An internal error occurred in the initialization stage, the application could not be loaded. please contect appkication vender. error no 502.....please help me fix this
well this happens when i start up my computer and when i open my yhaoo message...well this happens when i start up my computer and when i open my yhaoo message...
an internal error occurred in the initialization stage, the application could not be loaded. please contect appkication vender. error no 502.....please help me fix this
XP Disctopan internal error occurred in the initialization stage, the application could not be loaded. please contect appkication vender. error no 502.....please help me fix this
XP Disctop
AnonymousNov 18, 2008
I keep getting the message internal error occured in the initialization stage 502 and i get one that says 302I keep getting the message internal error occured in the initialization stage 502 and i get one that says 302
Then its probably dealing with yahoo messanger! Uninstall the program and re-install it! That should do it, if it dosnt, check for viruses, you may have a program containing a virus!
Control Panel / Administrative Tools / Event Manager
Windows 10 in startup apps go to Administrative Tools / Event Manager
Right Click start menu click event Viewer
once there look to left and expand WIndows Logs Click on Applications and wait for them to load See my pictures i found an error then I clicked on it and it told me what app.
If you don't have event viewer turned on you won't get anything. Then just google turn on event viewer your OS = (winodws 10, Windows 8 etc. turn it on reboot once the error occurs it is recorded go to event viewer and see results.
6E Heater temperature does not go up
enough. (Slower temperature rise rate than 2°C/5 sec. is detected.)
To cancel the trouble status follows these steps: STEP1 .Press MENU
*,2,8,6,4 STEP2.The machine beeps for approx.
one second and displays “MAINTENANCE" on the LCD, indicating that it is placed in
the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry
from the keys. STEP3.Now you are inside the
simulation Press 01 to reset the
trouble status. STEP4.To exit the simulation press 99 • Pressing the 9 key twice
in the initial stage of the maintenance mode makes the machine exit from
the maintenance mode, restoring it to the standby state. • Pressing the Stop button
after entering only one digit restores the machine to the initial stage of
the maintenance mode.
If again 6E occurs try to check the halogen lamp or power supply PCB.Contact authorized technician to do this checking.
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio. This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem. Solution 1.
Remove web.config file from inetpub/wwwroot directory
Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
Reset IIS
Solution 3. Applies to Windows Server 2003 Note: This is a Microsoft KB article: When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message: The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'. CAUSE This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool. WORKAROUND To work around the problem, do one of the following: Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset OR - Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
you might have installed third-party plug-ins, audibles or emoticons on your yahoo messenger. these programs are automatically loaded everytime yahoo messenger starts. they work fine, not until you reinstall yahoo messenger or upgrade it to a newer version causing an internal error when they are loaded. first, remove/uninstall all these programs from the add/remove programs in the control panel, be very careful when doing so and be very sure of what you are removing. then uninstall yahoo messenger. if error still occurs during the uninstallation process, you haven't removed every program/emoticons/plugins connected to your yahoo messenger. when uninstallation is successful, restart your computer and then delete the yahoo messenger folder in the programs folder on your system hard drive. then you can reinstall yahoo messenger before adding/installing your emoticons or plug ins again.
you may use boot to "last know good configuration" try to reboot the computer once again, then while it is initiating, start pressing "F2" until a menu appear, now select "last know good configuration"
this method may depend on what is the type of your motherboard, but usually it is F2 or F5
should you have other questions, just let me know.
Your SanDisk Cruzer® Micro SDCZ6-2048 (2 GB) USB 2.0" may be giving problem due to the internal errors.
Therefore 2 GB card may be scaned through anti virus, if problem repeats then format ur card from the computer.
thanks u i will try this...
XP Disctop
ok..what application are you referring to?
