Question about Akai Mpd16 Midi/USB Mpc-Style Drum Pad Unit System
Mpc 500 i need 2 get my mpc workin!!!basicly i deleted from the mpc hard drive(i saved into my computer first)i put nnew samples but nothing plays !!!whats the problem ?there is anything wrong tha im doing? help
  • Akai Master
  • 19,396 Answers
First ensure that you are saving into the right folder, on MPC HD and not into a subfolder, and that files are in correct midi format. Also ensure that connections to MPC are OK.
If connections and saved files are ok, then probably you need to reinstall Mpc 500software onto your computer, using disk provided with your Mpc 500.
Posted on Oct 19, 2008
  • Ginko
    Ginko Oct 19, 2008
    If connections and
    You can find software and manual download here.
Do you have cd or flop disc for a mator with 500 gb 5.1.2535.0
Devices like this should be plug and play with Windows systems. Assuming you're on a Windows OS you may have deleted the generic driver, what version of OS are you running?
Mar 20, 2014 | Maxtor OneTouch 4 500GB External USB 2.0...
My Samsung G2 Portable external hard drive, 640GB, when i am copying stuff unto it, it is very slow. I just got it new
If you're using a desktop try checking the speed of your USB thru bios setup. Here's a sample below, Change fullSpeed to HiSpeed.
1. To access bios setup, press Delete on your keyboard. 2. Look for the USB configuration. 3. Just change the settings on USB Controller Mode nothing follows. 4. Save and exit. pcsyke_53.jpg
Hopefully this Helps. Thank you for posting.
Jul 08, 2011 | Samsung G2 Portable External HX-MU032DC/...
How can the MPC 500 play the Samples on the Pads in real time?
You have to go to the sample edit page and move the start point to the beginning of the wave sample. Right now your start point is before the sample actually starts.
Oct 07, 2009 | Akai MPC-4000 Plus Production Center (w/80...
The 5500 doesn't recognize the files on my ipod, which are mainly cd's impoted to itunes, so i converted all the files to MP3 but it still isn't recognizing the files. what do i do?
Actually there are 2 possible solutions to your problem. When you plug in your Ipod or USB drive into the Denon HS5500 the machine will put a file on the drive called "Denon_DJ". This file needs to be deleted each time you add new mp3's to your ipod or usb device or your new files wont be shown.
The second has to do with what type of mp3 you are using and what sample rate it was created with.
For instance I record music with my computer and keyboards. I like to record in 96KHZ because it sounds so much nicer than 44.1k. Well the Denon wont read anything created with a sample rate higher than 44.1K . I downloaded a song from a DJ friend that was recorded in 48KHZ and made into a 196k MP3 file. The Denon wouldn't play it because it is not 44.1. Check your manual or check online.. the Denon reads 44.1k 320kbs and lower files only.. (Bad Denon)
You may also want to avoid what are called Variable Bit Rate files. Most files you download online are ripped at a variable bit rate. The Denon will play variable bit rate Mp3's .. But you will not be able to save cue points or save memos to the system. I found this out the hard way. So. I took all the files I had created that were VBR and put them into Audacity with the Lame MP3 plugin and set the bitrate to 320kbs and now I can save memos.. But everytime I put the USB flash drive into my pc and put new songs on I have to delete the Denon_DJ folder.. Its sad too because thats where the HS5500 stores it's playlist files... :( Bad Denon. They should have asked me to write the software.. xD
I hope that helped you..
Apr 12, 2009 | Denon DN-HS5500 Turntable
Akai MPC 4000 Plus
You could set the sample to "one shot" in the trim page or in the Program>KG Mix>Zone page.... it is currently set to "as sample"... i like to use the release to let the sample fade out as long as i like... its a lot diffrent from the old poly mono thing but i like it better overall... hope this is helpfull.
Apr 16, 2008 | Akai MPC-4000 Plus Production Center (w/80...
MPC 500 PROBLEM!!
you need to set your Parameters Params and make sure the you set enough bars for the sample.. if it cuts out you could try hitting the track button and putting the drums on track 2
Mar 15, 2008 | Audio Players & Recorders
Wave samples will no longer play
Try using audacity, it's free and can handle big files (as long as you have the RAM).
http://audacity.sourceforge.net/
Dec 18, 2007 | Seagate 160GB 3.5" External USB Drive 160...
Help
When youre in LOAD or DISK mode, does the mpc allow you to scroll through the cd? In what format are the samples. If the sample doesnt load, it wont play, but when selected, it should allow you to preview the sound. The 4000 allows users to import/load SND and WAV files.
The MPC4K should allow you to sample right out the box, but make sure you have the latest OS.
http://www.akaipro.com/support.php
try the 4k FAQ..
http://www.akaipro.com/supportfaqsMPC4000.php
It's also covered in the manual with you can download for free @
http://www.akaipro.com/supportdocuments.php#Z248
I know, who wants to hit a manual when you want to bang out....I'm a classic 2K owner, trust me I know, but sometimes the 5 minutes in checking the methods, saves you downtime, and gets you into funk mode quicker..
The 4k is also the first Mpc to come with onboard sounds, so check a preset, then check your cd, and if youre getting audio from the preset, then you know it's not the sound generator / synthesis chip. If you have a computer, try itunes or sound converter to switch the sound format, or look for a really nice low end application called CDXtract.
If youre banging out on halloween, youre my kinda MPC user.
Keep me posted.
Oct 31, 2007 | Akai MPC-4000 Plus Production Center (w/80...
Hard drive full cannot delete
JVC manual site
Download and install adobe reader, if needed
Right mouse click and "save target as" to save each manual to a file
May 10, 2007 | JVC Everio GZ-MG20 Camcorder
Akai Mpd16 Midi/USB Mpc-Style Drum Pad Unit System Logo
306 people viewed this question
Top Akai Audio Players & Recorders Experts
Michael Harrier
Vernon Taylor
 Grubhead
Grubhead
Are you an Akai Audio Player and Recorder Expert? Answer questions, earn points and help others
