Keyboard Shortcut for Windows
What is Windows Key board Shortcut....
    Scholar:
  • 85 Answers
Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system. I use the following keyboard shortcuts every day:
Windows key + R = Run menu
This is usually followed by: cmd = Command Prompt iexplore + "web address" = Internet Explorer compmgmt.msc = Computer Management dhcpmgmt.msc = DHCP Management dnsmgmt.msc = DNS Management services.msc = Services eventvwr = Event Viewer dsa.msc = Active Directory Users and Computers dssite.msc = Active Directory Sites and Services Windows key + E = Explorer
ALT + Tab = Switch between windows
ALT, Space, X = Maximize window
CTRL + Shift + Esc = Task Manager
Windows key + Break = System properties
Windows key + F = Search
Windows key + D = Hide/Display all windows
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Also don't forget about the "Right-click" key next to the right Windows key on your keyboard. Using the arrows and that key can get just about anything done once you've opened up any program.
Keyboard Shortcuts
[Alt] and [Esc] Switch between running applications
[Alt] and letter Select menu item by underlined letter
[Ctrl] and [Esc] Open Program Menu
[Ctrl] and [F4] Close active document or group windows (does not work with some applications)
[Alt] and [F4] Quit active application or close current window
[Alt] and [-] Open Control menu for active document
Ctrl] Lft., Rt. arrow Move cursor forward or back one word
Ctrl] Up, Down arrow Move cursor forward or back one paragraph
[F1] Open Help for active application
Windows+M Minimize all open windows
Shift+Windows+M Undo minimize all open windows
Windows+F1 Open Windows Help
Windows+Tab Cycle through the Taskbar buttons
Windows+Break Open the System Properties dialog box
acessability shortcuts
Right SHIFT for eight seconds........ Switch FilterKeys on and off.
Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.
Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.
SHIFT....... five times Switch StickyKeys on and off.
NUM LOCK...... for five seconds Switch ToggleKeys on and off.
explorer shortcuts
END....... Display the bottom of the active window.
HOME....... Display the top of the active window.
NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.
NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.
NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.
LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.
RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.
Type the following commands in your Run Box (Windows Key + R) or Start Run
devmgmt.msc = Device Manager msinfo32 = System Information cleanmgr = Disk Cleanup ntbackup = Backup or Restore Wizard (Windows Backup Utility) mmc = Microsoft Management Console excel = Microsoft Excel (If Installed) msaccess = Microsoft Access (If Installed) powerpnt = Microsoft PowerPoint (If Installed) winword = Microsoft Word (If Installed) frontpg = Microsoft FrontPage (If Installed) notepad = Notepad wordpad = WordPad calc = Calculator msmsgs = Windows Messenger mspaint = Microsoft Paint wmplayer = Windows Media Player rstrui = System Restore netscp6 = Netscape 6.x netscp = Netscape 7.x netscape = Netscape 4.x waol = America Online control = Opens the Control Panel control printers = Opens the Printers Dialog
internetbrowser
type in u're adress "google", then press [Right CTRL] and [Enter] add www. and .com to word and go to it
For Windows XP:
Copy. CTRL+C Cut. CTRL+X Paste. CTRL+V Undo. CTRL+Z Delete. DELETE Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE Copy selected item. CTRL while dragging an item Create shortcut to selected item. CTRL+SHIFT while dragging an item Rename selected item. F2 Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW Highlight a block of text. CTRL+SHIFT with any of the arrow keys Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys Select all. CTRL+A Search for a file or folder. F3 View properties for the selected item. ALT+ENTER Close the active item, or quit the active program. ALT+F4 Opens the shortcut menu for the active window. ALT+SPACEBAR Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4 Switch between open items. ALT+TAB Cycle through items in the order they were opened. ALT+ESC Cycle through screen elements in a window or on the desktop. F6 Display the Address bar list in My Computer or Windows Explorer. F4 Display the shortcut menu for the selected item. SHIFT+F10 Display the System menu for the active window. ALT+SPACEBAR Display the Start menu. CTRL+ESC Display the corresponding menu. ALT+Underlined letter in a menu name Carry out the corresponding command. Underlined letter in a command name on an open menu Activate the menu bar in the active program. F10 Open the next menu to the right, or open a submenu. RIGHT ARROW Open the next menu to the left, or close a submenu. LEFT ARROW Refresh the active window. F5 View the folder one level up in My Computer or Windows Explorer. BACKSPACE Cancel the current task. ESC SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.
Use these keyboard shortcuts for dialog boxes:
To Press Move forward through tabs. CTRL+TAB Move backward through tabs. CTRL+SHIFT+TAB Move forward through options. TAB Move backward through options. SHIFT+TAB Carry out the corresponding command or select the corresponding option. ALT+Underlined letter Carry out the command for the active option or button. ENTER Select or clear the check box if the active option is a check box. SPACEBAR Select a button if the active option is a group of option buttons. Arrow keys Display Help. F1 Display the items in the active list. F4 Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE
If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts:
Display or hide the Start menu. WIN Key Display the System Properties dialog box. WIN Key+BREAK Show the desktop. WIN Key+D Minimize all windows. WIN Key+M Restores minimized windows. WIN Key+Shift+M Open My Computer. WIN Key+E Search for a file or folder. WIN Key+F Search for computers. CTRL+WIN Key+F Display Windows Help. WIN Key+F1 Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L Open the Run dialog box. WIN Key+R Open Utility Manager. WIN Key+U
accessibility keyboard shortcuts:
Posted on Oct 19, 2008
How do i change my volume and where is the fn key in this keyboard
    Is it possible to control the master volume with some keyboard shortcut? I would prefer it to be without a use of some additional software.But if it isn't possible then the software should be pretty light-weight and not consume a lot of CPU/RAM. Thank you for your help.
