Question about Kenmore 19233 Computerized Sewing Machine
E1 Error What is an E1 Error and how do I fix it? I have restarted and rethreaded the machine after getting this message and nothing will make it "reset". I was sewing and got the "stop for safety purposes" message and then subsequently the e! message after stopping. Now my machine will not do anything. I have been sewing for 22 years and have never encountered something I can't fix. Help!
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
Posted on Dec 27, 2006
After spending many hours on the phone with Sears, someone finally gave the manufacturer's phone number (1-877-739-4648)! Their help desk told me that an E1 error usually means that a fuse needs to be replaced. The fuse is covered under the 2 year electrical warranty. They said I should take the machine to a Sears Service Center to get it repaired. Go luck. I am completely frustrated with the Sears website and the salespeople who want to help, but can't because they haven't been trained on the machines!
Posted on Jul 05, 2006
SOURCE:
I have a CS6000 I sewing machine. I cannot get rid of the E1 message no matter what I do. Any suggestions?
The owner's manual most likely lists what the error means. If you still unable to fix it, you may need to take it for service.
https://www.sewingmachinesplus.com/brother-sewing-machine-error-code-e1.php
Apr 19, 2018 | Sewing Machines
Thread error message
rethread needle using every thread guide, also try changing the needle, if that doesn't help them the machine may have a computer problem
Dec 24, 2015 | Brother SE-270D Computerized Sewing...
How do I fix the E1 error code?
Abnormal rotation in main motor Motor runs at more than maximum speed
Look HERE for Service Manual
May 22, 2012 | Brother CS6000i Computerized Sewing...
Hi Mr. Janome expert, My Janome Memory Craft 4900QC is showing error message E1.Unfortunately I lost the manual to identify the solution to this problem. Could you mind telling what this error means...
E1 means it out of order--something in the electronics is mess up--it needs to be serviced
by a service tech with the tools to check the electronics of the machine
Sep 13, 2011 | Janome Memory Craft 4900QC Mechanical...
I get this message saying E1 Error, i have cleaned it, it still shows that
change the needle
rethread the machine
make sure the thread has not come off the thread take up lever
make sure the bobbin is correctly wound
did you clean under the needle plate where the feed dogs are?
have you adjusted the tension for the fabric your sewing
Nov 18, 2010 | Kenmore 19233 Computerized Sewing Machine
Hi i keep getting the E1 error message flash up on the sewing machine, it still sews but it keeps stopping and the E1 error message comes up, what exactly is wrong with it? can you he;lp? Thanks
E1 means that your machine thinks the thread has broken.
There's nothing you can do to fix this: it has to go to an authorised Singer Service Centre for diagnosis and repair. Usually it's a faulty thread sensor.
Sep 10, 2010 | Singer CE-200 Quantum Futura Computerized...
Error message E6
Go to www.brother-usa.com and you can download your manual for free or call them, Your E6 message means that you have a thread tangled and you must get it out of the machine, totally unthread and brush bobbin area and feed dogs then, unplug and it will reset, then plug in and rethread,
Aug 24, 2010 | Brother CS-6000
19606 E1 MESSAGE HELP
E1 error message is a blown fuse problem.
Check out this site it shows you how to fix it http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
Feb 27, 2010 | Kenmore 19233 Computerized Sewing Machine
Kenmore 19233 Computerized Sewing Machine Logo
722 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
