stuck with A990FM from ECS. After 8 months error B2 cropped up. ECS says gave new BIOS that has fix for it. Made bootable CD but on Intel machine using FreeDos. Boots on Intel box but not on the AMD A990 (CPU FX8150). Trying to boot, LEAD on CD drive flashes ..... for ever ... Any ideas ?
2 Suggested Answers
carpenocte
  • 104 Answers
SOURCE: Bios problem
bios for ibm is at ibm.com and you should never update bios if you dont know much of computers but always use software to flash bios from windows... ibm.com will be good to download bios, the other part is up to you, because if you are clueless on this matter you better take your computer to an it technician before braking it down.
Posted on Mar 20, 2008
How do I update bios on acer 7741Z 4643
Bios Updates As Well As Instructions Are Available On Acer Website----BE VERY CAREFULL--If Not Sure Of Procedure Or Which Update To Install, Take It To A Pro. It Will Cost You, But If You Do It Wrong, Laptop More Than Likely Will Be UNUSEABLE.
Feb 27, 2015 | Acer Aspire Computers & Internet
Tip
Do not update Lenovo E430 bios to V2.54
Updating Lenovo Edge E430 could destroy your motherboard and cost you $450. Latest bios update is V2.54 and will update but leave you with a non bootable computer with no access to setup. Do not ever remove the power cord, battery, and bios backup coin cell battery at the same time. Result is Instant destruction of your system board. Update of bios up to V1.18 is okay but I would not activate the UEFI bios. Read all update directions carefully to understand procedure. Windows 7 and Windows 8 have different procedures.
on Feb 12, 2014 | Lenovo ThinkPad Edge E430 Laptop Computer
How to update my asus p4sgl-mx motherboard bios
"BUPDATER BIOS Upgrade Procedure" read the Instructions/Procedure from ASUSTEK
Caution:
Updating your Mainboard BIOS is not for the novice, any errors ie.Wrong Bios versions or power failure occuring during your Bios process may render your mainboard useless!!! Do it at your own risks.
Hope it helps.
Jun 02, 2011 | ASUS Computers & Internet
I need to know how to bios update
That is the right procedure. The next step is to type the path of the BIOS file. Have you tried D:\(bios file name)?
Nov 06, 2009 | Computers & Internet
''unknown cpu detected,bios update is required to unleash its pow
Ensure that you download the BIOS update from the ASUS Website - nowhere else - and that it is for your exact motherboard model.
Instructions are here:
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
I am a bit surprised that they still require you to copy the files to a floppy/USB and boot into DOS. Last time I updated my Phoenix BIOS the utility ran from Windows. But anyway, that seems to still be the procedure for ASUS boards.
Sep 24, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Ibm motherboard pro300a_afp bios update
Go to the Bios's Manufacturer's website, they will have it, get the update, and instructions to update.
there is a Specific procedure to follow.
Hope this helps
Regards.
Apr 16, 2009 | Computers & Internet
Up date my bios and copy my bios procedure
You will be able to update your BIOS from asus web site. Just fill in the details and get your update.However a BIOS update should only be done if this message appears during any operation of the PC.............sodeep
Apr 14, 2009 | ASUS A8N-SLI Motherboard
I want manual and bios of Asus motherboard model
Here's the link to the driver and bios updates. Hope it helps you.
http://bios-and-system-update.free-driver-download.com/ASUS/12467/ASUS-Mainboard-P4PE-BP-BIOS-1007.html
Mar 29, 2009 | ASUS P4PE-BP Motherboard
Motherboard
First reboot the computer and enter the bios screen. Disable the bios protect...
Then reboot back into the OS (Presumably windows) and download the bios update from the manufacturer website. It will probably be a zip file containg the bios and the flash utility. Unzip the file and you should have a windows and/or DOS flash utility. If not, the utility should be posted on the website. If the utility is Windows, simpy run the utility. It will ask for the location of your bios file. The update utility will do the rest for you. If the program is DOS, the procedure is similar. Move the utility and bios update into your root directory, reboot, and simpy run the program from the command line.
Nov 06, 2008 | Computers & Internet
Computers & Internet Logo
2,498 people viewed this question
David Payne
David Payne