    PS: I DON'T intend to buy a multimedia keyboard for that.
    Yes,you can create a Master Volume Shortcut and also assign a Shortcut Key.
    Right click on a empty area on desktop, and click on New and Shortcut.
    Paste the following in to the location of the item area:-
    %windir%\System32\SndVol.exe -f 49825268
    Click Next button and give a name to the Shortcut and click Finish.
    Now You right click on it and select Properties.
    Click Shortcut tab.
    Assign your desired shortcut key like F8 or F9 in the Shortcut Key area.
    Click OK/Apply.
Is There Keyboard Shortcut For Volume Control
Mar 08, 2015 | ASUS KB73211 Wired USB Keyboard OEM
Facebook login problems
If you are on a windows PC and on the Facebook screen you can use a keyboard shortcut to increase the font size for the page. The keyboard shortcut is to press the Ctrl key and the + key on your keyboard simultaneously until the font increases to the desired size. If the font becomes too large, the Ctrl key and the - key will shrink the text.
Aug 10, 2014 | facebook.com Computers & Internet
No Keyboard Access
Hi , some laptop have separate keyboard and mouse access key,
try to find it on key board and press it with or without <fn> key
some laptop support keyboard shortcut and if you know the shortcut
win 7&8>start >type on screen keyboard find it and double click and try to press the shortcut key
some laptops use some 3rd party software try to find it on start all programs
if you have problem with it try usb mouse and key board
if you still face problem with it maybe you have some hardware issue with your key board so try to send it to certified repair shop or ask from toshiba website or online care
Dec 15, 2013 | Toshiba Satellite(R) L655-S5157 Laptop...
I want to change what a key types e.g. the numeral 2 key has the @ sign but you need to use the ctrl key to get it. I want to use the shift key to get it.
Create a shortcut
Open the folder or directory that contains the program you wish to create a shortcut for.
Right-click on the program and click Create Shortcut.
This will create a shortcut named "Shortcut to <your program> in the directory you are in. If you wish to rename this shortcut, right-click the file and click rename.
Once the above steps have been completed, you can copy or cut this shortcut and paste it anywhere to execute this program.
Assign shortcut key to that Windows shortcut
Once the shortcut has been created to assign a shortcut key to that Windows shortcut follow the below steps.
Right-click the shortcut and click Properties.
Click the Shortcut tab.
Click in the Shortcut key box and press a letter. For example, if you press "p" the shortcut key will automatically be made Ctrl + Alt + P. Which means if saved when pressing Ctrland Alt and "P" all at the same time will run that shortcut.
also
http://www.snapfiles.com/get/mapkeyboard.html
freeware
MapKeyboard enables you to remap your keyboard and alter any key to function as a different one or optionally disable it as well.
The program can be quite useful for laptop users and people with keyboards that differ from the standard
hope this helps
Aug 22, 2012 | HP Computers & Internet
I was assigning new products to my m202 keyboard however I accidentally assigned a product to the PLU list key. Is there any way to remedy this
Create a shortcut
hope this helps
Jun 07, 2012 | Computers & Internet
How to create hot key
Right click the browser icon on your desktop and select properties.One of the tabs should say "Shortcut."
Under the shortcut tab is a text field called "Shortcut key."(1) Click on the field and then (2) press the key on your keyboard you want to associate with the shortcut.
Your shortcut key will be Crtl + Alt + Key.
This solution works for Windows. Some key combinations can not be used. You can find those here.
Feb 11, 2012 | Microsoft Computers & Internet
Re HP wireless Elite keyboard (RK713A): I am using it with a Sony notebook (Windows 7) - can the F9-F11 keys somehow remapped to something useful eg. open Outlook etc. ? (Registry?) Thanks!
Here's the Microsoft way - note that all Win7 keyboard shortcuts begin with CTRL-ALT-(your shortcut key here).
Note also that a desktop shortcut must already exist to which to be invoked by the keyboard shortcut.....
http://windows.microsoft.com/en-us/windows-vista/Create-keyboard-shortcuts-to-open-programs
The way the Internet community does it:
www.autohotkey.com - freeware - allows you to "package" a number of
keystrokes into a "keyboard macro" and invoke that macro thru
the use of a "hotkey." Keyboard macros can be as short as one
function key, but some Win7 function keys cannot be ove-written, such as F5
Dec 04, 2010 | HP CPQ175KB Keyboard
Keyboard doesn't have a windows key, how do I program shortcuts ?
I would try using SharpKeys to assign some other key on the keyboard to be your Windows key. http://sharpkeys.codeplex.com/Wikipage
Jun 21, 2009 | Logitech Cordless MediaBoard Pro Keyboard
Windows+E doesn't open Windows Explorer on my keyboard
Check to see that other Windows+shortcut keys work, such as Windows+M. If this fails, you know your key is either defective, or Windows has detected your keyboard incorrectly (it happens sometimes)
To check this, go into control panel, and ensure its listing as a Windows Keyboard, at least 101 keys, and not something like an 88 Key keyboard
May 01, 2009 | Office Equipment & Supplies
Shortcut
Not sure why you want a keyboard shortcut, but you can create a quick launch, desktop, etc.... shortcut by opening "My computer" then right clicking on it and selecting "Create shortcut" and then just pasting it where you want it. I hope this post helps?
Good luck.
Feb 15, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
566 people viewed this question
David Payne
David Payne
