Question about MSI K8MM-V Motherboard
Mother bord not a display
No display for motherbord ram and procesar are tested ok how to cheak bord.
  • tazwegion
    tazwegion May 11, 2010
    I'm guessing you tested the RAM & CPU on a different motherboard?
    * have you cleared the BIOS/CMOS settings on this board?
    * what is the physical condition of this board ie. mis-shapen components?
    * what is the history of the board (pulled from working system)?
  • Thomas F. Schneider May 11, 2010
    You have installed or turned on the motherboard driver from within the bios setup routine for you "onboard video? The other option turns on your AGP slot for a AGP video card.
    http://www.msicomputer.com/product/p_spe...
    New Friend:
Mother board not start cpu fan
Posted on Jan 18, 2013
Mother board
not display show
Posted on Dec 01, 2009
My mother bord intel 845gvsr ram and procecer is ok and motherbord has beep of ram but instal the ram no beep and no display and remove the ram but bord on the cantive beep how to cheak a motherbord plees...
try to use other memory or processor which is functional, then insert it to your motherboard, if the problem still exist then maybe the motherboard will be the problem. If motherboard would be the problem try washing it with the use of water and powder soap, then if you have a blower dry it until the water of the board dried or just hung the motherboard and wait atleast 3days before you assemble the parts. NOTE : Remove the cmos battery before you wash the motherboard, because it will cause a broke of your board, or if you have some extra money the safest way is to buy a new one, but first try your old parts into other motherboard which is working, if you confirmed that the motherboard is the problem then thats the time you will do those steps or replace your motherboard. Hope it help you. thanks
Aug 25, 2011 | Computers & Internet
My emachine T3958 is running fans and drives but the monitor and the keyboard are not getting any signals. How do I troubleshoot this problem?
For that first open cpu cabinet then refix RAM memory. Find cmos cell on motherbord pull cmos cell for 15minutes then refix so all settings goes to factory defaults. Remove pci cards from mother bord then check display. Open processor fan and porcessor remove dust from all parts.]
Let me know if you need more assistance. Thanks.
Oct 23, 2009 | E-Machines eMachines Desktop PC
MSI N 1996 MOTHERBORD DO NOT START SMPS OK
Hi this might not be a motherboard problem. Remove the memory card and clean the contacts and reinstall it. If this will not work for you replace the memory card with the same type you have in your computer. Hope this info will help you solve the problem
Aug 15, 2009 | Intel Motherboard
Motherboard
open cpu cover and check on mother bord u find model number on it.like for example D945 or etc.
Check on motherbord u can find it.
Apr 22, 2009 | Computers & Internet
have you a graphics card you could use? if so you could try re-installing graphics drivers for the onboard graphics.
if not, to test the video output you would need a post test card, available for approx £15. this would enable you to test your motherboard completely.
Feb 25, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No display
It is normal for a board to beep if there isn't any RAM in it. This is due to the POST process checking to see if everything is all right, and finding no ram.
to check the board, ll you can do, is make sure the CPU is compatible with the MB, also try putting an graphics in the machine. If it displays, great! Then you know your onboard graphics are not woking or disabled in CMOS. If it doesn't show anything, and you know that the RAM is not faulty, and the CPU is compatible, and you plugged out all CD-Roms/HDDs, then either your onboard graphics are faulty, or your motherboard is dead.
(You did test it with another screen didn't you?)
Good Hunting!
Jan 07, 2009 | Intel D845GVSR Motherboard
Intel 845gvsr motherbord nos display.
with no ram you will get beeps that confirms your processor is working (as it cant detect ram) you could be using the wrong speed or type, also as Ghoaliass stated, if your using a couple of modules try one at a time, if it fails on the first, remove the stick and try anther one and so on until you at lease get a bios screen :)
Hop-e this helps,
XBM
Nov 26, 2008 | Computers & Internet
check different working ram, also take out the cpu fan then place it again, then check
Oct 19, 2008 | Intel D845GVSR Motherboard
Please help
check mosfet ic 7338 it's burn in near by pin no1 replace it
check serial bank registance all near by ram slot value is 10ohms
Mar 29, 2008 | Intel D845GVSR Motherboard
MSI K8MM-V Motherboard Logo
406 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
