Skype We recently moved house and switched broadband providers. My Skype still works well, but my wife's is now unusable when she calls a land line. Everything is ok at her end, but the other party hears her voice very faintly if at all, and only after a 5 - 10 second delay. Headphones and mike test fine with Windows test feature. Skype-to-Skype calls are fine. I'm hard-wired and she is wireless to our broadband router. She has an excellent connection at 54Mbps. No signs of connectivity issues.
  • saviliericar Nov 11, 2008
    I have the same problem with my skype version 3.8 but revers. the person at the other hand seams hear me wel and from my side i hear each word after 5-10 minuts delay and with some distortion some time in the words.
    thank you for help.
  • 507 Answers
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Posted on Oct 20, 2008
WIFE`S CELL PHONE # IS BLOCKED, BUT IS NOT IN BLOCKED #S
Have her dial *82 before she dials the home number. If that works she has the cell phone set to block her number. *82 should unblock it for just that one call.
Aug 25, 2014 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
Ge skype phone
This sounds like a problem with your actual Skype account and not your physical phone. You can use Skype normally, but "Skype Out" (calling land lines) costs money, and the system doesn't seem to think you have any credit on your account.
Try this:
1) Check your configuration on the phone and double check the Skype account username is the one you have credit on.
2) Login to Skype on a computer with the same account. Call someone's land line and confirm a call can connect.
If you can't connect to a land line there (but your Skype account shows you have credit), contact Skype support - there's something wrong on their end that they will have to fix.
If you can connect just fine, try clearing and resetting the user account settings on the phone. If it still doesn't work, try connecting it to a different network (go to Starbucks and use their wifi or something).
Jan 12, 2014 | Lands Phones
I have a skype account but when itry to use it for calls within Canada I am told I do not have enough credit in my account to make the call. thought skype was free?
Skype is free to call and chat with other Skype users through Skype. You need to buy Skype credits in order to call landlines or mobile phones from Skype.
Sep 28, 2011 | Skype IM
Will the M J work on the pc desk top along with a land line.I have ATT broad band which requires a land line Does the pc need to on all the time
Yes M J will need your phone line. AT&T broadband will use your Ethernet. If you want to receive phone calls the computer must be on.
Jun 05, 2011 | Computers & Internet
I I HAVE BROADBAND ON STILL BUT CAN NOT RECIEVE PHONE CALLS
Try installing filters on your phone line. Make sure not to put filters on the broadband modem. If you are using a splitter for the phone and the modem, just put a filter on the phone line and not the one going to the modem. If this doesn't work, contact your internet service provider (ISP) and tell them the problem. They should send a tech to resolve the problem. This has something to do with the POTS splitter outside your house.
Nov 09, 2009 | Lands Phones
LAND LINE TELEPHONES: Can you not assign a long distance carrier?
Yes you can have your phone set to local calls only.
You have to speak with your service provider and tell them you no longer wish to be able to call long distance from your house phone. but still want local calls only.
Jun 13, 2009 | Vtech 9009111 Cordless Phone
Forward a land line using skype diverter and adapter
you can use a new box called "rylwy" wich divert your land line to skipe phisicaly
dd
Feb 09, 2009 | SKYPE RTX Cordless DUALphone VOIP...
BT phone and broadband from sky...ok i cant make or receive phone calls.bt say that they checked the line and it shows no faults..ive tried different phones on line but no joy, interactive on sky box also...
Not a total solution, but a reason , perhaps.
I have both BroadBand and Telephone from BT.
In the past they always billed you with one bill. also if your phone was cut off due to lack off payment so the BB went off also.
they have now split their billing system - and services- into two separate identities, meaning that the phone could be cut off for calls yet your Broadband will still work and vice versa.
So, i would say the problem lies with BT , even though you have ordered your BB from Sky they still have to ask BT to setup your service at the exchange. It seems that they have not checked your service for both BB and phone.
I recently had my phone cut off (BT's 'direct debit 'accident'!) but my BB worked throughout the fortnight it took them to resolve where my paid bill money was!..
So. Call your main service provider (that would be Sky if you get no bills from BT) and tell them your phone service has most certainly NOT been activated.
I recently spent 17 hours over 3 days speaking to 23 customer assistants, before reaching a manager who resolved a similar issue for me at BT.
Under their new setup BB personel cannot see your phone account and phone personel cannot see your BB account - and we get charged over 1/3rd more for this mayhem . their reason explained to me as "having everything on one bill was confusing some customers so you now have two accounts and two bills for everything" !!
your socket is fine as you have enough connection for BB which takes more bandwidth than a voice line.
Basically you have some corporate customer service red tape to hack through.
Good luck
Nov 08, 2008 | Lands Phones
Zoom phone adapter problems
For zoom adapter, calling with handset
Dial 011+1+(zip and number) followed by *
ex. 01112223333*
This is for u.s. calls, just change the country code to the one you need, if not u.s. call.
Dec 09, 2007 | SKYPE / VOIP to PSTN (RJ11) Phone USB...
Computers & Internet Logo
479 people viewed this question
David Payne
David Payne
