Kernel Cardbus card (YENTA socket) problems
When I installed Linux on my Asus L7200 laptop, this problem took a long time to diagnose
    Scholar:
  • 85 Answers
Dear
With many distributions with the later 2.4.x kernels (>2.4.15 I think), the PCMCIA cardbus services has been merged into the kernel with the YENTA socket. While this works with most laptops it also have problems with many others. Usually, the kernel messages will state that the card is detected correctly but then the ard will not respond to any ping messages in or out.
If your laptop does have this problem then you will need the older modular cardbus services through the PCMCIA-CS package. The information and source can be found at the Linux PCMCIA Information page. The solution for this is not for the faint of heart. It requires a recompilation of the kernel in order to disable the kernel PCMCIA implementation and install the PCMCIA-cs as a module. Again, the best source for Linux information such as kernel compilation can be found at the Linux Howtos. Also, Linux on Laptops provides many useful information on installing Linux on laptops
As of 2006/2007, the Yenta socket in the 2.6 series kernel is quite stable. It should now works properly with most if not all previously unsupported laptops.
Screen garbles after changing between X Windows and console
This is a relatively common problem with Linux on laptops. In the kernel call line in Grub or LILO, make sure that the vga=7xx line is included so that the kernel locks to a particular native LCD resolution. Some common vga= values for 16-bit color are:
800x600 vga=788
1024x768 vga=791
1280x1024 vga=794
Posted on Oct 19, 2008
I have a new ASUS G73SW-A1 laptop with no firewire port. Can I add a firewire port. Can I install a Belkin Firewire adapter into the cardbus? Does it even have a cardbus? There is some kind of card slot on...
You can add a firewire card to on of your existing PCIMCI slot.
Please see, as an example
HERE
You may purchase these cards online at nearly any electronic/computer shop.
May 04, 2011 | Computers & Internet
IO-APIC + timer does not work
May be problem on your CD/DVD rom change it
when it is weak or run time error
Mar 20, 2010 | ASUS M2N-MX Motherboard
Is there any way to configure the poweredge 6300 to boot with just 2 EDO memory cards ? I am trying to install redhat 5.2 (for historical reasons) and the linux kernel isnt compatible with 4x256MB EDO...
From the manual, it says minimum of 128 meg to work, so I assume the problem is with the Linux installation. If the Linux is expecting 512 and does not see it, it probably won't work. Being as you have 4 chips installed, have you tried removing two of the ram chips?
Dec 24, 2017 | Dell PowerEdge 6300 Server
Can we install fedora 11 on Intel d102gcc2 mother board ; I tried couple of time earlier to install various fedora versions , but all went in vain, I think the problem is with sata drivers , please advice!
If you've used live CD Boots, you could try and add nomodeset to the kernel line in the grub boot menu. This would disable kernel mode setting, which causes problems on some graphics cards.
In the BOOT Menu, Press TAB while highlighting "BOOT" Option
Just add "nomodeset" to the end of the text..This disables Kernel Mode Setting and F11 will be up and running....
Oct 21, 2009 | fedora Linux Operating System
Anyone know how to get ASUS Express Gate to go online with Sprint's mobile broadband connection? It works great whilst in Windows but will not connect whenI try to use the Express Gate...Really appreciate...
The problem is that Express Gate uses a cut down installation of Linux embedded on the motherboard to allow you to boot the computer in a very basic mode to access the internet to check email etc. Linux supports most network cards but it will not natively support your USB mobile broadband device. I managed to get my Vodafone aircard working in Linux, but you need to add drivers and kernel support for it and i'm pretty sure that won't be possible with the embedded cut down Linux that Express Gate uses.....
Dec 30, 2008 | Computers & Internet
ISA sound in Linux
Dear.
Since version 7.3, Redhat have removed support for ISA devices. If you have a older computer that uses an ISA sound device (such as my Asus L7200 laptop with Yamaha OPL3 chip), the ISA device will not be recognized. What you need to do is to download the ISAPNPTOOLS package. Unzip and untar the file and then follow the readme file's instruction to compile, install and configure it. You will also need to add the sound device module to /etc/modules.conf. After that the sound should work. Refer to the Linux Howtos for more information.
Since 2005, Linux ALSA sound architecture support pretty much have eliminated that issue even for ISA sound devices.
Oct 19, 2008 | Computers & Internet
Acer Aspire 4720 RHEL4 Installation
again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
Mar 26, 2008 | Acer Aspire 5100 Notebook
Unable to Install Red Hat Linux Enterprises 4
when the time of installing only you have to take linux boot loader then it will show both operating systems otherwise i think the problem is monitor configuration in linux installing
Mar 24, 2008 | Computers & Internet
Failing to log on Asus Laptop L7200 with windows xp professional
can you explain if its the initial logon to enter the bios and set up; or the windows log on to boot into your desktop
Jul 03, 2007 | ASUS COMPUTER (S6FM-1P028C) 11.1INCH 1366...
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
