Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
Ld-1204w1 my dishwasher does not empty the water. comes up with error code E0.
  • 423 Answers
What did you find the problem to be?
On an LG dishwasher, I am not aware of an E0 error. But there is a "OE" error code (as in output error)
The first thing to check is the lower sump area - remove the filter beneath the spray arm and look everywhere for blockages that have slipped through. If that is not the problem, the drain motor has probably failed.
Good Luck!
Posted on Apr 07, 2009
LG Dishwasher E0 Error
Most Frequent Causes for OE - DRAIN ERROR // Water not draining correctly. The manufacturer has assigned this error or fault code to indicate a problem with the water drain pump. Check the drain hose for kinks or clogs. Check the drain pump for any obstructions inside the pump housing.
Also, check the sink drain.
Oct 25, 2017 | LG Dishwashers
LG dishwasher displaying EO error message - have checked all pipes, no blockages
What is the error message or code that you are getting?
Oct 06, 2008 | Dishwashers
Need to reset, can't get it off the error code for overflow
sounds more like the waste hose is blocked or the pump has packed in. If the machine cannot empty the water this will always appear.
Feb 24, 2013 | Dishwashers
I ahve an error code 2 coming up with my Whirlpoos ADP 6000Wh dishwasher?
A couple of sites I know seem to agree. They say:
F2 error fault code
This is a water leak, which has operated the float device by dumping water into the base of the appliance. The anti flood float device switches off the incoming water valve and operates the drain pump until the Water Indicater (pressure switch or Turbidity sensor) indicates the sump empty.
  • Water is in the bottom tray
  • Floater or float switch switches off the water valve and the electronic switches on the drain pump until pressure sensor reports that it is empty. There are numerous causes for this fault, but it all usually comes down to the fact that something, somewhere is leaking. To cure this you need to find the leak.
    Jun 23, 2011 | Dishwashers
    The code EO comes on after the thrid cycle on our Hobart glass washer what should I do
    E0 STANDS FOR NO WATER @SUMP PROBE DURING 3 CONC. CYCLES. MY FIRST GUESS WOULD BE THERE IS SOMETHING STUCK IN YOUR DRAIN VALVE ALLOWING ALL THE WATER TO GET PUMPED OUT INSTEAD OF WASHING AND STAYING IN THE TANK. DONT FORGET TO VOTE
    Oct 23, 2009 | Hobart LXiGC Dishwasher
    Error code LE and OE
    The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
    LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
    Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
    Rinse cycle has no water
    check the sump probe under the screen and the 2 probes in the right back corner.clean them with a light grit sandpaper.let me know.
    Mar 28, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
    Danby ddw2406
    Simple solution. DO NOT spend the money on a tech coming to the house.
    This error code comes from getting too much water in your machine, either from a dish filled with water emptying, or perhaps a clog from the sink that prevents your machine from draining. It is meant to prevent overflows from too much water being in the tub. It is a simple fix though!
    First of all you should at least shut the power off on your machine. For the effort of a couple of more steps, it wouldn't hurt to shut the breaker off at the fuse panel. You will have to unscrew the undercounter tabs that mount the dishwasher to the countertop. They are located just under the counter sticking out from the top of the dishwasher when the door is open. Then proceed to pull out the dishwasher from under the counter. You will only have to pull it out about half way and you will find the overflow valve. It is located on the right side of the dishwasher just under the insulation and level with the lower hinge on the door. (Right side when you are looking at the machine.)
    There are two overflow valves. One looks like a small cup, the other looks like a cylinder with a float in it like your toilet. Both of them have black rubber covers near the bottom. Take these covers off and about a quarter cup of water will flow out of these overflow basins. Allow them to completely empty, then replace the rubber drain covers and then replace the unit under the counter.
    Once you turn the power on, the error code should be cleared and you are ready to use the dishwasher again.
    Jun 03, 2007 | Danby DDW2406 Stainless Steel Built-in...
    Error code AO1
    Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
    Jun 27, 2006 | Indesit 24 in. DE73 Evolution...
    LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
    483 people viewed this question
    Top LG Dishwashers Experts
    Mike
    Mike
    Mike
    Are you a LG Dishwasher Expert? Answer questions, earn points and help others
