Question about Electronics - Others
I have a Honda ew171 with welder Gen.electronic start EBI-1109 with a GX340 Honda motor that is 337 c.m.c GC05-2063656 EY7, Last. time I used it was October last year and it worked. fine got it. out today and could not get it to run skill saw,,or. even a. light nothing could you help me out please thank,s Dennis Robinson
usuallyno
  • 13 Answers
SOURCE: acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Posted on Aug 23, 2007
SOURCE: Car won't start. Makes a sizziling or "zzzz" noise when key is turned on.
Had car checked again at dealership. They stated they checked the charging system and battery would not hold a charge. Found a bad cell in the battery. The alternator was working fine. Battery replaced. Car has been starting fine since battery replaced.
Posted on Oct 23, 2008
  • 7 Answers
SOURCE: hobart engine drive welder has no power out put
i took an old trickle battery charger,6 volts and energize the armmiture,all so called polarizing,google it ,shows how also
Posted on Feb 04, 2009
  • 234 Answers
SOURCE: Craftsman air compressor will not start
I am assuming that there is no air in the machine now. Otherwise it will not turn on if there is enough pressure in the tank.
If it will not start at all, the on/off switch on the pressure switch may not be turned on or it is defective.
You can also check the reset switch on the motor (red button).
These are very simple setups and it shouldn't take too long to troubleshoot.
Posted on Apr 18, 2009
SOURCE: I have a fimco pump on a 25 gallon sprayer. It is
at the end of the pump little square box with one pillpes head ,take it off and there is another screw in there turn it until it works,
Posted on Jun 09, 2009
Honda GX390 Generator not performing under load.
a GX390 Honda Motor but the used generator stator can be different cannot give more suggestions then measuring the circuitbreaker it can be broken the suggestion 60 mf capacitor can have trouble and electronic modul and bridge rectifier for some other dc connectors the coil diodes inside the stator. several options to go.
Jun 21, 2017 | Honda Electrical Supplies
My Honda gx340 is revving high all the time Can some one tell me y thank you
should be an internal govenor on a plant unit like that
there is a thicker than normal metal rod running off the carby to the motor and that is where you adjust the govenor
cant find good instruction how that governor is adjusted ..if adjusted the wrong way it will rev out may even throw a piston
then check carby idle adjustment
should hunt (rev up and down only slightly )as load changes
you tube
11hp Honda GX340 cold start
https://www.youtube.com/watch?v=i3_v68__X5o
Honda GX340 HGI Partsf21c43c2-def4-46c5-9224-ed46701c0c01.jpghonda-gx340-revving-high-all-time-some-qkhmqzcwln4tohiil4ndbnz4-2-2.jpg
Jun 22, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
What RPMis the max torque
the chart shows figures of 10.7 hp-8.0kw with a torque of 19.5 ft/lbs- 26.4nm at 2500rpms ( max net torque)
the chart shows gx390 is 11.7hp (8.7kw) but the torque is the same as the gx340
you can get these figures from world. honda com or by going google and typing in--torque range of honda gx 340 motor at max rpms
10 hp engines running at 2500 rpms will be good for gensets of 5kw continuous out put as most makes run that size engine
Apr 20, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Have honda gx340 11hp pressure washer and gas keeps going into oil?
Excessive fuel entering the inlet manifold, carby needle and seat not shutting of fuel flow , remove and clean fit new gaskets and needle and seat if worn.
Jul 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Pressure washer rope recoils to quickly when pulling to start
I'm sorry if I'm not quite understanding the question.
Are you saying the rope MAY be too short and so the amount of pull available is also shortened?
Feb 23, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
I have a Honda EP5000 Generator set with GX340 engine, the problem is that too much oil is discharging from OHV cover into the Air Cleaner via that rubber pipe and spilling out from it. Engine also smokes...
Hi,the quick,but not final fix for this issue is to use a oil additive similar the one-s from the cars,but make sure you are using the one required by the fuel type.The engine is worn out,needs overhaul,soon or later.Good luck,regards
Nov 01, 2014 | Honda 6kw 120/240v, Gx340, Recoil Start...
Why does Honda GX340 die immediately despite fresh gas, cleaned carb, and new plug?
Perhaps you haven't adjusted the carburetor correctly.The fuel supply orifice could be still plugged . Recheck the carb.
Aug 27, 2014 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Multiquip generator wont start
Multiquip GA-6HEB Honda motor will not make a complete revolution on the engine gets stopped goes back the other way and the same thing.
May 13, 2014 | Multiquip GA6HA Recoil Start 6000 Watt...
How to replace valve timing gear in honda gx340 engine
Align crankshaft and balancer gear first. Rotate crankshaft and align timing gear. Alignment mark may be hard to see on crankshaft for timinig gear.
Jul 09, 2012 | Honda Gx340 Gas Engine 11hp Motor Pressure...
What kind of oil goes in the engine on my ew171?
Any good quality 10w-30 motor oil will work just fine...
heatman101
Sep 02, 2011 | Honda Electrical Supplies
Electronics - Others Logo
132 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
