Question about Acer TravelMate 513T Notebook
Nokia 6210 USB Phone Parent file is missing.
I have tried numerous times to load PC suite on my computer but when I get to the point of connecting the phone to my pc it wont detect it and the problem comes up as USB Phone Parent is missing/cannot be found. I have tried the Nokia site and nothing has worked. I have tried reloading the software 3 times and connecting to a different usb port numerous times. I am going nuts!!!
    Master:
  • 538 Answers
Handling this in chat..looks like the software is down revision
Posted on Oct 19, 2008
Hello. My Nokia 6210 navigator has broken screen. I would like to backup my all contacts and when I'm trying to connect it with Nokia PC Suite through USB cable I always receive message that my...
Well,
Connect it to your PC then use the arrow keys of the mobile to change the transfer mode to PC SUIT
mode.
The PC SUIT selection might be up or it might be down,so try both,first try up then press the ok button
of the mobile,if it doesnt show the PC SUIT mode on your PC,disconnect the mobile and re connect it
again then try the down key and press the ok button of your mobile.
This will work 100%
Jun 04, 2011 | Nokia 6210 Navigator Cell Phone
Tip
How To Format(flash) Nokia Phones.
Formating is required only when your phone hanging,switching off automatically,forgotten the security(resets to 12345) code and when you want update your phones software.(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To back up your files
*Install the Nokia PC suit
*open Nokia PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*Nokia PC suite of your handset
*Internet connection(Min speed 1Mbps)
*Nokia software updater(you can download by using Nokia PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option)
*Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you
on Jan 29, 2011 | Cell Phones
I forget my phone password. need 2 remove. plz help me out
Hello Nadeem....
You can unlock by 2 methods 1)you can get master code from
http://www.unlock-zone.com/
or
http://www.nokialockcode.com/mastercode.php
and
superunlockcodes.com/unlocking-services/rs12wp6/ (You have to pay for these)
2)You can flash(format) your handset to reset code 12345
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
Thank you have a nice day....
Feb 19, 2011 | Nokia 6300 Cellular Phone
Ptton.off.problem
Hi....
For this check your battery.whether it lock to battery slot correctly or not.
If not just put thick small paper piece on the battery while closing the outer lid.
If battery lock correctly you need to flask your phone(This problem due to virus).
flash(format) resets your security code to 12345
To flash you need
Feb 12, 2011 | Nokia 6020 Cellular Phone
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
To flash you need
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
Actualy i want to format my 3110c mobile phone memory but i can't.please give me solution
Normally Nokia and other symbian devices can be reset with *#7780# or *#7370#. if not you should find master reset in the general settings.
Feb 03, 2011 | Cell Phones
My nokia 3310c when dowloading applications, after reaching 100% download it shows a message application error.
It means the application installer not compatible with your phone. i.e. the application file is .sisx for Symbian S60v3 which is not compatible with your device. Or the file is broken or outdated.
When you download any application software, make sure its compatible with your phone. Your device can only install JAVA application so you can download application with .jar extension. And choose application with proper size for your screen (128x160 pixels), if its too big, it wouldn't able to be installed too.
Hope this help and if helpful RATE please.
Feb 03, 2011 | Nokia 3110 Cellular Phone
I put a security code .. im truying to unlock my nokia E5 i get : code error .. what can i do ? i need to reset my security code please .. thank you a lot
Hi iba bob...
or
and
To flash you need
Try the follwing.... *check whether your phone or memory card memory full or not If memory is full clear some memory *Scan with a updated version of updated antivirus If problem persists you need to flash your handset
To flash you need
*A Computer
*PC suite of your handset
To flash
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option)
**Don't disconnect while updation process
Than you have a nice day...
Jan 31, 2011 | Nokia E5 Cell Phone
I want to install symbian SIS file on nokia 7610 supernova mobile
you can install software or transfer files by connecting your device to a computer via a USB cable and use the Nokia PC suite to do it..download the software from internet to your computer(its free) and install them.
remember to download the exact version which suits your device as there are numerous types of pc suites.
thanks for contacting fixya!!!
Oct 22, 2009 | Nokia 7610 Supernova Cell Phone
Cant download pics from phone to computer no more...why ???
Disconnect the phone cable USB then open Nokia PC Suite (I presume you've got a Nokia N70) At the top of the PC Suite window go to Settings/Manage connections, tick the two bottom boxes, Serial Cable [CA 42] and USB cable, TWICE so as to highlight the Configure button.
Click OK, then follow the instructions to connect the cable to the USB then the other end to the phone.
It should now work if you're lucky, if not do a restart.
After restart connect the phone to the cable.
Give plenty of time for the icon on the PC to go green before clicking it to open PC Suite.
Feb 21, 2008 | Cell Phones
Acer TravelMate 513T Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
