Sony KLV-26U300A + xBox 360 setup help needed!
Just need a little bit of advice. I've got the Sony Bravia KLV-26U300A television and I need help in getting my xBox 360's sound to work properly. Here's how I have my set-up:
AV1 - Wii Console
AV2 - PS2
Component 1 - xBox 360 (using the HDTV option)
PC - My Laptop
I have all of these units plugged into the correct sockets and everything works perfectly through the television... unit I add my Logitech Z4 speakers into the mix.
I'm using the AV output on my TV (there's only one, and it's a composite connection) to run to my Z4 speakers. I have to convert the RCA connection to a 3.5mm stereo connection to for it to work and so far only my Wii and PS2 will have anything to do with it. I've tried some of my own troubleshooting and have worked out that both of my component connections don't seem to run through the output connections on my tv. It's so frustrating! I have all green, red and blue connections plugged in as well as the white and red for audio but it still won't run though to my speakers. Double adaptors aren't working for me either (and even if they did I don't want to use them darn-it!). If I plug my xBox 360 into the standard AV composite connections everything works well but that doesn't leave me any ports for my other consoles. Grrr! I've also tried switching from HDTV to normal TV on the xBox's AV cable but even that doesn't work.
Any help would be fantastic! Is there a setting on my xBox 360 or on my TV that I'm not using? Help help help!!
SHEARCH eeprom memory dumps
Posted on Jun 21, 2009
Klv 26u300a sony bravia TV Power board is good. no
The fault is with the power board itself.
Oct 02, 2013 | Televison & Video
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
My sony bravia model nos.klv-26S400A IN5 its lcd
I don't have a listing for your exact model, but a similar one has its LCD panel costing over $600 net. Check with a local servicer for parts availablility as the model I used has the panel no longer available. It is possible that a replacement panel won't be available for you either.
Hope this helps a bit,
Apr 29, 2010 | Sony BRAVIA KLV26S200 26 in. LCD TV
My Sony Bravia KLV-40U100M has audio but the screen is black. No picture. Could it be the lamp? The unit is only a little over 2 years old
No,this tv a LCD not a DLP.The LCD inverter board is dead.Must replaced to get picture back.The board is usally a long board.Tries, to buy the board.
Jan 15, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
There is no picture and no sound on my sony bravia KLV-40u100m
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps
Jan 01, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Bravia KLV-S40A10 HDMI input
I agree with your solution and you are correct in that you lose very little quality by using component instead of HDMI. there are A/V receivers that transcode HDMI inputs to component; as far as I know that's the only other option
Dec 25, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Getting my Sony TV to operate in 1080i.
Asumming you have set the Xbox at 1080i in the video settings and you have used all the four component lead ends, (apart from the yellow video end, as you won't need this) it should work.
Jan 11, 2007 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Televison & Video Logo
555 people viewed this question
Top Televison & Video Experts
