Question about Garmin zumo 550 GPS Receiver
Zumo wont accept 12v charge from car or bike !
Can anyone help please, from the cigarette lighter or in its cradle it wont take a charge
    Scholar:
  • 174 Answers
Did you drain the battery completly? Have you tried another battery yet? I've come across this issue once, seems the owner drained the battery completly. Leaving it hooked to the mains with the mains charger for almost a day did solve the issue. I'd try a new battery first.
Posted on Oct 27, 2008
I have 765T Garmin. It won't charge from cigarette lighter. REturned first Garmin to company, got a "newly refurbished" unit, so it's different. Still won't charge from car. Cable lights up,...
if its an oem garmin charger and the green light is on and still wont charge, then the problem is most likely the power port on the back of your garmin...if its not the factory charger, get one for a garmin..that should solve your problem...if not, let me know
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Nov 08, 2010 | Garmin nuvi 765T GPS Receiver
Question: My Garmin just went dead, but if it is still in the cradle being powered by my cigarette lighter could it still be my battery, or is it some thing much worse..?
it is probably the battery because you can run the units without the battery in as long as it has a power source it will still work
Jul 04, 2010 | Garmin zumo 550 GPS Receiver
My garmin charges with my computer but stopped charging in the car
The most obvious answer is a possible blown fuse in the cigarette lighter socket or the in the tip of the charger plug. Most charger plug fuses are accessed by unscrewing the metal tip. Check both for good fuses.
If this doesn't solve the problem, make sure the points of contact between the charger, cradle and GPS are all free of dirt and grime. Don't forget to vacuum the cigarette lighter socket - especially if it is used as a lighter, too.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
The cradle no longer charges the garmin in my vehicle. It's not charging anymore. Nuvi 750
Sometimes, if the Garmin GPS battery is allowed to fully discharge, it would require charging directly via USB cable connected to a PC or Mac before it would accept a charge for the cigarette lighter again. Try connecting this way for 4 - 8 hours or more before going forward.
Check the cigarette lighter plug in another "known good" lighter socket / vehicle to help rule out a defective socket. A socket without power indicates anything from needing to change a "simple to replace" fuse - or a bigger problem - damaged wiring in the vehicle (if the socket is used to light cigars & cigarettes - vacuum the socket out to remove ash and tobacco that may collect inside). Trying the GPS elsewhere helps eliminate possible problems with the socket. If it doesn't work elsewhere, depending on the plug that goes into the socket, it too may have a built-in fuse. Check the plug for an exposed fuse - or see if the tip unscrews to provide access to a fuse inside. If unsure, the tech Support people at Garmin are a great source for free help.
Lastly, dirt or grime on the "cradle to GPS" connection or "cable to cradle" connection could be causing the failed connection. In short - carefully inspect all points of connection and remove any deposits found.
Sep 16, 2009 | Garmin GPS
Porsche cigarette lighter is bigger than standard cigarette plug
Found a cigarette lighter assembly that is the standard DIN/SAE size that is a direct replacement for the one in my car.
Aug 31, 2009 | Garmin zumo 550 GPS Receiver
Speaker doesn't work when using Garmin on my motorcycle but it works in my truck. got any ideas?
there is a speaker on the cradle for the car and none on the bike cradle probably due to the exposure to the elements when on the bike and i think the Zumo must be powered from the bike for the speaker on the Zumo to work when riding.
May 23, 2009 | Garmin zumo 550 GPS Receiver
Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
Zumo not accepting a 12v charge
Mike,
My friend had the same issue as you mention. Puts his Zumo 550 on his bike only to have it discharge in a few hours. He later found out the pins on his motorcycle cradle had corroded and therefore was not keeping the Zumo charged. His solution was to purchase a new motorcycle cradle at about $100.00 CDN.
Oct 20, 2008 | Garmin zumo 550 GPS Receiver
Zumo Wull not charge form bike mount
Experience the same problem with my Zumo 550. Told by service advisor @ Radio World that this is a common problem. Unit needs to be charged on the DC charger occasionally. The motorcycle mount and car mounts, I was told, does not charge the battery on these units, but maintains a charged battery.
Oct 19, 2008 | Garmin zumo 550 GPS Receiver
My garmin zumo will not turn on.
Have you also held the power on button for a couple of minutes, with the battery installed, and without the battery installed. There is an issue with the garmin dying, some cases a new battery helps, other cases, just leave the battery to charge for several hours, worst case is that you have to ship it to Garmin. I had a couple of Dead Zumo, however, removing the battery for several minutes, putting it back and clipping the zumo in the car holder did the trick for me. I also have a spare battery and allen wrench, just in case...
May 26, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
139 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
