Question about Steiner Center Axis Pin for Bighorn 15x56 Tripod
Tripod adapter for Steiner Navigator C 7x30
Where can I get the replacement part that has the screwed hole to acept a tripod adapter, for my Steiner Navigator pro C7x30
    Sniper:
  • 73 Answers
How do I change the thread size on my monopod?
You should not need to change the thread size on your monopod. All tripods, monopods, cameras and other accessories have standard fittings. Check that you haven't accidentally crossed the threads on your Panasonic which would make it difficult to locate the threads to tighten it.
Also, check that you are not trying to screw the monopod into the hole. Some cameras have a smaller hole beside the tripod thread.
You may be able to contact your monopod manufacturer in case they supply an adapter that wasn't supplied with your monopod.
Sep 18, 2014 | Manfrotto 290 Series 59.4" Monopod
Head won't secure to tripod
Two potential issues. 1. Perhaps you have just not screwed it on tight enough. Just tighten the black knob as much as you can then screw the head on your legs as tight as you can. 2. If you can't even do that I will assume that the hole on the bottom of the head is too large for the screw on the tripod legs, in which case you just need a a bushing adapter. Like this one:
http://www.bhphotovideo.com/c/product/882988-REG/Sunwayfoto_tn_15_Bushing_3_8_1_4_Stainless_Steel.html
Apr 10, 2014 | Gitzo Gh2750qr Series 2 Magnesium Off...
Sony DSC-H20 1/4 inch Tripod adapter
There is no way to fix it. You should go to nearest Service centre and change the Camera body part.
Best wishes
Mar 16, 2012 | Sony Cyber-shot® DSC-H20 Digital Camera
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
The leg axles of my Manfrotto 190PROB are loose and the tripod legs will not stay spread when I carry it. How do I take off the top yoke to access the allen screws to tighten the leg pivots?
The top yoke of a Manfrotto 190PROB is held in place by a spring mechanism. The spring mechanism is just behind the screw that tightens the center column. First remove the center collumn. Inside the to yoke (where the centre column was) there is a small hole. Poke something in that hole to push back the spring mechanism. You should now be able to push the yoke out towards the top. When the yoke is removed you will see the three screws that keep the hinges tight. Reasembly is straight forward. Simply re-enter the yoke in such a was as to push back the spring mechanism.
Dec 12, 2010 | Manfrotto 190XPROB PRO ALU Tripod
Eye rubber for 7X50 military marine
You can get the green eyecups for the military marine model from steinerpartsdirect.com I can also recommend changing the standard neck strap with a neoprene one for an older Steiner Nighthunter that is non cliclock. Makes for a much more confortable carry. Just make sure it is one that loops and isn't click lock.
Aug 10, 2009 | Steiner Navigator Pro Binocular
My Steiner Navigater 7 by 50 were coated in a thick layer of sticky pollen. I briefly rinsed them under the tap and now the right hand side (with the compass) has condensation in it. I thought that because...
If weather cooperates, put them out in the direct, bright sunlight for a couple of hours.I have done this many times in the last 30 years or so.Usually that will drive the moisture out.I generally clean the outside of my binocs with a paint brush, or in some cases, a toothbrush.For the lenses I use a soft cloth.No solvents.Good Luck
Mar 15, 2009 | Steiner Navigator Pro Binocular
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
Photography Logo
103 people viewed this question
Top Steiner Photography Experts
pontelemon
pontelemon
Tony
Are you a Steiner Photography Expert? Answer questions, earn points and help others
