Mitsubishi 1080 hd tv
This tv was given to me by a military family that moved, friends of ours..
She told me that the remote got stepped on and now the timer light just flashes and will not turn on..
is there an easy fix for this?
send any info to
Wulfsden2004@yahoo.com
thank you,
Chris
No the TV timer light flashes and will not turn on, but the stepping on the remote is what I was told happened, the tv itself will not turn on at all..
The husband mentioned something about if you pull some chip and leave it out for a few minutes when the power is unplugged, and then drained it would reset the whole tV? any idea what chip that would be?
Posted on Oct 19, 2008
  • 2,071 Answers
If you can turn on the TV manually,but not in the remote then the problem is in the remote.You better open the remote and reworks or resolder all solder parts joints maybe it loose or crack.Check also the circuit board if not broken if broken use a small wire to connect the broken line.
Hope it may helps you;
Regards,
VOTIT
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
I need a remote control code for a Mistsubishi HD 1080 TV
need to know what remote you have to help do you have a model # or if you go to this site you will hind the 2 remotes S I sells. Click on the pic. then you can download the manual. Hope this helps. If the remote is not there Get me the model # and I will find the codes for you.
http://mscustomercare.com/
Good Luck
Dec 30, 2008 | One For All URC-4330 Remote Control
I cant get high def 1080-i to work on my mitsubishi 55807
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
I just subscribed to HD service, But my mitsubishi 55807 tv wont display 1080 it stays on 480. the server is comcast. can you help?
Tv code
Good Day, weilly101;
Look into your COMCAST booklet or call COMCAST, not TV problem. Good Luck, big IRISH.
Aug 30, 2008 | Mitsubishi WS-65809 65" Rear Projection...
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
