I have a Canon, Pixma MP520 and an error message is coming up 6A80 Printer error has accurred. Turn off power then back on again. If problems persist, see the manual. I can't seem to fix it, can you help
  • 4 more comments
  • j13_urs Oct 28, 2008
    I have a canon pixma iP4600 and the "service error 6A80" came up the second time I tried to use the printer. Tried switching on and off, switching PC off etc but no luck.
  • Curlycat Nov 18, 2008
    I have a Canon Pixma MX700 and an error message is coming up 6A80. I looked at print head containing ink tanks. It is not moving from the left to the middle when you open it. Still stuck. I believe that it causes the error 6A80. We need to contact Canon Representatives. Is another way to fix it?
  • curlie508 Jan 17, 2009
    Just received my new Canon PIXMA MP620.  When asked to push on button I get same message/error code: 6A80 "Printer error has occured.  turn off printer then back on again.  If problem persists. see the manual"  The manual does not address this problem.  Can you help?
  • dvius Jan 20, 2009
    I bought the Canon mp620 a few weeks ago. Last night after printing 3 sheets of paper, I noticed the yellow light flashing. The error code was this 6A80. I was instructed to turn off the power and then turn it back on again. This did not work.
    I went to Canon's support site and it says for this error, I need to have the unit repaired. Is there a user serviceable way to fix this?
  • Anonymous Mar 30, 2009
    I have same error 6A80 and am trying to fix it at the moment. Can anyone help. DOT
  • slevings1 May 06, 2009
    I have a mp630.I was printing a page and the paper jammed. The printer started making a metalic grinding sound and now I get an error 6A80 message and refer to the manual but the manual doesnt address this problem. Can anyone help with this problem?
Put the colors out of the printer and do it on and off a few times and put the colors back in and a few times on and off again, that was working on my 6a80 problem.
Greetings Pieter.
Posted on Sep 03, 2009
Error 6a80
Sheet feed unit (QM3-2647)
- Logic board (QM3-2599) PROBLEM
Oct 19, 2013 | Canon PIXMA MP520 InkJet Printer
My Canon MP520 has a 6A80 error and now the printer head is also stuck on the far right side.
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
Feb 03, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Hi, I have a "dead"
APP position error or Error Code 6A80
Condition: An error occurred in the APP motor.
Problems and Solutions:
  • Check for foreign material or paper debris around the purge drive system unit
    - remove foreign material.
  • Check for foreign material or paper debris around the ASF unit
  • If other solution fail, replace one off the following part
    - Purge drive system unit
    - Logic board
for more info visit: http://pcmediks.blogspot.com
Dec 28, 2010 | Canon Pixma MP450 All-In-One InkJet...
Canon MP520 error message 6A80 - Have tried switching on and off at wall no help. Judy
May 31, 2010 | Canon MF8180C Color Laser MFC Printer
Canon MP520 Error 6A80 has occurred -
Hi @ all,
i got the same problem. I did some google search and found the tip below:
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
But doing this another menue appeared and i pressed okay and swithched the printer off. I did 3 times and finally the error disappeared. Now i am really happy because my printer is still working. Hope it will help you to fix your problems with this error.
Nov 03, 2008 | Canon MP520 All-In-One InkJet Photo...
Message error 6A80. Comes up with "printer error has ocurred. please turn off printer then back on again. if problem persists see manual" manual has nothing in it.
Jul 27, 2008 | Canon MP520 All-In-One InkJet Photo...
Error cannon pixma mp520
Turned it on, off many times as instructions suggest,
etc no dice. Reinstalled software, did everything including giving it a few taps.I was very seriously ready to buy a new one and trash this one, even checking flyers. I read where so my are having this same problem.
In my anger I started pushing all the buttons randomly and suddenly the green light stayed on.
Voila the crazy thing works fine again. Must have reset the glych somehow ?(I have no idea how)
Give it a try before giving up, who knows!!
Jun 03, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
Apr 12, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Brand new PIXMA MP520 just connected up. Having just installed the print head and the ink cartridges, now getting message when turn on the printer. >>> 6A80 Printer error has occurred. Turn...
I opened the printer, and pushed gently on the lever that holds/releases the print head, and this seemed to release whatever was stuck. After this the print head moved freely on turning on the printer/copier.
Mar 05, 2008 | Computers & Internet
1,223 people viewed this question
jasbo
jasbo
