ERROR CODE E001 - Office Equipment & Supplies
  • 76 Answers
This is normally due to the laser unit depending what machine it is!
Posted on Oct 20, 2008
  • feeldebones Oct 21, 2008
    sorry this is down to the fuser unit!
How to solve the error code E00001-0010 canon iR-ADV 6255i
Fuser noise and intermittent E001 code error :
The upper fuser roller section makes a noise and intermittently error code E001 occurs.
Nov 03, 2016 | Canon Office Equipment & Supplies
How can i fix the error code 000001-00002
Assuming you have a copier or laser printer, this site:
Thread Canon IR 2200 error E000001 002
suggests:
Some errors can just come up and you can just clear them and if everything works fine you don't need to worry about calling a tech. However if clearing it doesn't make the error message go away or you have problems emerge with the copier then you do have a problem.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Jan 11, 2016 | Canon Office Equipment & Supplies
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Canom imagerunner 2520 error e000001
the e001 is error for the temperature rise detection in fixing unit. There are more sub codes that I need to know for precise troubleshooting. i.e. E001-000 or E001-001 or E001-002
But if there is no fault in components, you can try to reset it in service mode.
Procedure:
additional function, then press 2 and 8 then go in clear by pressing scrolling, then go in engine, then choose ERRCLR and then turn off and on the copier.
If these doesn't helps you need to replace fixing film unit.
Aug 29, 2011 | Canon 0000A011BA Copier
Error code E001; machines switches itself off after displaying this code. What does this mean?
Your in luck, Canon really did not change there error codes from way back then..... A E001 means you have a problem with the fusing unit. You may have a blown thermal fuse or one of the heatting lamps or you may have a bad thermister. It may be one or all of them. Did you try to rest the error code?
Mar 30, 2011 | Canon NP 6650II Copier
E001 error code on canon ir400
the fixing assy is faulty the halagon lamp has blown. this would have to be replaced and the error to be reset in service mode this requires a technician.
Sep 21, 2010 | Office Equipment & Supplies
Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
Nov 09, 2009 | Canon imageRUNNER 600 Printer
E001 switch off the machine and on again
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
Sep 09, 2009 | Canon imageRUNNER 400S Copier
Error codes
E000 and E001 is due to the laser unit, I can explain in more details.
E014 is due to the Dc motor failing
Hope this helps?
Oct 17, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
142 people viewed this question
k24674
