Question about Cameras
I seem to be getting double exposure on most films, I brought this camera new in Duty Free New Zealand in 2001 it went well until 2003
    Problem Solver:
  • 5 Answers
Hi
Sounds like the continous shooting option has been enabled.
I would check this first.
Hope this helps
Posted on Oct 19, 2008
Instax mini 8
horizontal varde owar size sony tv model no kv-hv21f83a
Dec 25, 2013 | FUJIFILM instax mini 7 Digital Camera
I have a 36 exposure film in the camera with 25 pictures taken and I want to remove the film without taking more photos. How do I rewind?
To rewind the film mid-roll, press the two film rewind buttons simultaneously for one second. The two buttons are marked with a red film symbol, and double as the Auto Exposure Bracketing button to the left of the viewfinder and the Aperture/Exposure Compensation button to the right of the control panel.
The film is completely rewound when a blinking "E" shows in the control panel.
Sep 08, 2010 | Nikon F65 35mm SLR Camera
Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
My Pentax SPII shoots blank images
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
Jan 31, 2010 | Olympus Stylus 850SW Digital Camera
"ME" flashing on data screen
Hello
Thank you for using
FixYa for your problem
Muilt Exposure mode i think it is
Been a little while sorry
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 28, 2009 | Minolta Maxxum XTsi 35mm SLR Camera
How to change film in Nikon N 2020
Press the R1 and R2 release buttons. Pull up on winder handle until the back of the camera opens. Continue the pressure on winder handle until you have removed the film canister. Insert new film canister. Pull leader across winder assembly. Close camera back. Press exposure button. Press winder handle in towards camera b
Oct 13, 2009 | Nikon Photography
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Forget how to take double pictures.
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 31, 2008 | Vivitar V3800N 35mm SLR Camera
Film advance
I bought a seagull 4a-105 camera and the film advance never seems to be consistent. Often times the frame counter numbers are not centered in the
viewing bubble. When I go to have the film processed, I have had as many as six to seven frames either double exposed, or no exposure in the frame. The
best that I have managed out of 12 frames is 8 frames done correctly. I followed the directions and threaded the film to where the arrows align with the marks, but still the problem persists. Is the film winder the culprit? If so, how can I repair
it? The camera cost me $217 new, and I can't justify spending $200 to repair it when I could buy a used Yashica online. Any help or advice is appreciated.
Apr 21, 2008 | Shanghai Seagull 4A-105 Medium Format...
Turn it on
Actually, you don't have to "turn on" the Vivitar V3800N. Just be sure it has working batteries in it (takes two small alkaline button cells, unscrew the cover on the bottom with a coin--put new cells into the holder with the + side up). If the batteries are working, when you press the shutter button halfway down, you should see an LED light up in the right side of the viewfinder. This is the readout for the exposure meter: a red + indicates overexposure, red - is underexposure, a green dot means you've got the exposure correctly set. You just change the shutter and aperture settings until you get the green light, then shoot. When you load film, you also need to set the ISO film speed setting. Pull up on the outside ring of the shutter speed dial and turn it until the number in the window is the same as the ISO number on the film you are using. The batteries, by the way, only power the exposure meter. The shutter is fully mechanical (just like in the good old days), so you can use the camera without batteries if you have a separate exposure meter, or if you can estimate exposure. Film loading is about like any other 35mm manual camera: pull up on the rewind knob to open the back; insert the new cassette of film on the left and pull the film leader out a couple inches and hook the film to the takeup reel on the right. Move the film advance lever a bit to be sure the film is firmly hooked onto the reel, then close the back. Wind and shoot three shots to get the exposed film leader out of the way, and then start shooting. When the film is finished, press in the rewind button on the bottom of the camera and rewind the film into the cassette before opening the back of the camera. Good luck--these are pretty good little cameras. We buy a lot of them for the photography program where I teach, and I've only ever had one with a problem (meter was bad). The lenses are quite good, and they are "K-mount," which means that any Pentax bayonet lens, and gazillions of others with this mount, will all fit. --Michael R. Sawdey
Sep 03, 2007 | Vivitar V3800N Zoom 35mm SLR Camera
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
