Question about RCA F27665 27" TV
Color rainbow in picture
The picture comes in and sound works fine. While the picture is displayed a rainbow of colors starts from center of screen and comes down half way and branches left and right.
  • Anonymous Dec 23, 2007
    have the same problem
If it is a rear projection it probably has cob or spider webs in front lights lenses or mirrors eaasy fix open clean carefully
Posted on Nov 11, 2007
  • 1,476 Answers
Your problem sounds like someone got a magnet too close to the CRT. This can be removed with a degauss coil (which you probably do not have) or it will eventually go away if your built in degauss circuit is working. Everytime you turn on the set the circuit degausses the crt so colors can be displayed properly. If the circuit is not working you will need to have a tech repair it.
Posted on Jun 23, 2006
4 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: RCA MM36100 color problem
sounds like you have a deguassing problem with your TV .. have the repair person bring out a deguassing coil and see if thsat helps.. This will only be a temp repair as you will have to have the problem that caused this to be fixed. good Luck
Posted on Aug 12, 2006
  • 4102 Answers
SOURCE: Has sound, no picture, just color
usually if the tube has gone you will get no sound and all you will get is the telly on standby so the best thing to do is take it to repair shop and they should tell you for free what is wrong but usuall it costs more to repair than it does to buy another one sorry i couldnt be any more help
Posted on Oct 29, 2007
  • 15 Answers
SOURCE: color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Posted on Jul 23, 2010
Vizio 50" Plasma VP50HDTV20A comes on with sound but screen shows rainbow colours before pictures comes and picture is blurry when on and not in full color. All the inputs have the same display.
If this is an old Plasma TV that you picked up somewhere, it may just be too old. Plasma screens degrade over time.
New plasma TV's are not common anymore, so I am assuming this one has been around for awile.
If it is new, take it back to where you bought it.
Apr 10, 2017 | Vizio Computers & Internet
Vizio 46lfhdtv20a verticle rainbow line down the screen. picture start playing and after a while the color line cover the screen
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 29, 2016 | Vizio VO47L 47 in. LCD TV
Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
May 30, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
this is the conversion IC chip that controls the centering of the colors , vertical and horizontal
it needs to be replaced , $300 to have a tech come out , $30 for the part
Sep 04, 2008 | RCA P52937 52" Rear Projection Television
Color displays in rainbow effect
Remove any speakers or electronic items that are near the set.
Jun 27, 2008 | Televison & Video
Bad color
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Mar 15, 2008 | Panasonic CT-32SX12 32" TV
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
Same as other poster: Player only plays black and white
It sounds like the circuitry which actuates the color drives for the screen are not working, this would ba analogous to adjusting for a B&W picture on a color TV you have color but the screen shows black and white. I would get a schematic for this set and measure the voltages on the color processor that connects to the screen since you know that the external jack has color. If possible I can help you troubleshoot this, if you need me to help out.
Aug 19, 2007 | Durabrand PDV-705 Portable DVD Player
Rainbow of color when viewing DVD
TRY TO MATCH THE SYSTEM OF THE TV AND DVD. IF ITS NTSC SET IT BOTH WAY OR IN OTHER SYSTEM
Jun 06, 2007 | JVC AV-32120 32" TV
RCA F27665 27" TV Logo
409 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
